Building a pair of Polk Monitor 10's
This is the construction drawing I will be following.
Will I am -
As far as aesthetics, the only obvious change is I may laminate the front with an Oak laminate rather than the satin black polk used. We'll have to see how that looks before making any permanent decisions...
Will I am -
Did the coating used on the originals front baffle serve a sonic purpose?
Now that is a good question. The only answer I can give is I have seen M10's with painted fronts and others with what appears to be a poly laminate. Did polk test all construction materials including vendor changes and process improvements or did they say that's close enough, we're making money?
I am making my cabinet from MDF, not particle board, and I'm making 1" front and back panels rather than 3/4", so I think in my build it's moot.
If polk had a sonic benefit in mind using a laminate rather than something else, i would be impressed.
Will I am -
I finished my cross overs this evening. Anything I missed?
Will I am -
Stick with nylon risers...the steel will mess with the inductors on the terminal cups.
nbrowser - as you can see I went with the nylon standoffs for the additional riser, but I did use the original steel standoff on the first riser. So I haven't added any additional steel but I also haven't removed any. That meets my build criteria, right or wrong.
Will I am -
Looks good, nice an clean.Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
Working on getting SDAs -
Looks good. Pretty sure those original standoffs were aluminum though.Home Theater/2 Channel:
dhsspeakerservice.com/ -
You are correct, the others I bought are steel so even better. My mistake.Will I am
In the shop today to start cutting pieces.
Will I am -
Nice shop! 3 bandsaws?b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Perfect fit! Now for the real thing!
Will I am -
So Monitor 7's are suppose to be the bee's knees when it comes to the series. Let's find out. I had enough material to make a pair of 7's.
Will I am -
Very impressed!!! Looks good!!!
I like your work! Looking forward to seeing you smile when your finished.
Great thread! Been there before a few times..LOL
Today is wood laminating day. I decided to do the front and backs in oak. I think this will be a good contrast to the walnut veneer.
Will I am -
After trimming. These will look good after sanding and a clear satin finish.
Will I am -
These are the pieces for the sides and top including the solid walnut for the front.
Will I am -
Last thing we got done tonight was gluing the solid walnut to the sides.
More to come next weekend.
Will I am -
Getting ready, sanding the sides smooth for the veneer.
Will I am -
Is that your workshop!?!
*subscribed*Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Will I am
