Improvements To The SDA SRS 1.2TL - Summary Of Modifications
DarqueKnight
DarqueKnight Posts: 6,765
edited May 2013 in Vintage Speakers
Introduction
It is always amusing when we SDA enthusiasts are reviled for daring to use our 20+ years old SDAs with modern, and often very high performance, electronics and cables. It is amusing because of the arrogant ignorance shown. Does something being old mean that it cannot be improved and brought up to modern standards?
Can a 100 year old house be remodeled with every modern convenience and comfort and brought up to current structural standards? Can a 30 year old sports car be retrofitted with a modern engine, drive train, suspension, etc., and then run rings around a comparable sports car fresh off the assembly line? The answer to both questions is an unequivocal YES! In the case of my modded, hotrodded, Stereo Dimensional Array Signature Reference System 1.2TL "True Stereo" loudspeakers, which will turn 24 years old in October of this year, the only original parts are:
1. The medium density fiberboard Cabinets.
2. The stereo and dimensional drivers.
3. The passive radiator.
4. The polyfill material.
Everything else was replaced with higher quality parts: crossover circuit board, capacitors, resistors, inductors, internal wiring, crossover cover plate, binding posts, binding post plate, binding post jumpers, tweeters, driver and tweeter seals, AI-1 non-common ground interface, grille cloth, the method of securing drivers and tweeter to the baffle board, and even the original oak trim.
Most of the performance improvements were recommended by Polk's engineering department. The truth is that SDA's were about 20 years ahead of their time. Low noise high performance crossover components were not available in manufacturing lot quantities in the 1980s. Even if they had been, amplifiers that were stable into low impedances were not common. Therefore, SDAs were put in a choke hold by the state of amplifier technology and by the state of component technology. It took a couple of decades for other technologies to "catch up". The fact that SDAs are able to perform well with today's high performance amplifiers, cables, and electronics is a testament to the genius of the design. Components which exhibit low electrical and mechanical noise are particularly important in stereophonic reproduction because such noise diminishes stable and clear spatial rendering.
I am deeply appreciative of the collective efforts of Polk Audio's engineering department, which started me on the speaker upgrade path in 1990, and the talented members of this forum who have brought a lot of thought and expertise to helping SDA owners get the most from their "ancient" speakers (Ken Swaugger, Toolfan66, F1Nut, Face, RickTfromAZ, VR3, Gimpod). I must also express my appreciation to Matthew Polk and Polk's engineering Vice President, Stu Lumsden, for continuing to provide product support throughout the years for a loudspeaker line that was formally discontinued 22 years ago.
The electrical and mechanical modifications are rated as small, moderate, large, or huge with regard to their impact on sonic and mechanical performance improvement.
Electrical Improvements
Figure 1. Polk recommended mod: the RD-0198 tweeter. Moderate improvement.
Figure 2. AudioQuest GO-4 15 AWG Hyper-Litz speaker cable used for internal wiring. Moderate
improvement.
Figure 3. Installation of AudioQuest GO-4 wire.
Figure 4. AudioQuest GO-4 wire in tweeter section.
Figure 5. Custom aluminum binding post plate with Cardas CCGR-S gold plated tellurium copper binding
posts. No sonic improvement.
Figure 6. AudioQuest Perfect Surface copper jumpers with silver bananas and Cardas CCGR-S binding
posts. The jumpers, surprisingly, provided a small improvement.
Figure 7. Custom binding post plate with cables attached. This picture was taken prior to the Dreadnought's
Monster Cables replacement by PS Audio Xtreme Resolution Reference speaker cables.
Figure 8. Steel retaining ring for binding post plate. Large mechanical improvement. This picture was taken
before the internal wire replacement.
Figure 9. SDA inductors: Solen 10 AWG, North Creek 14 AWG, stock 18 AWG.
Figure 10. Solen SDA inductor installed. Large improvement. This picture was taken before the internal wire
replacement.
A high DC resistance SDA 16 mH inductor was used to keep the speaker impedance reasonably high for the typical power amplifiers available in the 1980s. Such caution is not required with today's amplifiers. A large gauge 16 mH inductor with very low DCR significantly improved bass response.
Figure 11. Custom crossover circuit board with bracing board. Small sonic improvement. Large mechanical
improvement.
Figure 12. "Custom crossover circuit board with Sonic Barrier damping material. SB brought a
small sonic improvement."
Figure 13. Crossover board with crossover cover plate treated with Dynamat Xtreme.
Figure 14. Top side of completed crossover with Jantzen and Solen inductors, Sonicap capacitors and
Duelund resistors. All the crossover improvements worked together to make a huge improvement.
The total crossover upgrade was a huge improvement, but the constituent modifications ranged from small to large.
Figure 15. Duelund CAST Silver resistors on underside of crossover circuit board. Small improvement.
Figure 16. Per Polk's recommendation, the tweeter protection polyswitches were removed and replaced
with a copper jumper wire. This made a small improvement. The copper jumper was replaced with a silver
wire jumper, which made a further small improvement.
It was easy to hear the difference between the copper and the silver jumper wires. For example, on words like "unique" it was easier to hear the vocal click at the end of the word.
Figure 17. AI-1 Dreadnought custom non-common ground interface with 1000VA isolation transformer.
Large improvement.
Figure 18. Dreadnought Cardas CCGR-S binding posts.
I like the Cardas posts because of their strength and appearance. I have not been able to hear a difference between them and other high quality binding posts, like Vampire. I couldn't even hear a difference between the Cardas posts and the stock posts...although I could hear a difference between a 1 inch copper jumper and a 1 inch silver jumper. I also easily heard a difference between stranded copper wire binding post jumpers and AudioQuest solid core copper wire jumpers.
Figure 19. The Dreadnought's Avel-Lindberg AV-047548 1000VA shielded transformer.
Figure 20. Dreadnought's transformer installed with Dynamat Xtreme damping material.
Figure 21. Dreadnought cables: PS Audio Xtremet Resolution Reference 11 AWG speaker cables.
Moderate improvement over previous Monster Cable Z2 Reference cables.
  • DarqueKnight
    edited April 2013
    Mechanical Improvements
    Figure 22. Steel retaining rings for drivers and passive radiator. Huge sonic and huge mechanical
    improvement.
    Figure 23. Steel retaining rings for crossover cover plate and former stock binding post plate. Huge
    Figure 24. Armacell was a small sonic improvement over Mortite and stock seals. Armacell was a huge
    Figure 25. Drivers with Armacell foam tape applied. Armacell compresses to paper thinness.
    Figure 26. Driver and passive radiator baskets with Dynamat Xtreme damping material applied. Small
    sonic improvement.
    Figure 27. Bass brace: This is a Polk supplied accessory with the tallest models of SDAs. Moderate
    sonic improvement.
    Figure 28. Grille cloth: "Ponte" thin silky black knit fabric from Hancock Fabrics.
    Small sonic improvement, huge cosmetic improvement.
    Figure 28a. Blackhole 5 damping material. Large improvement.
    Cosmetic Improvements
    Tiger maple compared to the standard obnoxious oak? The tiger maple was a spectacular cosmetic improvement.
    Figure 29. Left top cap.
    Figure 30. Right top cap.
    Figure 31. Both top caps.
    Figure 32. Cap rounded corner detail.
    Figure 33. Top cap tiger striping detail.
    Figure 34. Bottom cap tiger striping detail.
    Figure 35. Burl/tiger striping detail on inner side strips.
    Figure 36. Tiger striping detail on outer side strips.
    Figure 37. Left sides.
    Figure 38. Right sides.
    Figure 39. Custom crossover cover plate. Silky black finish with brass handles. Huge cosmetic improvement
    over the stock plate.
    Figure 40. No, my SDA SRS 1.2TLs are not hopelessly out of date both sonically, technologically or
    aesthetically. Such Good Sound!
    Reference Threads
    01. AudioQuest-GO-4-Internal-Wire-Replacement-For-The-SDA-SRS-1.2TL
    02. SDA-SRS-1.2TL-Sonicap-Upgrade
    03. Duelund-Resistor-Upgrade-For-The-SDA-SRS-1.2TL
    04. The-AI-1-Dreadnought-Project-Pt.1
    05. SDA-SRS-1.2-1.2tl-cover-plates-handles
    06. SDA-SRS-1.2TL-Custom-Wood-Panels
    07. SDA-Driver-Seals-Original-Foam-vs.-Mortite-vs.-Armaflex-Foam
    08. Dynamat Xtreme Driver Basket Damping
    09. SDA-Polyswitches-Are-Nasty
    10. Custom-Printed-Circuit-Board-And-SDA-Inductor-For-The-SDA-1.2TL-Preliminary-Results
    11. Improvements-To-Modified-SDA-SRS-1.2TL-Crossover
    12. Upgrade-Low-Frequency-Inductors-For-the-SDA-SRS-1.2TL
    13. Upgrade-High-Frequency-Inductors-For-The-SDA-SRS-1.2TL
    14. Solen 10 AWG SDA Inductor Upgrade
    15. Steel-Retaining-Rings-For-SDA-Drivers-And-Passive-Radiators
    16. SDA-Tweeter-Brackets-for-SDA-SRS-1.2TL-SDA-SRS-and-SDA-CRS
    17. PS-Audio-xStream-Resolution-Reference-Speaker-Cable-A-Review-Pt.-1
    18. Sonic-Barrier-Damping-Material-For-SDA-SRS-1.2TL-Crossover
    19. Revisiting The Bass Brace
    20. Custom Binding Post Plate
    21. Blackhole-5-Damping-Material-In-The-SDA-SRS-1.2TL http://www.polkaudio.com/forums/showthread.php?148198-Blackhole-5-Damping-Material-In-The-SDA-SRS-1.2TL&p=1913822#post1913822
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited April 2013
    Thank you for your attention to detail and to document all changes for future polkies to use as a great reference.
    F1nut Posts: 52,406
    edited April 2013
    Nicely done, Ray and thanks for getting the ball rolling.
  • Conradicles
    Conradicles Posts: 6,437
    edited April 2013
    No Spikes or did I miss that? Great job!
  • vmaxer
    vmaxer Posts: 5,124
    edited April 2013
    DK, now it would seem that you are all out of something to do with this hobby.....I can help!:surprised:
    I can drive up my 1.2tl's and swap them out with yours and you will have the pleasure of not being bored any longer:redface:
    Wont cost you a dime:mrgreen:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dcoil
    dcoil Posts: 153
    edited April 2013
    Ray, I would love to hear your system - maybe the best sounding Polks on the planet and maybe one of the best sounding speakers on the planet. I know that sounds preposterous to a lot of audiophiles, but I've auditioned speakers costing >$10K with high dollar electronics I wouldn't trade even for my SRS's.
    Did you say yours were for sale:cheesygrin:
    SDA SRS modded: X’ovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDO’d, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
  • nspindel
    nspindel Posts: 5,343
    edited April 2013
    You didn't mention the polyfill! Stock or replacement???
    Great work, as always. Thanks for posting!
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2013
    Ray,
    Thank you for yet one more great write-up and great pictures -- what a list of great threads!
    This summary should be invaluable reading for all those who are out there -- or who will be out there in the future -- and who are looking for ways to get the most out of there Polk SDAs.
    Like many others, I could not have done what I have done to improve my SDA SRS1.2s and 1Cs without your many threads that show the way and document your results in convincing ways.
    This thread makes it easier for those to follow.
    Sincere thanks!
    PS: I have auditioned speakers ranging up to $100k MSRP and more, and as good as they sound, they do not produce the SDA effect that, IMHO, distinguishes the vintage, upgraded (or stock) Polk SDAs from any other speakers you can buy at any price.
    Onward and upward -- or should I say, onward and downward, further into the rabbit hole! :smile:
  • teekay0007
    teekay0007 Posts: 2,288
    edited April 2013
    Had I not already given my left one just to keep my hair past the age of 35, I definitely would do it just to get the chance to spend some time admiring the workmanship, the beauty and the sound of that system, in person. :cool:
    VERY well done, DK!
  • audiomagnate
    audiomagnate Posts: 48
    edited April 2013
    Those have to be the nicest Polks on the planet.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited April 2013
    "In the future". I can imagine X years from now, someone picking up a set of SDA's at an estate sale and asking how to make improvements on a "vintage" set of speakers.
    Couresty of DK, that person will have all the answers to the "How" and "Why" right here, with links to the nuts and bolts.
    Throw in your own superlative adjective(s) here to describe the effort and documentation; I don't have any to do it justice.
    Acknowledging the input/assistance/suggestions from those involved is, btw, pretty classy. Very, very nice.
  • DarqueKnight
    edited April 2013
    Polk recommends using either the bass brace or spikes, although I have read of people using both. In my room, the bass brace sounded better than spikes. I have not tried using the bass brace and spikes together.
    vmaxer wrote: »
    Noooooo...there is always something to tweak...something lust after.:wink:
    vmaxer wrote: »
    If I had the storage space, I wouldn't mind having two pairs of stock 1.2TL's: one for spare parts and one for research and demonstration purposes to show the huge difference between the modded and stock speakers.
    vmaxer wrote: »
    That's very generous of you, but taking advantage of you like that would bother my conscious.:cry:
    dcoil wrote: »
    Yes, look for them in the Flea Market on April 1, 2014. I should be bored with them by then.
    dcoil wrote: »
    In my case it has been speakers costing $15,000 (B&W 802 Diamond) to $24,000 (B&W 800 Diamond) to $35,000 (Dunlavy SC-VI).
    For me, SDAs are like the nice looking all around good woman with good character that you have a long-term serious relationship with. Other exotic high performance speakers, to date, have been more like the super hot woman who's good in bed but you only want to have a fling with her.
    While we are on the subject of other speakers, I thought the boutique capacitor connoisseurs among us would be interested in knowing that two of the world's most revered loudspeaker brands, Dunlavy and Dynaudio, used/use (Dunlavy went out of business) the allegedly "harsh" sounding Solen capacitors in their crossovers. Both companies also used/use ceramic metallic resistors in their crossovers (SDA stock resistors are ceramic metallic type).
    Dunlavy SC-V ($15,000 per pair) crossover with Solen capacitors and ceramic metallic resistors.
    Dynaudio Evidence Platinum ($85,000 per pair) crossover with Solen capacitors and ceramic metallic resistors.
    I wonder if Face and F1nut would accept a free pair of Dynaudio Evidence Platinums if the condition was that they could never tweak the crossovers.:twisted:
    I was curious about what Wilson audio used in their crossovers, but apparently that is a closely guarded secret:
    "I knew there was no point in opening the Sophia 2 to examine the crossover network because after Wilson Audio has built its crossovers, it places them inside a large container into which it pours a slow-setting epoxy compound. When the epoxy dries, all the components—inductors, capacitors and resistors—are buried forever inside it, a process Wilson Audio refers to as ‘potting’. According to Trent Workman, of Wilson, this is for two reasons. Firstly and most importantly he told me, ‘the crossovers sound better when they’re potted.’ Also important, this process means the crossovers will stay within specification even if they’re subjected to rough treatment while the speakers are being transported and shipped. The exact make-up of Wilson Audio’s crossovers is also a closely-guarded secret, with all the parts hidden away if you go on a factory tour, but Workman told me I’d find Multicap capacitors and air-cored inductors inside." [Link: Wilson Audio Sophia II Review - AV Hub]
  • DarqueKnight
    edited April 2013
    nspindel wrote: »
    Stock. Thanks for mentioning that. I did consider replacing the polyfill. Ken Swauger suggested a replacement material, but I could not find any conclusive evidence of a "better", rather than just "different" material.
    When I can bring myself to taking my speakers apart again, I will experiment with adding strips of Sonic Barrier Black Hole 5 to the wall behind the drivers.
  • nspindel
    edited April 2013
    I bet your grill frames are stock as well....
  • teekay0007
    edited April 2013
    There's DK, reigning Polkie of the Year, churning out more sig material right there! :biggrin:
    Worth noting, I've tended to find said hotties quite fatiguing. :cool:
  • drumminman
    drumminman Posts: 3,395
    edited April 2013
    Nice write up, Raife, and thanks for all the clear and concise DIY threads. You've made it possible and easy for those of us with less than an EE degree to follow in your footsteps.
  • DarqueKnight
    edited April 2013
    nspindel wrote: »
    They are, but I consider them part of the cabinet.
    By the way, I ordered a sheet of Black Hole 5 today. One 24" x 27" sheet is enough to treat both speakers. I'm not looking forward to gutting my speakers (again) though.:sad:
    The reports by drumminman and Polkmaster1 on this mod were very informative and encouraging.
  • DarqueKnight
    edited April 2013
    Toolfan66 wrote: »
    Just don't do the entire cabinet with it like some other schmuck did a few years ago..:cry:
    I recall you doing the Sonic Barrier mod, but I didn't recall the BH 5 mod.
    I am just going to put strips behind the drivers and tweeters similar to what drumminman did with his 2.3TLs.
  • DarqueKnight
    edited April 2013
    Toolfan66 wrote: »
    I also have 2" wide strips on the sides of the cabinets behind the drivers as well..
    Did you use a single 2" wide strip down each side in the driver area or multiple 2" strips? How long were the side strips?
  • TennMan
    TennMan Posts: 1,266
    edited April 2013
    Toolfan66 wrote: »
    A single 2" down each side.
    I cut four strips 4" wide, and four strips 2" wide, that used up one piece of BH5, I then used small pieces of SB behind the tweeters..
    I love the results, it really cleaned up the mids..
    When you installed the BH5 did you put the polyfill back in place or do you leave it out?
  • drumminman
    edited April 2013
    Now that you've become acquainted with the sound of your new Pass Mono Blocks and the SQ improvement they've brought it'll be interesting to see how the BH 5 mod affects your speakers. I would guess that you would experience what I, TF and others have, but the proof is in the pudding.
    Looking forward to your impressions.
  • locnguyen26
    locnguyen26 Posts: 34
    edited May 2013
    nice work!!!
  • locnguyen26
    edited May 2013
    thanks for all the pictures!!!
  • headrott
    headrott Posts: 5,496
    edited May 2013
    You aren't bored with them already Ray? Perhaps if you just listen to them a little more?:razz:
  • vmaxer
    vmaxer Posts: 5,124
    edited May 2013
    Great info, I need to get to work on mine.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • drumminman
    edited May 2013
    This thread should be a sticky. Lots of valuable info re: the pics and links to the mods all in one place.
  • woofiepaws
    The links did not carry over form the old forum.
    Grrr.
  • ooklaa
    ooklaa Posts: 46
    Just joined. Have a lot of reading to do. But the links for the modifications do not work. Anyone have new links?
  • Malbec
    Malbec Posts: 558
    Go to DK's profile page by clicking on his screen name. On the right side of his page click on discussions. That should give you plenty to read.
  • wrich22a
    wrich22a Posts: 7
    The links that are referenced above by DarqueKnight do not work, I haven't been on this forum for about 6 years and I am trying to play catch up. I have a pair of SDA-SRS's that I bought on E-bay 9 years ago which I modified with new tweeters, capacitors, resistors etc. Based on what I learned form Ray.
    Can I assume the .4mh and .7mh inductors that are in the chart will work part number 1160 and 1489?
    Does anyone know about the 2.75mh inductor? I found a Jantzen listing which has a part number 000-0049, which 2.75mh, .9ohm, Awg 18.
    Other wise I will Measure what I Have
