2 channel rig finally set up again!
FINALLY! Project complete!
We essentially rearranged the living room 180*, had a dedicated 20a circuit put in, ran cable and data lines and fished the tv wires though the wall. I taped the speaker cables down so there are now no wires for the little kiddo's to mess with.
As far as the TT is concerned...I was planning to wall mount, but as I looked at the project more closely...it just wasn't going to be feasible.
So I came up with an idea and it worked. #5 vibrapods on the feet of the audio rack, large sorbothane balls on top of the rack for the first shelf to sit on, mini sorbothane balls between the two shelves and #2 vibrapods under the TT feet. I know that's a lot of messing around, but I am able to jump and stomp with NO skips. I was stomping so hard I thought pictures were going to start falling off the walls :)
Also moved an Ikea shelf back into the living room for my albums. Not the sweet 'record store' setup I had for awhile, but it'll do.
I feel so relieved. This project took way longer than I thought it would, but I wanted it done right. It just feels good that its finally done and I can sit back and not stress.
«13
  • voltz
    voltz Posts: 5,384
    Looking good Paul :) Enjoy it!
    edited May 2015
    Nice work! Bet it sounds GREAT! Very clean! Could you do my house?
    Neat is not something we have around here!
    Enjoy!
  • Thorton
    Thorton Posts: 1,324
    Very nice work. Looks great. You always end up spending more time on a project than expected but it the end you usually end up with a smile on your face.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • btown1985
    btown1985 Posts: 113
    Nice and clean! The more I see vinyl and these nice players, the more I am intrigued...
    LSiM 705 and 706c, Def Tech Supercube I, Anthem AVM20 Processor, Oppo BDP-105D, Adcom GFA-5503, Pioneer Kuro KRP-500M, Panamax Elite 15PFi
  • Wardsweb
    Wardsweb Posts: 944
    Kudos to you for all the hard work, but it was worth it. Now forget work, sit back, relax and spin some vinyl. Listening is what it's all about.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Nicely done.
    Good feeling to have the rig back up after being off-line, eh?
    Love that MF int amp! :)
  • hochpt21
    hochpt21 Posts: 5,423
    Erik Tracy wrote: »
    Nicely done.
    Yea, me too :)
    EndersShadow Posts: 17,752
    Looks horrible. I think the MF integrated just doesn't go with your gear. You should send it to me instead :wink:.
    Looks great.
    I'd look into speaker wire conduit as another option to hide the wire if the tape doesn't work out.
    I use some of the larger square white conduit for my 2 channel to hide some power and HDMI cables.
  • hochpt21
    Looks great.
    I have a layer of blue painters tape as the first layer of tape so as to not damage the cables. Then the darker tan duct tape over that. For the left channel I currently have masking tape instead of the brown duct tape (hence the different colors), but when I pick up another roll of the light brown duct tape they will both look the same and it blends fairly well with the carpet.
  • PSOVLSK
    PSOVLSK Posts: 5,438
    hochpt21 wrote: »
    ...it blends fairly well with the carpet.
    I didn't even notice the tape. Setup looks great!
    SCompRacer Posts: 9,344
    Looks great Paul! Nice job on the TT isolation.
  • MrBuhl
    MrBuhl Posts: 2,419
    Looking good Paul!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • BlueFox
    BlueFox Posts: 15,250
    Very nice. I sometimes am envious of those with nice homes. I like the smoke detector over the setup. Good thing audio level can't set it off. :)
  • hochpt21
    SCompRacer wrote: »
    Thanks Rich. I really struggled with this. Even when I had it mounted in the built in on the other side of the room, I would get skips sometimes when the kids would bounce around.
    I had planned to wall mount it with this new setup, but wasn't going to feasible. I thought I'd throw all my pods and balls at it ;) and see what happened. The result is not one skip yet even with me and the kids jumping all around. I'm really happy with the results.
  • chumlie
    chumlie Posts: 8,658
    Atta boy baller. Enjoy !!! Looks great.
  • kevhed72
    kevhed72 Posts: 5,205
    Looks awesome.....motivation for me to finish drywalling my room.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Excellent. Thats it! I'm cleaning the mancave!!
    edited May 2015
    hochpt21 wrote: »
    Wall mounting a TT can help in some instances, but it won't do anything about ground borne vibrations entering the turntable on a wall mount from the building structure. Could be it depends on where the wall is built. That is a room divider wall sitting on a suspended floor would transmit floor vibes better than a wall built on a foundation. For that reason, I prefer the isolation method like you did. The plus is change the room around, the table on isolation can follow the rack versus moving a wall mount.
  • gce
    gce Posts: 2,158
    hochpt21 wrote: »
    Good job on the isolation for your TT. I have mine wall mounted now and you can bang on the floor in front of it and you hear nothing from the TT. I did have it sitting on a stand sitting on the floor but not isolated like yours is and it was horribly noisy.
    Anaheim Hills CA,
    HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
  • dromunds
    dromunds Posts: 10,169
    Looks great! I also use vibrapod/sorbothane isolation under my TT and it works very well. BTW, I didn't notice the tape in the photos initially either. Pretty nice vinyl collection going there ...
  • hochpt21
    2 channel system #2 is also finally set up again :)
    My "man-room" had turned into a storage room and I cleaned and organized today.
    I also had a dedicated 20a circuit run here as well. I was getting horrible interfere from the light when it was on causing a buzz throughout the system.
    Now silent black background.
  • Erik Tracy
    That needs a MF, too. :)
    edited May 2015
    Erik Tracy wrote: »
    Agreed. That poor Dared looks like a mouse compared to the other gear.
    Anyhoo...glad your 2 channel is back and making you play with yourself...again.
  • hochpt21
    Currently the Dared pre and HK 3490 (just the power amp section obviously) sound pretty damn good.
    Eventually, I'm planning on a different power amp and upgrading x-overs, but right now it's just fine.
    I now have a dedicated 20a circuit for the main system, the man room and the HT. It has made the most difference by far in this room for whatever reason. It was a delight to 'hear' the silence in the background :)
  • [Deleted User]
    I admire your sense of grandeur. Well done. Use guys keep me on my toes. :p
    Erik Tracy wrote: »
    tonyb wrote: »
    Erik Tracy wrote: »
    I admire your simplicity...... I'd just replace that CD player with a Squeezebox w DAC myself hehehe.....
  • hochpt21
    Erik Tracy wrote: »
    tonyb wrote: »
    Erik Tracy wrote: »
    But then what would I play all my super duper audio disks on ;)
    hochpt21 wrote: »
    Erik Tracy wrote: »
    tonyb wrote: »
    Erik Tracy wrote: »
    Audio discs? You mean those shiny things you put under your drink so it doesnt sit on the wood endtable?
  • chumlie
    So what's in the fireplace now ?
  • hochpt21
    chumlie wrote: »
    Wood :D
    Jk....actually we may get a new insert for the fireplace but I think we're going to use the built in where the audio gear was for kids books
