A Real SL 2000 Hack. Replace stock (burnt voice coils) with "silk diaphragm dome ".
VSAT88
Thought you all should see what I have been up to this time. Just wanted to see if I could do it. Until I get the replacement tweeters ( I have them on the way now) I decided to see if I could hack into the toasted SL 2000s I had. Well it worked, how well I don't really know yet. So far so good they actually sound better than I expected. I expected they would not work at all or would sound terrible and they don't. Either way these did not work at all and after this they do. There are just so many variables (as many as you can imagine) that there was almost no hope in getting them perfect at least in one try. It was worth $11.00 just to see what happened ! I have a lot of fun doing stuff like this. Inevitably I will try again with different domes another day, its just a matter of time. Who cares anyway, these are shop speakers and I have more on the way. Have fun with this one !
First I removed the silicon.
Took it all apart.
Cleaned the gap with masking tape.
De soldered the old wire.
Cleaned my fingertips and parts.
The old and new.
Test fit.
A small amount of glue.
Then I put it all back together and let it dry. And..Thanked my helper Hoo Doo !
As always, my disclaimer ..Do not attempt at home ! Thanks for looking !
Took it all apart.
The old and new.
Test fit.
I love stuff like that, thanks for posting it.Political Correctness'.........defined
President of Club Polk -
Nice, you converted the tweeter into a woof-er.Stan
Main 2ch:
HT:
Other stuff:
Nice, thanks for sharing. Do you have a link for where you purchased the silk diaphragm domes from?
http://www.ebay.com/itm/280913355718?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Cant beat that price. Quick shipping considering.
Item # Item: 280913355718..
Me too, gives me some ideas to play around with the blown SL-2000 I have sitting on top of a SDA around here....yeah it's been replaced!
Thank you. If you decide to do so great. If you dont I will give you my address and I will victimize another SL 2000.
How did you center the voice coils so they don't scrape the magnet/pole piece assembly?
Excellent job! I'm going to order a couple myself.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks for posting. Always had a vague idea of what's behind the dome."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Since Polk and Peerless were together for a while back in the day I never understood why Polk never incorporated the replaceable silk dome and voice coil that Peerless made and sold to many speaker makers. I used them and they were wonderful.
Trust me if I'd of seen these I would of tried it also ..great job. -
I'm thinking that the devil is in the details.
westmassguy wrote: »Excellent job! I'm going to order a couple myself.
Wow thanks ! And I agree. A lot of manufactures could sell a lot of parts if you were allowed to change out the dome to suit your personal taste. Kind of like ordering Bob Crites diaphragms for my Klipsch speakers. I think they sound much better than the factory ones and I am glad I did it !
Why not it was a fun project ! Thanks .
I ordered them. I've got a couple of paperweight SL2000s. I think I'll do an A/B with the RDO-194s, see how they stack up. Could be interesting.Home Theater/2 Channel:
I will say this, it may be my ears are better today than yesterday ( yes I do have some ringing in my ears) or that they have just started to "break in" but it seems as if every time I go back out to my shop they sound better. I have been letting them play as much as I can..
Mechanical break in is inherent for any driver with a flexible surround.
Very helpful to anyone trying to repair an SL2000, thanks for the post and great job!
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
What kind of glue did you use?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
This stuff called E 6000 but I would not use it again. Too tough to deal with (stringy) and would not stick as I wanted. I will use in in the area between the voice coil wires that go over to the speaker connectors on top though. Clear and works perfectly there. Please do not get me wrong, it is absolutely awesome on some materials just not this one. I emailed the diaphragm manufacturer (after I did the job, smart guy I am..) and they said the part was made of cloth. I do not think so. Seems like at least the outer ring is made of a very thin plastic. I am going to use regular 100% silicon next time unless someone here post back with a better glue.drumminman wrote: »What kind of glue did you use?
I would not use that to glue the diaphragm to the plastic bezel... when silicone cures it out-gases acetic acid which I've heard is not so good on electronics. I will state that it sure seems to me that is what Polk used and might be fine for the leeds to +/- but not the actual dome...maybe superglue?
I'm going to use my go-to glue, Aleen's Tacky Glue.Home Theater/2 Channel:
westmassguy wrote: »I think I'll do an A/B with the RDO-194s, see how they stack up. Could be interesting.
I'm looking forward to your comparison. I have a very nice pair of Monitor 10B's in storage because of the fatiguing sound of the SL2000s.
Great thread, pics and info.
Got few 2000's here and that looks like fun.
THANKS for the posting.
westmassguy wrote: »I'm going to use my go-to glue, Aleen's Tacky Glue.
I was thinking about that. I would like to know as well. I do not have any RDO-194 so please let us know if we can build some homemade ones !
I have been wanting to go buy some of that anyway so..away I go. I have an old dome and an old tweeter so I am going to do some experimentation with Superglue and Aleen's and see how I fair.
