RTA-11t problem
24
  • derwood
    derwood Posts: 29
    Ha!, that is nothing. Wait till I get the carver 1.0 I used to own a pair of monitor 10b's that I bought new in 88', those things were awesome. Had a new carver 1.0 just on the verge of clipping, they never failed. Damn, those were the good old days.
    F1nut Posts: 51,676
    Yeah, they don't clip, they just blow up.
  • codycatalist
    codycatalist Posts: 2,662
    I still feel it's impedance or the amp itself. Are the other speakers you tested 6 ohm or under? I know if I drop my impedance by half I cant even turn up a quarter of the way without clipping.
    I figure if it was crossover issues you would hear it.
    If it was the internal wiring causing a short it would happen regardless of the amount of volume.
    If it is the speaker wire going to the amp grounding out that'd be easy noticed.
    IMO I think it's over driving or internals in the amp.
    I am NO audio expert by any means but running through different issues I've had, those are my 2 cents.
  • derwood
    derwood Posts: 29
    yeah, you are probably correct. It's just strange that the other speaker does not trigger the relay. Thanks.
  • derwood
    derwood Posts: 29
    Who knows, maybe that one is functioning correctly and the crossover that I say is good may have a problem. All the more reason to get them rebuilt.
  • boston1450
    boston1450 Posts: 7,758
    If i run my Yammy at 10:30 on the dial my brain is getting beat up. I cant imagine going above 12:00. Id be worried about my ears let alone my gearn1xdn8eoys3o.jpeg
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Nightfall
    Nightfall Posts: 10,084
    edited April 2016
    10:00 is plenty for me too. Any louder than 11 or so and my SDA's start sounding like garbage anyway, and that's with 350 watts.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • codycatalist
    Dang is that black lacquer on top?
  • boston1450
    edited April 2016
    Yes & they are spiked now & not so close to a wall. Gives the rear passive room to breathe
    Randy-Maine
    by David WMG
  • codycatalist
    Ugh. I want the 15s.
  • boston1450
    I want the 11's but wife say NO lol
    Randy-Maine
    by David WMG
    F1nut Posts: 51,676
    It's a sheet of gloss black acrylic. You can pry it off from the rear with a putty knife. When I restored a pair of RTA 15TL's I replaced the tops with slightly textured matt black tops as the smooth gloss ones get scratched way too easily.
  • codycatalist
    My wife hasn't told me no yet but I've also not fallen into the rabbit hole yet.
  • boston1450
    btw i enjoyed reading you archived threads. I would love to get my ears on some 11's someday. To the op - i hope you get the issue fixed. The 11's are well loved around here.
    Randy-Maine
    by David WMG
  • derwood
    derwood Posts: 29
    if you want to here your polks sing put on The cars "Candy-O"
    F1nut Posts: 51,676
    That's a lot of reading....LOL
    I take it you mean the Model/Monitor 11's? They are basically Monitor 10's on steroids with a clearer midrange.
  • derwood
    derwood Posts: 29
    codycadalist, I bought the rdo-198-1
  • Nightfall
    derwood wrote: »
    So you have RTA-11TL's and not RTA-11T's?
    afterburnt wrote: »
  • codycatalist
    Sweet! Make sure to upgrade the crossovers to allow those tweets. Stock they accept the RDO194
  • Nightfall
    F1Nut wrote:
    To convert an RTA 11T model to "TL" status you would have to change one inductor from 0.4mH to 0.3mH, change one resistor from 2 ohm to 1.5 ohm, change one cap from 12uF to 16uF, remove the poly switch, remove a 2.7 ohm resistor and change the tweeter. Not impossible, but probably not worth the cost.
    afterburnt wrote: »
  • derwood
    derwood Posts: 29
    it currently has sl3000 tweeters.
  • boston1450
    i read alot :) ... nope i ment RTA11's ive never heard. Ive owned the Monitor 10's & 11's w/peerless tweets that sounded very good
    Randy-Maine
    by David WMG
  • derwood
    derwood Posts: 29
    I thought the rdo-198 replaces the sl3000
    F1nut Posts: 51,676
    Derwood, look at schematics posted here for both versions, then compare to your speakers. You could very well have the TL version as Polk was known to use up stuff from the previous model.
  • derwood
    derwood Posts: 29
    my speakers say RTA 11t. The crossovers are dated 1990, there is only one rectangular resistor directly under a capacitor.
  • derwood
    derwood Posts: 29
    F1nut, thanks.
  • Nightfall
    There's also a chance that a previous owner incorrectly replaced the tweeters at some point in their life. Looks like you have some research to do.
    afterburnt wrote: »
  • codycatalist
    Check what the model number is on your upper passive. If it's SW83 it could be the TLs.
  • boston1450
    edited April 2016
    derwood wrote: »
    YupAroo. way better tweeter :)
    Randy-Maine
    by David WMG
    F1nut Posts: 51,676
    derwood wrote: »
    In that case, you have the TL version.
