Inverted phase question, with a twist
GlennDog
My Cary preamp inverts the phase signal at the output
I am also using tube mono blocks, the good 1KVA dreadnought and SRS 2.3 TL's
Is this statement true, regardless of equipment used:
"It is not a good idea to reverse the polarity of speaker wires when using SDA speakers this would connect a common ground short to the positive terminals of your amplifier. In the case of a twin blade SDA this would short the amplifier, in the case of a pin blade speaker there wouldn't be any "SDA" information."
The reason I ask is because the SQ/soundstage isn't quite right. Thoughts?
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
Not an expert, but I believe your mixing phase with polarity. Phase in a music signal can be inverted, but that doesn't change the polarity of the amplifiers output.
On second thought, since you're using a Dreadnaught, there is no direct connection between the speakers, so reversing the polarity at both Amplifiers Outputs or the at both speakers binding posts should not cause any damage. What affect that will have on the difference signal and crosstalk cancellation is unknown.Home Theater/2 Channel:
dhsspeakerservice.com/ -
TY wMass,
I'm no expert either, but I think the 2 terms are one-in-the-same. But to be clear, the Cary owners manual refers to "phase" and states the connections at the speker need to be reversed from the conventional connection method.AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
True, a pre amp with inverted phase output is corrected by reversing speaker cables. Unsure what the effects would be reversing speaker cables with SDA/Dreadnought.
I've had pre amps that inverted phase, a ModWright SWLP 9.0 for example. With my active crossover ESL's it didn't seem to matter much inverting phase, but with conventional speaker crossovers it did. (It costs more to add circuitry/tubes to correct the phase output, may affect original design circuit SQ, etc). Other active circuits (like CD player) can also reverse phase so sometimes you have to experiment with correct or reverse phase at speakers and keep what sounds better. But only if safe to do so in your SDA/Dreadnought situation.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I have an Odyssey Candela that reverses phase. I've run the speaker wires with the polarity as marked (+ to +) and reversed from the amp into my 2.3TL's with a Dreadnought. It won't hurt anything. Connect it the way it sounds best."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
drumminman wrote: »I have an Odyssey Candela that reverses phase. I've run the speaker wires with the polarity as marked (+ to +) and reversed from the amp into my 2.3TL's with a Dreadnought. It won't hurt anything. Connect it the way it sounds best.
So the Odossey reverses phase?? I have one and had no idea..Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Good to hear from you!!
To be clear, you are saying that it's ok to connect the Pos speaker to the Neg Dreadnaught binding post??AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Leave the Dreadnaught alone. You're swapping the + & - at the amp or the speaker terminalsdrumminman wrote: »I have an Odyssey Candela that reverses phase. I've run the speaker wires with the polarity as marked (+ to +) and reversed from the amp into my 2.3TL's with a Dreadnought. It won't hurt anything. Connect it the way it sounds best.
