This joint needs some more vintage hifi
  • sucks2beme
    sucks2beme Posts: 5,558
    The HK citation 16 still eludes me. Someday one will be mine!
  • [Deleted User]
    saved from the scrap heap of time. Wood sides. Nikko trm-50 1969? pre/amplifier
    anyone got info on this beast?
  • Wardsweb
    Wardsweb Posts: 905
    Here is an oldie but goodie. Phase Linear 700B
  • Wardsweb
    Wardsweb Posts: 905
    Pioneer HPM-200
  • Wardsweb
    Wardsweb Posts: 905
    SAE C101 and Pioneer CT-F950
  • Wardsweb
    Wardsweb Posts: 905
    Carver Silver 7t
    mhardy6647 Posts: 33,070
    OK - Mr. Ward wins. He always does ;- )
    Happy Thanksgiving, sir!
  • Polkie2009
    Polkie2009 Posts: 3,834
    Wardsweb wrote: »
    That Pioneer looks solid! Nice units , are they from the late 80's?
  • Wardsweb
    Wardsweb Posts: 905
    Polkie2009 wrote: »
    The Pioneer is from 1979 and the SAE is from 1985.
  • Polkie2009
    These units are over 30 and 35 years old and still working? That's Japanese integrity right there! :)
  • Wardsweb
    Wardsweb Posts: 905
    Polkie2009 wrote: »
    Well they work with new belts. I haven't seen any originals that the belts were still good on. Rubber dries out and cracks or reverts back to its natural state and melts into goo.
  • Polkie2009
    I agree on the belts, but I'm amazed the circuitry is hanging in there. :)
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited November 2015
    Bing tells me after much searching this is circa 1969, 17Watts and sold for $89.00
    bucks or so. You push in the bass button for a rumble filter and the treble for a
    "scratch" filter.
    I'm curious on how to use it as a pre? Should have taken
    a pick of the back...
    your best bet for arcane Japanese vintage hifi is always www.audio-heritage.jp There is also a transliterated version, too, but I cannot remember the URL at the moment (nor, apparently, can Google).
    http://www.audio-heritage.jp/NIKKO/amp/trm-50.html
    "Pre-amp/amplifier" may just be a moniker to indicate it's an integrated amp (and not just a preamp)? If it's not just that, there should be "pre out"/"main in" jacks on the back apron, I would think.
    Nikko stuff was never common nor popular in Maryland in the olden days, so I am quite unfamiliar with it. If nothing else, they made some fine tuners (their "Gamma" tuners).
  • [Deleted User]
    Thanks MHardy. Makes sense. I kept looking for a "pre-out" type RCA
    without luck. OTOH, I read something that said the signal is split or something.
    I'll try to get a pick of the back.
  • [Deleted User]
    I found this easy to translate:
    "Preamplifier / Amplifier, which turned into all-IC other than the world's first power transistor.
    The output circuit I have adopted a low-distortion epitaxial planar silicon power transistor NIKKO developed.
    In addition, IC for the main amplifier driver (thick film integrated circuit), and those incorporating a resistor and a capacitor and four transistors of 13 points, has won the excellent characteristics and high reliability.
    The equalizer stage of a preamplifier part, it is possible to suppress particular, has adopted the NIKKO audio linear IC, which was developed for the equalizer amplifier, it is possible to acquire a high characteristic, the ± 0.2% rate of change at -20 ℃ ~ + 85 ℃ It has been.
    The tone control part has adopted two of NIKKO audio linear IC, thus ensuring excellent characteristics.
    The power supply voltage, temperature compensation uses the compensation Ted varistor.
    We have adopted the circuit breaker for the audio to the protection circuit.
    The NW-type circuit protector UL standard (USA), has been approved by the CSA standard (CANADA), we have won high reliability.
    It is the design that was unified in FM / AM tuner FAM-14 and the same size."
    :using google translate. Thanks!
  • [Deleted User]
    and here are the specs: Thanks so much!
    Model Integrated Amplifier
    Music power 52W (4Ω)
    51W (8Ω)
    Effective output piece-channel operation: 18.5W / 18.5W (8Ω)
    Both channel operation: 17W + 17W (8Ω)
    Frequency characteristic (IHF) Main Input: 10Hz ~ 70kHz ± 1.0dB
    Aux Input: 20Hz ~ 30kHz ± 1.0dB
    Power response (IHF) 20Hz ~ 30kHz
    Distortion of 0.6% or less (at the time of an effective output)
    Channel separation 50dB or more
    Input sensitivity / impedance Phono MAG: 2.4mV / 100kΩ
    Phono CER: 80mV / 100kΩ
    Tuner, Aux, Tape: 300mV / 100kΩ
    Tape (DIN): 300mV / 100kΩ
    Recording output DIN: 300mV
    S / N ratio Phono MAG: -65dB
    Tuner, Aux, Tape: -75dB
    Tone Control Bass: ± 12dB (70Hz)
    Treble: ± 12dB (10kHz)
    Load impedance 4Ω ~ 16Ω
    High filter (scratch) 10kHz, -10dB
    Low filter (rumble) 25Hz, -10dB
    Use semiconductor IC: 6 pieces
    Transistor: four
    Diode: two
    Varistor: four
    Power AC100V / 117V, 50 / 60Hz
    Dimensions Width 330 × height 105 × depth 260mm
    Weight 5.2kg
    oh, the "English" morph of that site is www.audio-database.com
    I really like www.audio-heritage.jp although it's kind of frustrating to look at and to see some of the Japanese hardware that was rarely if ever exported because (I suppose) that the marketing savvy of the Japanese companies figured the TransAm drivin', Pabts-swillin', polyester-wearin' Amurricans would never be interested in it.
    :-P
    You know, stuff like this:
  • [Deleted User]
    the top speak caught my eye right away off their site.
    (get it, eye...site) :D
  • boston1450
    boston1450 Posts: 7,477
    edited December 2015
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    ^ Randy- I've had several of those SL-23's pass thru my collection. Nice little starter tables that usually only require a new belt and you are in business. Sounds good with the newer Shure M97xe cart.
  • boston1450
    TNHNDYMAN wrote: »
    Its got the Santon681EEE cart & stylus. Not sure if that stock/original. Cheap tt's do the job pretty good. Bedroom Carver set up.
    Randy/Maine
  • pumpkinman
    pumpkinman Posts: 9,524
    New to the pumpkin speaker stable. DCM Time Frame 600's
    Because I am The Pumpkinking
    Workin' on a pair of Mirage L-750 loudspeakers. These actually belong to the guy who built our house :- ) A little quid quo pro.
    Left:
    24140001459_117f162f21_b.jpg001 by Mark Hardy, on Flickr
    Right (see below for info on the MR):
    24481568286_1f5be1c53d_b.jpg004 by Mark Hardy, on Flickr
    One of the midrange drivers is borked. Temporarily, I've swapped in one of the fine old 4-1/2" pincushion frame CTS drivers. The latter may be familiar to some of you from their 1970s appearances in Polk Audio Model Nine and Mini-Monitor loudspeakers :- )
    The borked MR (not a CTS):
    24507758715_0bd2b615a6_b.jpg006 by Mark Hardy, on Flickr
    The right speaker with a CTS temporarily installed. The CTS is actually a bit more sensitive than the original MR, so the midrange is noticeably more forward -- heh, more Altec like ;- ) -- with the CTS driver compared to the proper driver.
    24399465772_d56636fae3_b.jpg008 by Mark Hardy, on Flickr
  • aprazer402
    aprazer402 Posts: 3,104
    This item is not in Wardsweb or many others league. Very nice gear guys! I've had this one for many years. A Magnovox FD-2040, Made in Belgium, Philips CD-1 transport, I think a 14 bit DAC, metal tray (slow and clunky), RCA interconnects are hardwired (and very short). Very heavy unit compared to todays players. Still sounds good.
    I am really, truly trying to de-clutter some at the old manse...
    to that end, the refoaming project mentioned above has got me on a refoaming jag.
    Did a pair of (Recoton-era) Advent Baby II over the weekend. Turned out fine, cute speakers but a little treble-challenged. OK, bass-challenged too. Midrange is surprisingly good, though. I am gonna invest in a pair of decent, modern XO capacitors for 'em.
    But, ne'ermind. Yesterday & today, I refoamed a pair of (also Recoton-era) Advent Legacy II. Pretty uninspiring cosmetically but fairly well built -- and well worth the effort. Kind of wooly/blurry down on the floor, but raised up a bit... they're doing quite nicely, thank you very much. Listening to Black Crowes' first album as I type this (via a pretty nice hk "twin-power" amplifier that happened to also be taking up some space here) and they're very toe-tappingly gettin' the job done.
    three bad photos = one decent one? ;- )
    24550058801_ed3af1a91b_b.jpg004 by Mark Hardy, on Flickr
    24264538669_6e340cbdb5_b.jpg002 by Mark Hardy, on Flickr
    24336720260_8c255d6e74_b.jpg001 by Mark Hardy, on Flickr
    edited January 2016
    And all this time I thought you were an Irish Catholic. When did the Presbyterian conversion occur? lol
    Legacy speakers were very popular back in the day, we would have considered buying a pair if we could have afforded them, even though they were not that expensive for ordinary mortals! But, when your diet consisted of tuna, canned peas and pasta, there were obviously budgetary constraints!
    German-English Lutheran...
    16139344795_1a333d818c_b.jpgcamera collection2 by Mark Hardy, on Flickr
    Note the two wind-up Martys on the shelf in the photo above :-p
