Driver/Speaker rings for your vintage Polk SDA's Monitors..
One question,on the 1.2tls what is the best way to get the original inserts out to install the rings.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Received my box of rings tonight. Cool! Now I just need to tear into my "stock" speakers: 1. Glue the magnets on the MW's, 2. Dynamat Extreme the MW's and SW's, 3. Install replacement RD0-194's & RD0-198's (in proper models) and install rings at that time, 5. Spike them, 6. Send cross-overs to Dave to be rebuilt with Gimpod boards etc. Should have it all done by 2018. Thanks again Larry! A great product.
dkfreebird wrote: »One question,on the 1.2tls what is the best way to get the original inserts out to install the rings.
they screw out with an Allen Wrench, if you look at the hole you will notice it..
Thanks Larry I will go check that out.One less thing to do when they get here.
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
I received mine yesterday. I appreciate the quick service.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Looks like a lot of you guys received them yesterday, considering they left Monday UPS ship these pretty fast..
I got mine, too. Will commence to cutting and grinding to fit these idiotic 3.1 cabinets... I might end up cutting them like the tweeter brackets.
Got mine too, thanks a lot Larry!
Mine arrived today. Thank you!ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Now I can officially say, payment sent. Thank you Larry!
Ha, no worries, I knew you would that's why I just shipped it. I will let you know when the payment gets here...
Got mine today along with my sheet of blackhole 5.Time to get the cabinets ready for the new crossovers.Thanks again Larry!2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Hi Larry- received mine too! Thanks again!
I received mine as well, thanks a lot!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Got mine yesterday.
Thank you very much Larry! -
Is it too late to get in on the rings Larry? If not, I need a set for my SDA 1C's please. Thanks Larry.
Got mine! Thanks Larry!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Rings came in today. Thank you Larry for putting this together.Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
I may have missed it, were there any discussions if Larry was going to make any tweeter brackets? Thanks.
Thanks Larry. Got home to a package on doorstep. Merry ChrismasRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
aprazer402 wrote: »I may have missed it, were there any discussions if Larry was going to make any tweeter brackets? Thanks.
I still have a few from the last time I ran tweeter brackets, how many do you need?
I did take care of the guys that specifically asked for them..
I also have about 5 sets of crossover rings for the BIG BOYS SRS/1.2/1.2TL..
I also have about 6-8 sets of Binding Post rings..
If any of you want to clear any of these out for me just let me know..
Larry,
Add two sets of binding post rings to my crossover ring order.
Robert -
Larry, how much do the binding post rings run? I may need two to three sets.
Do you have 4 Tweeter brackets left over along with the hardware and template if so I could use them. Do I need binding post rings not sure.Home Theater
PM sent requesting tweeter brackets for a set of Monitor 7s with Peerless if you have any extras. Thanks!
Larry,
I would like a pair of the tweeter brackets for my pair of 3.1 TLs. Is this still possible. Please PM the price.
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
18 tweeter brackets sets, (8 for 1.2TL) (6 for 2.3) (4 for 1C). Thanks, Larry, PM me cost.
I am interested in buying a ring set and tweeter brackets for my 2.3TLs please. Please pm me total cost and availability. Thanks.
also want a ring set for my SDA CRS and tweeter brackets. -
Larry, I'll take a pair crossover rings for the BIG BOYS (SRS). PM sent.Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Ah the snow has kept me busy here, I will update you guys tomorrow what I can and or can't do...
Thanks!! -
I would like a set of the crossover rings for the 1.2s please. Received the previous order, Thanks!Vinyl, the final frontier...
