RD-0194/ SRS 2.3 (sl2000) upgrade
glnordeen
I ordered 6 RD0194 to upgrade the SL2000's in my SRS 2.3's. They ring. It's not just one. I've swapped back and the ringing disappears. It's frequency specific. So far it's Dire Straits - Telegraph Road, and also Mannheim Steam Roller - The Holly and the Ivy. I'm extremely disappointed as this is the direct replacement speaker. The problem is, one of the original Sl-2000's is dead. It just stopped working, and shows open when I took my VOM Meter to it. That's what prompted the upgrade. You can't just change one given the age of the others and the difference there would be. Is this common or is it something else?
Answers
Check with @KennethSwauger
I have had 2 out of 6 that resonate badly but to far to send back from Australia....
OP, you did let them burn in for a few days first before cranking it, yes?Political Correctness'.........defined
President of Club Polk -
yes.
I waited 3 weeks. At that point I went with the assumption one or both were flawed even though they were new. Polk sent me replacements right away. I put the new ones as soon as I got them and there was an immediate change for the better with only a slight ringing at higher levels. After a couple of days it's been perfect and all perform excellent.
Nice,,i have just ordered 8 for a second set of sda srs, It would be nice if i could receive another 2 to replace the ones i received earlier that resonated badly,I will try notifying Polk via the COY who purchased and forwarded them for me!
I have to date , purchased a total of 26 x rdo-194's in the last 2 yrs.
Watch this space : )Post edited by ptrooper on -
4 days Three emails to customer support regarding the faulty rdo-194's and no response!
Call don't email.4 days Three emails to customer support regarding the faulty rdo-194's and no response!
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Call them. That's what I did, and they got right on it.
Cheers,I am in Western Australia. I will get onto it!
