SF Stradivari: the eagle has landed!!!
13
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2015
    He has the same problem with the Strads as with the Diamonds. He has not addressed the audio foundation (power, cables, and vibration reduction/elimination). Without a good foundation, the best gear in the world will be lackluster.
  • megasat16
    megasat16 Posts: 3,521
    edited August 2015
    I agree that the 211FE needs to go. I have a friend with 211AE (a bit older than 211FE you have but almost identical) based on Push-Pull 845 so I have heard it before. We had a shootout for 845 based amps and no doubt the SET 845 wins very instances we turned it on. So, go SET if you don't need a lot of power or don't listen to very loud. 845 SET will give you about 20W of real Class A power in oppose to the 110W in your Cary. You may also want to look into 211 tubes that has a more lush top end sounds. I have two SETS amps which both can use 211 and 845 tubes.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • megasat16
    In order to get 22W, you need to run the 845 about 1000V minimum. You could get about 25W if running them at 1200V. You can get more than 30W if running them at 1400V but extremely dangerous and goes to the A2 region. And it's a chance the tube will red plate at above 1250V. Old RCA tubes may be OK to run at 1500V but forget about if you have the new Chinese tubes. Graphite plate versions has 100W power dissipation but most metal plate versions are only rated to 75W dissipation. Actual output power is about 1/4 of that for Class A SET amps.
  • Joey_V
    Joey_V Posts: 8,603
    I am really thinking of going Cary 845 set... It is 50w of pure class a power.
    If only someone nearby had a set... Hmmmm?
  • Joey_V
    Joey_V Posts: 8,603
    Agenda for rest of the year:
    1. Upgrade power amps
    2. Set up rack
    3. P10 power conditioner
    4. Hang up the panels
    Next year
    1. Source upgrade
  • Joey_V
    Joey_V Posts: 8,603
    Here I'll let u look at it skip
    http://www.caryaudio.com/products/cad-805ae/
  • haimoc
    haimoc Posts: 1,031
    I am not sure how tube amps could drive these beautiful speakers to their full potential.
  • megasat16
    Be weary of the SET amps that goes into A2. It'll usually result in higher distortion at both and low volume. If you can live with low to moderate power, a nice SET with 20W or less will do the magic. If not, look for the Pass SS Class A Amps.
  • ken brydson
    ken brydson Posts: 9,047
    Gawd I'm glad to be relatively poor....
  • Joey_V
    Joey_V Posts: 8,603
    Alright so I made some positive movement in the right direction. Pulled out 6" more from Back wall , aggressive toe in.
    Sounds good ati Mid to high volumes.
    I think I realize that strads don't do low volume well. But amazing when the 802
    Diamonds would give up... The strads keep pushing.
    I need a stronger amp.
    Even these large Cary. 211fe isn't enough.
  • Nightfall
    Nightfall Posts: 10,083
    edited September 2015
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,103
    Having heard SF's driven with MF, you need a big balls Musical Fidelity amp. Heavenly even at low volume.
    Congrats on the speakers, beautiful.
    Dare I say.....that room looks a tad smallish for those speaks. Agree with the bass build up in the corners. Also agree you need some SS amplification with balls the size of Mt. Rushmore. Dang though, one of the most beautiful speakers on the planet.
    Joey,
    Remove all those panels from the room and see how it sounds. Then add some slowly to the room. Almost seems like you have too much, over dampening the sound.
  • I agree with Skip bring them in away from the side walls, but also, I would try not toeing them in so much. I little reflection off the side walls goes a long ways in regards to presence and realism, especially at lower volumes.
    Yep, also agree on bringing them in from the side walls and reducing toe in. We don't have a good grasp on the room or distance to his seating position either.
    The SF are a warmer sounding speaker, the Cary gear is warmer sounding gear, I would think they'd perform better in a more lively room, hence my suggestion to remove those panels. The carpeting is gonna soak up a lot anyway too. In order to get some low volume detail, your gonna need an amp with balls and some reflections in the room...not less.
  • Joey_V
    Joey_V Posts: 8,603
    Yeah thanks for the advise everyone.
    Several things to keep in mind:
    1. The side interaction of the Strads are minimal compared to an regular baffle speaker, that's the beauty of it.
    2. There might be a little too much paneling, so I may have to trim that down and bring some to the game room, however... will play with that some more later.
    3. I had it too close to the back wall at some point and it was just way too much bass... now I moved it about 6" forward and it sounds great.
    At mid to high volumes, the speaker really comes to its own. Far better delivery than the 802 Diamonds.
    The 802 Diamonds are better at low volume delivery however.
    Now, I am trying to change the amp... but the market is dry.. meaning that if I try to put my 211FE for sale, there might not be any bites for a while, at least until the winter comes.
    I am thinking:
    Classe M600
    Pass XA100.5
    Parasound JC1
    In that order.
    Working with sellers for each as we speak.
  • Joey_V
    Joey_V Posts: 8,603
    tonyb wrote: »
    Joey,
    Dare I say I need a new room?? Bahahahaha
  • Joey_V
    Joey_V Posts: 8,603
    DSkip wrote: »
    Joey, get them out into the room more and off those side walls. Try not to have them equidistant from the side and back wall. If you do that (looks like you have it like that right now), you are going to get bass build-up in the corners like crazy. That is going to destroy anything good those speakers can do. Move those amps in front of the preamp to give you some more room.
    Good idea... I don't think they are equidistant. I am about 30 inches from the back wall at the one corner. From the side wall, I think (not sure) 16".
  • Joey_V
    Joey_V Posts: 8,603
    I can't get rid of the 802 Diamonds.... I love them too much.
    Damn it!!!!
    There goes the Boulder amp upgrade.
  • Joey_V
    Joey_V Posts: 8,603
    DSkip wrote: »
    Joey, measure not from the cabinet but from those rear ports. Those are what will do the damage as they are what throw all that energy into the corners. The middle of the cabinet looks roughly equidistant to me.
    Gotcha
  • Joey_V wrote: »
    tonyb wrote: »
    Joey,
    Why limit it to just a ROOM...
    A baller like you... you need a Audio HOUSE!!!!!!!
    Just say it's an "investment property"... Gut it entirely and rebuild it to make it into nothing but audio rooms.... then ensure its got plumbing, a nice couch (for the dog house days) and a kitchen....
    Joey_V wrote: »
    Don't count it out yet. Sell something.....like those shorts. The Smithsonian pays big bucks for antiques.
  • BlueFox
    Experiment with the panels on the back wall. Looks like overkill at the moment. As mentioned before, your power and cabling is restricting the potential of your gear.
  • Joey_V
    Joey_V Posts: 8,603
    BlueFox wrote: »
    Bud -
    I will.
    On a side note, power and cabling... in time. can't do it all at once. If we were so lucky that we could just dump a bunch of money on the best of everything all at once, then there would be no need for discussion. The room and the system top to bottom would be perfect. System in evolution is the best way to put it.
    Right now, when I turn the system up... it's getting better. Still low level detail requires improvement... in time, I think I'll get there. These speakers are balanced from top to bottom.
  • tonyb wrote: »
    Joey_V wrote: »
    A comedian too! Made me chuckle.
  • Joey_V
    Joey_V Posts: 8,603
    Alright... We got new amps coming as of today. Interesting how my wife was in on the transaction conversation.
    I was driving and talking over the car speakers...
    She's like "what did you buy now???"
  • GlennDog
    GlennDog Posts: 3,158
    "BlueFox wrote: »
    P10, my good man . . . P10
    pm sending soon
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • marvda1
    marvda1 Posts: 4,964
    so, what amps did you buy?
    Puritan PSM156
  • BlueFox
    I considered both models of the Classe 600 amps, the aesthetic design, and the HT industrial design. My biggest concern was since I listen to classical string quartets at low volume at night I would hear the fan. I checked on multiple forums about this and some could not hear them, and some could. I am very sensitive to unwanted noise, and I even moved my refrigerator to the garage to eliminate its noise.
