2 channel rig finally set up again!
2
  • chumlie
    chumlie Posts: 8,658
    Looking good Paul.
  • hochpt21
    hochpt21 Posts: 5,423
    edited February 2016
    Digging up an old thread.
    Wife ok'd moving another IKEA shelf into the living room for albums.
    This was before. I do miss my 705's :(
    Here's how she looks now.
    2C65D4D8-D7A7-4A88-84E7-C83BA4A2A045_zps63rulzru.jpg?1455478894538&1455478895238&1455478903491&1455478907396
  • gce
    gce Posts: 2,158
    looks good and yes the IKEA shelf's are perfect for albums.
    Anaheim Hills CA,
    mhardy6647 Posts: 35,058
    Excellent. Thats it! I'm cleaning the mancave!!
    Manage your expectations.
    I cleaned mine -- but it still looks like a utility closet.
    EndersShadow Posts: 17,707
    Random thought... Can you turn those on their sides? Might look more symmetrical that way
  • marvda1
    marvda1 Posts: 4,952
    hochpt21 wrote: »
    you must try the straley interconnects.
    Puritan PSM156
    This may be an irrelevant or even pointless aside; my apologies if the poster of the photo already knows this OR if it has already come up in the thread.
    The Expedits (which those appear to be?) can be oriented either "portrait" or "landscape".
    but...
    there's a big but (not to be confused with a big bu t t)!
    The weight bearing shelves really need to be of a single piece if the load on them is heavy (e.g., LP rekkids). The 'square' Expedits can be assembled/employed either way, but the results of making the wrong choice are well documented -- and disastrous.
    http://thevinylanachronist.blogspot.com/2012/10/a-blog-i-wrote-some-time-ago-which-you.html
    687474703a2f2f6261726e61636c657363686f6963652e66696c65732e776f726470726573732e636f6d2f323031322f30362f6661696c2e6a7067
    I actually had one of my shelves oriented incorrectly when I disassembled, moved, and reassembled them at the new house in NH. Someone noticed it in a photo, mentioned it, and I remediated it PDQ. Whew.
    12038566264_287a884a17_b.jpgDSC_6224_oops by Mark Hardy, on Flickr
    ^^^ No. Wrong. Bad. :-P
    Again, my apologies if everyone knew all about this already (the "issue" has been around for a long time)!
    PS the Expedit was replaced by the Kallax, which is pretty darned similar to the originals.
    ^Yeah there is a thread where a guy reinforced his with some plywood he painted in the same color
  • hochpt21
    That was me :)
  • hochpt21
    It does look a little off symmetrically, but if you focus on the MF integrated, that is the center as far as critical listening is concerned. The rest is centered on the TV for the wife, and the shelves are just where they can be.
    I have the albums mostly on the top shelves so I don't have to bend down so far.
  • hochpt21
    @mhardy6647
    Yes I have seen those horrible pictures. I have them the correct way with some additional corner supports.
  • Mikey081057
    Mikey081057 Posts: 7,127
    hochpt21 wrote: »
    2 channel system #2 is also finally set up again :)
    My "man-room" had turned into a storage room and I cleaned and organized today.
    I also had a dedicated 20a circuit run here as well. I was getting horrible interfere from the light when it was on causing a buzz throughout the system.
    Now silent black background.
    I like that color
    Garage | Polk Monitor 5B's
    hochpt21 wrote: »
    Gotcha, for me the symmetry of everything not being centered would drive me bonkers lol...
    But thats my OCD....
  • hochpt21
    hochpt21 wrote: »
    I agree, but when you're in the room, it's easier to focus on the two speakers and the middle of the listening position.
    What REALLY bugs me is when my wife takes my spot :):):)
  • hochpt21
    hochpt21 wrote: »
    I like that color
    Thank you. I miss your old listening room LOL!
  • Mikey081057
    This one?
  • hochpt21
    This one?
    Yes, that wall color and that picture just explode. Plus you had more awesomeness in there than shoul legally be allowed.
  • Nightfall
    Nightfall Posts: 10,084
    I can't believe you have those beauties hiding in a closet.
    afterburnt wrote: »
    Village Idiot of Club Polk
    txcoastal1 Posts: 13,513
    Yeah that one...very cool
  • hochpt21
    marvda1 wrote: »
    hochpt21 wrote: »
    Do you have them?
    Better than signal silvers?
    Work well for turntable?
  • Mikey081057
    This room is under development :)
  • hochpt21
    I've been noting it's progress :)
    You still have that picture?
  • Mikey081057
    No... sold it.... I might want to get another tho... there are lots...
    http://www.lik.com/thework/oceans-beaches-harbours.html
  • afterburnt
    afterburnt Posts: 7,892
    @hochpt21 what do you miss about the 705's?
  • Mikey081057
  • Mikey081057
    DSkip wrote: »
    I really miss those Mini X's. Just phenomenal for what they are.
    They are everything and more ... they actually made me put my sda's in the closet... that says it all
  • Mikey081057
    afterburnt wrote: »
    The 705's are in my HT ... I love them very versatile...
  • hochpt21
    afterburnt wrote: »
    The LS 90's are a really good speaker. Especially solid deep bass.
    I miss just a bit of the air and detail in the mids and uppers. The 705's provided that. The 90's are very smooth but I think I'm beginning to discover that I prefer the higher side of detail and a bit of sparkle as opposed to smooth and buttery.
    Again, I really like the 90's, and it will be some time before I upgrade.
  • hochpt21
    DSkip wrote: »
    Don't mistake high end extension for detail. The tweeter is the biggest downfall of that series IMO. It may not be the tweeters fault, but the highs are just not quite there.
    They are good speakers though and deserving of a stop at the abode.
    As @erniejade can attest to, the sound difference with the grilles off is incredible. That's how I would prefer to listen, but the wife doesn't like and I've got thirty fingers under 6 yrs old to keep out :)
  • afterburnt
    Thanks hochpt21, I am still trying to miss my 707's but they are still here lol. They are my project child. Man I got spoiled with the Ushers but the 707's are a dream with HT but I just don't do much of that these days. BTW I love your TT isolation, mine works really well to but I think it needs some black spray paint.
