Inverted phase question, with a twist
My Cary preamp inverts the phase signal at the output
I am also using tube mono blocks, the good 1KVA dreadnought and SRS 2.3 TL's
Is this statement true, regardless of equipment used:
"It is not a good idea to reverse the polarity of speaker wires when using SDA speakers this would connect a common ground short to the positive terminals of your amplifier. In the case of a twin blade SDA this would short the amplifier, in the case of a pin blade speaker there wouldn't be any "SDA" information."
The reason I ask is because the SQ/soundstage isn't quite right. Thoughts?
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2015
    Not an expert, but I believe your mixing phase with polarity. Phase in a music signal can be inverted, but that doesn't change the polarity of the amplifiers output.
    On second thought, since you're using a Dreadnaught, there is no direct connection between the speakers, so reversing the polarity at both Amplifiers Outputs or the at both speakers binding posts should not cause any damage. What affect that will have on the difference signal and crosstalk cancellation is unknown.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • GlennDog
    GlennDog Posts: 3,158
    TY wMass,
    I'm no expert either, but I think the 2 terms are one-in-the-same. But to be clear, the Cary owners manual refers to "phase" and states the connections at the speker need to be reversed from the conventional connection method.
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    SCompRacer Posts: 9,147
    edited April 2015
    True, a pre amp with inverted phase output is corrected by reversing speaker cables. Unsure what the effects would be reversing speaker cables with SDA/Dreadnought.
    I've had pre amps that inverted phase, a ModWright SWLP 9.0 for example. With my active crossover ESL's it didn't seem to matter much inverting phase, but with conventional speaker crossovers it did. (It costs more to add circuitry/tubes to correct the phase output, may affect original design circuit SQ, etc). Other active circuits (like CD player) can also reverse phase so sometimes you have to experiment with correct or reverse phase at speakers and keep what sounds better. But only if safe to do so in your SDA/Dreadnought situation.
  • drumminman
    drumminman Posts: 3,396
    I have an Odyssey Candela that reverses phase. I've run the speaker wires with the polarity as marked (+ to +) and reversed from the amp into my 2.3TL's with a Dreadnought. It won't hurt anything. Connect it the way it sounds best.
  • vmaxer
    vmaxer Posts: 5,121
    drumminman wrote: »
    So the Odossey reverses phase?? I have one and had no idea..
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • GlennDog
    drumminman wrote: »
    Good to hear from you!!
    To be clear, you are saying that it's ok to connect the Pos speaker to the Neg Dreadnaught binding post??
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • westmassguy
    GlennDog wrote: »
    drumminman wrote: »
    Leave the Dreadnaught alone. You're swapping the + & - at the amp or the speaker terminals
