I just bought this last week - Yaqin MS-30L integrated tube amp
124»
  • I would send him a message. I am sure the post just expired and he has not refreshed it. My tube amp has 8 pre tubes as does the MS-30L and 4 power tubes. The pre tubes are very in expensive compared to the power tubes. You could replace all 8 for less than one power tube. Send him a message and see what he has in stock. When I was looking in to it he also had a demo model of the 30L but I really wanted the big vu meter of the MS38.
  • marvda1
    marvda1 Posts: 4,956
    as a rule the 8 tubes would be cheaper as they noe as sought after as the 12ax7 and 12au7 tubes.
    Puritan PSM156
  • Hermit
    Hermit Posts: 1
    Greetings
    Just found my way over here today. I have a Yaqin MC-30L and recently did a tube roll to EH6CA7sand a full 6AK5 preamp refit. they are still breaking in as I write this. Noticed a much tighter bass response with the 6AK5s and then added the EH6CA7 matched quads. Picked these up from Tubemeister.
    The tubes that came with this amp took about 80-100 hours to finally open up and sound decent. The roll however made a difference in better articulation and staging. the bass was immediately tighter with the mids and treble sounding a bit wider and cleaner overall.
    I have tried using a combo of the original pre-amp tubes and the 6AK5s but decided to use all 6AK5s for the reasons stated.
    I am hoping after running it for the same amount of time 80-100 hours it will bloom a bit and open up in a similar fashion as a friend's unit who runs the same set up.
    Bias is set at .40. I ran the originals at .38, but prefer the EH adjusted at .40 as they sound best with this bias setting.
    Hermit
  • PolkieMan
    PolkieMan Posts: 2,446
    YAQIN Silk Audio ms-38.
    Mine came today fed-ex 10:55am CST AT the front door, they just left it there didn't even ring the doorbell.
  • xsmi
    xsmi Posts: 1,804
    Wow man. That's horrible. Lucky no one walked off with it. Have you had an opportunity to hear it?
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Just saw this tread. I want one of these now. Turns out there is a dealer in Ontario. I know what I want for Xmas. Thanks guys, my wallet is already empty.
    2 channel:
    Theater:
  • :D
    SDA SRS 2.3TL's
    SDA 2B TL's
    txcoastal1 Posts: 13,518
    PolkieMan wrote: »
    Been 4-days now, what up my man
  • boston1450
    boston1450 Posts: 7,758
    Congrats on the new MS
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • PolkieMan
    edited November 2015
    Sorry txcoastal and thanks boston 1450
    BTW this is all Glenn Fowler's fault! :smiley:
    Very happy with it.
    Hardest thing was finding a place to put it.
    It's like 50 lbs.
    I went ahead and got the Phono Preamp that Ray sells too.
    Blue light is too bright
    I have it on SDA 1C plenty of power ,for me.
    I still have to create some more room and burn it in.
    I am going to figure out the motor hum on that old Elac sub something else while.
  • xsmi
    xsmi Posts: 1,804
    Looking good man. Try a small piece of electrical tape on the blue light.
  • Nightfall
    Nightfall Posts: 10,083
    Everybody knows tubes and SS sound the same.
    Just kidding. Looking good! Is there a Silk tube preamp?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • indyhawg
    indyhawg Posts: 1,673
    That is one great looking amp.
  • PolkieMan
    Nightfall he's on Ebay here is a link.
    http://stores.ebay.com/Silk-Audio
    xsmi yea that blue light needs to get dim :=\
  • PolkieMan
    I used a drop of blue touchup paint for the car worked perfect. lights but not bright.
    xsmi wrote: »
  • xsmi
    xsmi Posts: 1,804
    PolkieMan wrote: »
    Cool, I didn't think of that!
  • boston1450
    Hope your enjoying that PolkieMan. I got mine hooked up to the 1c's now with MIT cables. Im going to be TL'n the CRS+'s soon & im gonna give them a listen. Enjoy & please keep us posted
    Randy-Maine
    by David WMG
  • PolkieMan
    Wow I was a little concerned about having plenty of power for the 1C, not!
    I got to get some this holiday stuff out of the way, I'll b back :-)
  • boston1450
    Power isnt a issue. Plenty
    Randy-Maine
    by David WMG
  • Mikey081057
    Mikey081057 Posts: 7,127
    Yeah but it's not an Emo or Parasound...
    kidding... love my Yaqin
    Garage | Polk Monitor 5B's
