No BS pre amp
1246
  • SCompRacer wrote: »
    The analog power supply of the DAC chip must be an ultra low-noise design or the chip itself won't exhibit ultra-low noise. Noise degrades dynamic range. Low noise power supplies are expensive to implement and in my case, add much heat. A vented enclosure is a must. Add high quality output with low noise power supplies and the signal leaves the DAC with the quietest and most dynamic signal to be amplified.
    Rich,
    What impact would "regenerated" AC (such as the PS Audio Power Plant) have on your circuit as described? Could a less elaborate power supply topology be employed?
    I've mentioned before, undoubtedly to a chorus of rolled eyes, my Power Plant is the best audio expenditure I've made in 45+ years as an enthusiast. I can only judge what I actually hear, and it is a night/day difference in noise floor. It lets all the other aspects of the sound reproduction take a couple of steps forward.
  • marvda1
    marvda1 Posts: 4,942
    remote done right is a $500 upcharge in the dehavilland ultraverve 3 preamp.
    Puritan PSM156
  • lightman1
    lightman1 Posts: 10,796
    marvda1 wrote: »
    She's a beauty Marv. Gotta sell some plasma though. :s
    SCompRacer Posts: 9,110
    Rich,
    Good clean power in will definitely help, but if the PS is not a top notch design you can still get noise out of it, regardless of input power. Twisted Pear has a pretty good design. Salas is one of the legends of power supplies at diyaudio.
    I use a Richard Gray conditioner.
  • Hey Russ how is the pre choice going? I am loving mine, when I first used the TT I thought it was way to bright but shes sounding much nicer now. Good luck and thanks again for your help.
  • lightman1
    Got a few leads, Bob. Just gotta check a few more things and the Iowa trip came up sooner than expected. Keep ya posted.
    txcoastal1 Posts: 13,505
    There might be some opportunities to look/listen to some pre's at LSAF...might want to hold your panties
  • lightman1
    txcoastal1 wrote: »
    Commando my friend. You have been warned.
    lightman1 wrote: »
    txcoastal1 wrote: »
    Not worried you'll be bunking with Russman :p
  • ken brydson
    ken brydson Posts: 8,996
    txcoastal1 wrote: »
    lightman1 wrote: »
    txcoastal1 wrote: »
    Have him put out the fire...
  • lightman1
    Cripes! It is right chilly in Des Moines. Wish I had a tube pre amp to warm me up.
    mhardy6647 Posts: 34,982
    edited March 2016
    The aboriginal Australians used to cuddle up with their vacuum tube amplifiers on cold nights. In New England, tonight may be what they would have called a "Monaural Single-Ended Direct Heated Triode Night"...
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    I have their album!
    edited March 2016
    Prof, Irwin Corey - my hero!
    Jeepers, apparently he is still alive... and 101 years old.
    https://en.wikipedia.org/wiki/Irwin_Corey
  • BlueMDPicker
    Yep, and enjoying himself.....MY hero!
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2016
    See Benchmark Media's white paper on PROPER implementation of digital volume control. All of the DAC2's use "HGC" (Hybrid Gain Control) 32bit volume control and they test & measure superbly with none of the shortcomings of analog controls.
    Having said that, there are older implementations that can be detrimental to sound quality---but it depends on specific design.
  • mikeyb128
    mikeyb128 Posts: 2,885
    steveinaz wrote: »
    I was going to bring this up as well. The benchmark is one sweet all in one unit.
    2 channel:
    Theater:
  • steveinaz
    The one feature that I really like on the BM DAC2 is rarely talked about; the additional dynamic headroom circuitry that makes overly "baked" CD's sound somewhat more listenable. CD's that suffer from the loudness wars brickwalling sound smoother and less harsh. I don't know how it works, but I have noted improvement in a number of hot CD's.
  • Realistic
    Realistic Posts: 355
    Russ any updates on your preamp quest?
  • lightman1
    Not yet Bob. Still in Iowa. Kinda put that on the back burner until I get back home. Still kicking some tires though.
  • lightman1
    nbrowser wrote: »
    lightman1 wrote: »
    What did the tires ever do to you? Poor tires :(
    :D Good one Ken.
  • Realistic
    Russ what is up with the pre hunt? Don't forget to update.
  • lightman1
    Hey Bob! I had haul booty out to Iowa earlier than expected, BUT....been hanging out at Steve's @gudnoyez house. And listening to the Vincent has whetted the whistle in the SQ search. Smooth as silk.
    When (if) I get back to NC, that one is rated high on the list. Howz the P5 treating you?
  • littlewoodboats
    littlewoodboats Posts: 823
    edited March 2016
    This is not playing in the same league as some of the options given but for a little less than a grand you could find a clean Adcom GFP-750 then send it to Big Sky Audio for a "best of everything" restoration/upgrade.
    Rick's work would make it easy to sell if you did not like the result.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I still say the primaluna premium preamplifier, I have the cary slp05 too and they are close in performace but not in price.
  • lightman1
    edited March 2016
    Well then, tell me what you hear pfb....
    tonyb Posts: 33,072
    The Primaluna has only about 10-12 db of gain, so a speaker with higher efficiency may be in order to pair it with. Not sure what yours are Russ.
    Too bad your on the road, you could have given the Rhumba a dance. I know you'd like that puppy.
  • polkfarmboy
    lightman1 wrote: »
    Well assuming the cables are slightly above average to hook up the pre and you have a good source my findings should mirror what many hear. The primaluna has a dead silent blacker than black background with nothing bloated or overly tubey about the bass. The bass is tight with amazing control but the clarity of the high end is super transparent. When you hear vocals they just come through with dynamic punch leaving almost nothing out. The tone of the vocals really digs you deep in to not only how an artist is sounding but bringing you a step closer to how they are feeling, thats what makes this a special preamp for me out of the many I have been through.
  • lightman1
    tonyb wrote: »
    Emerald Physics CS2p open baffle. 93db IIRC.
    Yep. Reading all the glowing reviews about the Rhumba has me thinking. Still on the pricey side, but maybe swing it one day.
  • lightman1
    I can dig it. I've owned a couple of Adcom pre's. Bang for the buck good sound. And I did not know about the upgrades. Thanks for that little nugget!
