Started the surgery on the 2.3TLs -plus a wiring question
Started the work tonight on my 2.3TL's- and pretty quickly made a mistake in my note taking but already saved by a sticky thread.
Items I'm doing:
1. secure magnets on drivers with loctite power grab all purpose
2. Drill and install set of Larry's Rings (Thanks Larry!)
3. Replace tweeters with 6 new RDO 198s I received last month
4. Install refreshed crossovers that David Shirly / DHS speaker service rebuilt for me that look awesome and should sound even better
So-- I was meticulous about labeling the speakers and labeling the wiring harness, but I made a mistake on the right speaker. I assumed the wires were keyed like the tweeters and so I did not note which color wire (black or white) went to the 'red dot' terminal on the drivers. The 'red dot' being placed on the left terminal when looking at the speaker from the front-- see pictures below. I caught my mistake 2 drivers in on the left speaker and started then noting the wire position.
What I recorded on the left speaker is that the of the two top drivers on the column of four drivers were wired black wire-to-red-dot-terminal (and therefore white wire to the right terminal). On the column of only 2 drivers, both had the blue wire going to the red dot/left and the green wire going to the right terminal. I did not capture wiring position of the bottom two drivers of the 4-driver column.
Can someone please confirm that:
1. On the left speaker, the bottom two drivers of the 4 driver column should be wired black wire to red dot/left terminal? Or does one or two of these reverse polarity for the SDA effect?
2. On right speaker, the 4 drivers column should all be wired black-wire-to-red dot/left terminal?
3. On right speaker, that the 2 drivers column should be wired blue wire-to-red dot/left terminal?
I found these schematics in the sticky section, think they answer my questions.
Thanks for your help. Feel pretty foolish given how much time I've planned this work.
Items I'm doing:
Post edited by waxman on
White or green are always negative.
That said, the diagram above for the right channel has the color positions reversed. Black or blue will be on the left side of the driver. White or green on the right side as you look at the speaker.
Do yourself a huge favor, install Blackhole 5 while you have them open.
So-- that's a pretty serious error in the schematics then. What it lists for the left channel is what I saw when I finally remembered to start taking notes, but I have zero baseline for the right channel, and now I have the most senior member of the forum disagreeing with engineering drawings as drawn by Rick Schimpf and signed by both a QA and Engineering approver back in 1989. Hard to swallow that either of you are wrong.
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
Think about it. The red dot is on what side of a properly installed driver? The drawings for the 2B and 1.2TL right channel are the same way. In the end the position marked on the drawings doesn't matter, what color is positive or negative does.
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Hi Mike, I've got a set of stock SRS 2's with the 1986 config- blade/blade interconnect that are in service until my 2.3TL's are ready to sing. I'm curious too- I expect there to be a lot of difference but won't be able to necessarily attribute them to any one change- the new RDO198s, Larry's rings, rebuilt crossovers with sonic caps, and new (to me) amp in bi-amp configuration delivering more power (sunfire in place of my carver tfm35) all are incrementally better than the SRS 2's in all areas, so hopefully the bump will be noticeable. If not, I spent a lot of money and time for nothin'
By coincidence I am going to pick up my 2.3TL's this Sunday so I know how you feel.
-Already ordered Larry's rings and 198 tweeters (thanks Larry).
-Got plenty of Dynamat Extreme and Powergrab for the drivers and any leaks in the cabinets.
-Got plenty of Armacell for gaskets.
-I plan to secure the end cap hardware with a gasket, flatwasher and lockwasher (thanks F1).
-Later I plan to swap out the x-overs with a set of gimpods boards with all new components.
-I plan to change the sub-base inductor to a lower DCR.
-While I am inside I plan to measure the wiring harness and document for future upgrade.
-I plan to upgrade the binding posts, IC cable and connectors.
-At some time I will upgrade the spikes.
Down the rabbit hole I go.
Have fun! I know I am
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Polk 1.2tl's Fully modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Marantz UD 7007
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups Polk Monitor 5 peerless,2.3tl,Polk Crs+ pin/blade with stands.McCormack Dna 0.5 Deluxe,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
You can cross that one off your list.
Hi F1nut, I appreciate your help. From your comment, you believe the right thing to do is to put the black wire on the red dot (left terminal when looking from top) for both the right and left channel drivers, end of story. That's my current course of action.
The think about it part- well, I did. Perhaps I was overthinking it, but the speaker doesn't determine the polarity of the signal, that's coming from the posts/crossover, so the way I read the schematic is that the black is still carrying the + polarity and the white is carrying the - polarity, and that you happen to connect them on swapped sides of the drivers (which carries no intrinsic charge) depending on if the driver is on the left vs. the right channel. If this was the case, you and the schematic would both be right- black wire is always +, etc.
My request to dkfreebird or machone when you get yours- if you have few minutes, I'd appreciate it if you'd pull a driver on your 4-stack from the right channel to confirm that the black wire does in fact go to the red dot/left terminal. That validation combined with F1Nut's recommendation would give me a warm fuzzy
It's low on the priority list. Good to have around if needed.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Marantz UD 7007
Pangea PC
Gotta disagree Mr. President, Armacel is the best stuff going for replacing the stock gaskets.
“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell
“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
understood- case closed. thank you!
IF they are damaged and need replacing.
For comparison, on the driver rings the barrels are still recessed in the lip so I will be able to easily get the airtight seal.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I am going on a road trip tomorrow to pick up my 2.3TL's. From looking at photos I see that they have spikes installed. The button feet are probably long lost and I was wondering what the thread size is so I can fabricate something to use to help move them around until I find the best location and reinstall spikes.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8 (x2)
Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
1KVA Dreadnought
Marantz SA 8005
Sony PS4
