Polk Audio LSi M 707
hi everyone, what do you all feel about the lsim 707 is it worth 4k a pair? I own the rti 150 and sda srs 3.1tl loudspeakers. do you feel if I buy the 707, the yamaha a-s 801 and audio quest rocket 33 would run the 707's very well? a sales guy at polk audio said he would put up 707's against any speaker costing up to 20k, do you think it is true, or a sales pitch? thank you, dana
    F1nut Posts: 51,894
    The 707 is a good speaker, but I like the 705 better. I don't know anything about your Yamaha, so can't comment.
  • yamaha is a intergated amp, audio quest is speaker cable
  • Nightfall
    Nightfall Posts: 10,083
    edited July 2015
    He means he has no personal experience with the integrated you are talking about, not that he doesn't know what it is.
    Have you upgraded your 3.1TL's? That's the route I would take.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,894
    Thank you Nightfall.
  • yes new sl 3000 tweeters
  • Nightfall
    edited July 2015
    SL3000's or RDO-198's? What about your crossovers, original caps? Mass loaded midwoofer baskets? Blackhole 5? How about room treatments?
    You could use an amplifier. Your integrated, though nice, doesn't have enough power to really get the most out of what you have.
    afterburnt wrote: »
    I think the Polk rep is stretching a bit claiming they'll compete with speakers up to 20k. They are a nice sounding speaker, just depends on your preferences on whether they are worth the 4k to you.
    Personally, if I had 4k to spend, I'd be looking at used or demo higher end speakers. New stuff loses it's value too quickly.
  • erniejade
    erniejade Posts: 6,321
    @F1nut why did you like the 705 better?
    To the op, check ebay for referb by Polk. You can save a good amount on a set.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I would go with the 705's and a nicer amp and pre. My experience with the 705's and the Parasound P5/A21 merits consideration.
    Garage | Polk Monitor 5B's
  • marvda1
    marvda1 Posts: 4,954
    you know what i think :)
    Puritan PSM156
  • so you all think the 705's are better than the 707's you would think that the 707's are better because it is there flagship model? yamaha a-s 801 integrated amp, and audio quest rocket 33 bi wiring speaker cable would run the 707's very well. what do you all think? thank you, dana
  • Nightfall wrote: »
    hi, just new RD0198-1 bought the 3.1tl in 1991. everything else is original.
    so you think the yamaha a-s801 integrated amp would run lsim 707? what do you thing?
  • dhart86
    dhart86 Posts: 1,594
    Bro....I beleive the consensus is that the 705's are a more balanced speaker and unless you have a really big room, the 705 would bring more value. Like F-1nit said, I have no experience with your yamaha.....however, I have (2) sets of LSIM 705 speakers and they are an easy load to drive, nicely efficient. Your speaker cables should be fine.
    But since you keep inquiring about the 707's ....just wondering, did you already order a set?
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • no not yet mount vernon cherry they are waiting for some to come in polk says I get a 10% discount on the 707's instead of 4k they be $3600 good deal speakers and speaker cable covered but what do you think about pre amp or power amp to drive the 707's?
  • erniejade
    Referb from Polk on ebay they are 1300 ot 1399 each.
  • dhart86
    Most of the polk refurb's are basically new open box (barely a blemish if at all)
    Main Rig:
    Second Rig:
  • Nightfall
    edited July 2015
    dhart86 wrote: »
    Like F-1nit said
    :#:D
    afterburnt wrote: »
  • dhart86
    Nightfall wrote: »
    dhart86 wrote: »
    Like F-1nit said
    :#:D
    Oops.....
    Main Rig:
    Second Rig:
  • I think I will stick with the 707's thank you for your help out of the two the 707's are much better for me than the 705's because of the specs and my living room which is large do not measure the size I will run them with the Yamaha integrated amp 100 watts model # a-s 801 and the audio quest rocket 33 bi wiring speaker cable what do you think about bi wiring better than normal wiring is the sound better first time bi wiring the 707's
  • dlb68@live.com
    dlb68@live.com Posts: 16
    edited July 2015
    do you know where I can maybe purchase the sda srs 1.2 TL in mint condition
    I tried eBay anywhere else? These are my dream speakers!!!
    txcoastal1 Posts: 13,514
    Bi-wire is a debate...but if you are on the hunt for 1.2tl just get regular cables
  • what is the best integrated amp under $1500
  • What is the best speaker cable under $600
  • deronb1
    deronb1 Posts: 5,021
    100 wpc is not going to give you the headroom to maximize the 707s potential. You might as well get 703s and a good sub. Use 12 ga wire to jump the terminals in either case.
  • rikm
    rikm Posts: 23
    ...well I have a pair of 707's in a big room [25x25x12] and think you would be happy with them...and unless you are in a hurry to just get them, as was mentioned above, the Polk factory store on eBay is worth watching... stuff goes on sale there at random times and you can save more than the 10% you are hoping for...
  • PSOVLSK
    PSOVLSK Posts: 5,396
    Matter of opinion, but I'll throw out the best I've heard...Dayens Menuetto. AND, it mates very, very well with the LSiM series. http://forum.polkaudio.com/discussion/168143/results-integrated-shootout-with-lsim703#latest This would be a tough unit to beat for the price, period.
    Also a matter of opinion, but I (and others here) use Douglas Connection. douglasconnection.com
    Tons of choices in that price range, especially if you go used.
    F1nut Posts: 51,894
    I've heard all 3 models with various gear in various rooms, the 705 is the best sounding regardless of room size and is easier to drive. I'll take a guess that all you're looking at is the bass spec because really that's the only difference. That would be a mistake. It takes power to get good bass and your Yamaha isn't up for driving the 707. However, it will do a decent job with the 705.
    So, $1500.00 isn't going to get you an integrated with much, if any more power than you have already. Take that along with the $600.00 cable money and put it towards some really good cables.
    What is your source or sources?
    With all due respect PSOVLSK, the suggestion of the 60 wpc Dayens, while seemly ok for the 703 is not the best one for either the 705 or 707.
    F1nut Posts: 51,894
    I have another question for you, dlb68@live.com. Since you already have 3.1TL's, why are you looking to buy other speakers? Why not upgrade the crossovers and all the other SDA tweaks? You'd be amazed at the improvement.
  • Nightfall
    From what I've read so far in this thread I gather that he's looking for confirmation bias on the 707's.
    afterburnt wrote: »
  • rikm
    rikm Posts: 23
    ...guess I would agree with the "more power for the 707's" argument and am not familiar with Yamaha, but it's likely they have a power amp that would sync up with the integrated he has and bi-amp the 707's...that would probably yield something more substantive than bi-wire on the integrated alone...
