Avengers blu ray skips and pauses
At thought it was a used movie but I got a new copy today and it does the same thing, almost like it's steaming the movie, what's th e deal? Very annoying. Player is turned on and off daily with my power conditoner.
Using a marantz UD7007. Please help
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
  • Inspector 24
    Inspector 24 Posts: 1,308
    I expected you to say it's with a Panasonic player...which mine does on far too many discs...
    If perfectly clean new disc, suspect dirty lens maybe?
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Check the manufacturer's website to see if there is a firmware update for your player. Sometimes newer discs have encoding changes that require firmware updates in players.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    I've read that Panasonic players do that.
    I need to, I'll look into doing that. Thanks a bunch
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Age of Ultron played through without an issue.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    tonyb Posts: 33,067
    Take it back, I've gotten a few bum discs along the way.
  • voltz
    voltz Posts: 5,384
    are you Sure it wasn't the HULK making it skip?
  • Mr. Sharpe
    I haven't gotten around to it yet. I found where I can put in my serial and I need to do it sometime. we watched the movie the other day and the pauses were clumped together about 5 at a time roughly 20 minutes apart. it's annoying. but the first time we watched it got so bad and completely stopped playing.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • gce
    gce Posts: 2,158
    What he said^^^^. This happens all the time with new discs if you don't check for updates.
    Anaheim Hills CA,
  • polrbehr
    polrbehr Posts: 2,842
    I know of someone who had a similar issue with the Dredd bluray, and he's using a
    (older) Pioneer BDP-09FD. The disc played once or twice and will not even load anymore. And every other BD he owns is fine.
    Not sure if a firmware update would be in order, he asked me and I told him give it a shot - or just buy an Oppo... LOL
    pitdogg2 Posts: 26,953
    yes do this I have a used BR player I bought here Pioneer Elite BDP-51 and it started skipping and not playing new BR movies.(DVD's played fine) I didn't expect it to still be supported yet I went to the Pioneer website after checking my Firmware number and low and behold there was a new firmware upgrade and it even listed the movies that were causing problems. With BR you need to check often get used to it it is the nature of the beast even if you are not having problems update those suckers.
  • Mr. Sharpe
    That seems ridiculous to have to do... but on the other hand the picture is so sharp it's worth it. DVDs are so fuzzy now, I've slowly been buying bd's new and used:) worth every penny
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    I checked the updates and upgrades on marantz.com and they have an update for all their receivers, none for the blu ray player.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
