I just bought this last week - Yaqin MS-30L integrated tube amp
I would send him a message. I am sure the post just expired and he has not refreshed it. My tube amp has 8 pre tubes as does the MS-30L and 4 power tubes. The pre tubes are very in expensive compared to the power tubes. You could replace all 8 for less than one power tube. Send him a message and see what he has in stock. When I was looking in to it he also had a demo model of the 30L but I really wanted the big vu meter of the MS38.
as a rule the 8 tubes would be cheaper as they noe as sought after as the 12ax7 and 12au7 tubes.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Greetings
Just found my way over here today. I have a Yaqin MC-30L and recently did a tube roll to EH6CA7sand a full 6AK5 preamp refit. they are still breaking in as I write this. Noticed a much tighter bass response with the 6AK5s and then added the EH6CA7 matched quads. Picked these up from Tubemeister.
The tubes that came with this amp took about 80-100 hours to finally open up and sound decent. The roll however made a difference in better articulation and staging. the bass was immediately tighter with the mids and treble sounding a bit wider and cleaner overall.
I have tried using a combo of the original pre-amp tubes and the 6AK5s but decided to use all 6AK5s for the reasons stated.
I am hoping after running it for the same amount of time 80-100 hours it will bloom a bit and open up in a similar fashion as a friend's unit who runs the same set up.
Bias is set at .40. I ran the originals at .38, but prefer the EH adjusted at .40 as they sound best with this bias setting.
Hermit -
YAQIN Silk Audio ms-38.
Mine came today fed-ex 10:55am CST AT the front door, they just left it there didn't even ring the doorbell.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Wow man. That's horrible. Lucky no one walked off with it. Have you had an opportunity to hear it?2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Just saw this tread. I want one of these now. Turns out there is a dealer in Ontario. I know what I want for Xmas. Thanks guys, my wallet is already empty.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
SDA SRS 2.3TL's
SDA 2B TL's -
Been 4-days now, what up my man2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Congrats on the new MSRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Sorry txcoastal and thanks boston 1450
BTW this is all Glenn Fowler's fault!
Very happy with it.
Hardest thing was finding a place to put it.
It's like 50 lbs.
I went ahead and got the Phono Preamp that Ray sells too.
Blue light is too bright
I have it on SDA 1C plenty of power ,for me.
I still have to create some more room and burn it in.
I am going to figure out the motor hum on that old Elac sub something else while.
Looking good man. Try a small piece of electrical tape on the blue light.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Everybody knows tubes and SS sound the same.
Just kidding. Looking good! Is there a Silk tube preamp?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
That is one great looking amp.
Nightfall he's on Ebay here is a link.
http://stores.ebay.com/Silk-Audio
xsmi yea that blue light needs to get dim :=\
I used a drop of blue touchup paint for the car worked perfect. lights but not bright.Looking good man. Try a small piece of electrical tape on the blue light.
Cool, I didn't think of that!2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Hope your enjoying that PolkieMan. I got mine hooked up to the 1c's now with MIT cables. Im going to be TL'n the CRS+'s soon & im gonna give them a listen. Enjoy & please keep us postedRandy-Maine
by David WMG
Wow I was a little concerned about having plenty of power for the 1C, not!
I got to get some this holiday stuff out of the way, I'll b back :-)POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Power isnt a issue. PlentyRandy-Maine
by David WMG
Yeah but it's not an Emo or Parasound...
kidding... love my YaqinMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
