Driver/Speaker rings for your vintage Polk SDA's Monitors..
I honestly didn't think there would be this many of you wanting these, it will take me a couple weeks to get everything together...
Thanks!! -
Larry: I appreciate it, but no need to hurry my order, take your time if need be, the end of the year would be soon enough for me. Thanks.
So this is about 29 sets, I'm going to cut if off at this point, and focus on the list thus far, I'm sure I will run a few extra, but this will keep me busy for a few...
Hey Larry ...I would like 2 complete sets , one for SRS's and 1 for 2.3's please ..Can you include the front plate and rear speaker con plates?
Cheers -
In for a set for CRS+ please.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Any chance we will see the crossover plate ring as well? I could use a pair of those.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
If you have extra, I need a set for my Monitor 7's. Thanks, Please.....no rush LarryMain Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
nooshinjohn wrote: »Any chance we will see the crossover plate ring as well? I could use a pair of those.
I could three sets of these
Thanks!!
You can deliver mine last, they will sit here for quite awhile before I get started with them anyway.
All rings are off the laser, waiting for the 8-32 stand offs to come in so I can hardware them..
Those wanting the crossover plate rings for the big boys, I will update if I can find the program, I don't want to have to make another one, I'm sure it's somewhere in my files... -
If you have extra sets I would like one for the 1.2tl's Thanks2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Thanks for the news on the crossover plate rings. I'll keep my fingers crossed.
if there are enough pieces id like to purchase a set for my sda 1c.System Details:
Marantz SR 5010, Rega RP1, Marantz CD 5004, Denon DRR-680, Carver M-4.0t
Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i -
I may be interested as well.Vinyl, the final frontier...
Hi, thanks for making this available! Please count me in for a crs+ set.
It just got real....
I still have to count out the screws, I will start pm'ing you guys in the next day or two..
D@mn dude what did you do,....hang out at the shop T-Giving weekend
Nice2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Thanks Larry. lots of work there - wow that looks coolRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
neato. thank you Larry!
I'm not in on this but so impressed with the amount of work put into it. Kudos man... -
Impressive.....big thumbs up to you for doing this.
Many thanks.
Larry,
I have a new set of 1c's to go with my 2b's and 1a's. I want to compare your rings to hurricane nuts. Logic tells me the rings are the best.
I want a set for my SDA 1C's if you have extras or make more.
Harry Jones
Marietta GA"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
That's a sexy pile of steel Larry - thanks for making another run!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Your a Jett Larry
Most of you should have received PM's, I will start with these orders and move down the line..
Thank you guys, and Happy Holidays!!!! -
PP sent, thank you so much Larry!
I sent my payment also thank you sir!!!!Home Theater
PP sent Larry, thank you again!
If I don't respond right back, I'm boxing these up..
PP sent,
Thanks2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
