Polk Audio SDA SRS Modification Thread Part 2 - The "Ultimate Build"
Little update
"The speakers sound spectacular. Much more open and detailed than with the original crossovers, and they really open up the music. If they will improve as the new parts get conditioned & burned in there won't be enough superlatives to describe them! To help accelerate the burn-in tomorrow the tuner will be hooked up and kept on when not using the CD player.
Tomorrow I may try them without the front covers and the internal light dialed up. When seated I may be looking right into the windows.
You have made a great speaker exceptional and resolved the problems with capacitors at or beyond their life expectancy, and the "old" technology being outdated.
Thanks for putting this project together. "- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
200 hour update -
A tuner was used to run the stereo system for the past 10 days with little "off" time, passing the 200 hour mark yesterday.
When now playing the same CD as in the first few hours the soundstage is much broader and deeper, and the richness and detail in the material is substantially increased (at least 30% to 35%).
The system now shows how many CDs are not recorded with a lot of depth and richness to the material. Those CDs with "depth" to the recording really come to life. The best example is with triangles on one recording where the strike, resonance, and decay of the tone is real and "suspended in air." The tight control over the bass now also brings out nuances that were not even heard with the original crossovers.
The speakers sound better than anything I've ever experienced! Thanks for making this happen, and for all of your time and effort. Let me know if there I anything I can do to help with your future projects.
He is using an assortment of high powered Krell gear with a large spacious room
wow...
WHen I get around to doing the SRS/M cabinet project, I might want to do something similar.
Congrats to both of you for raising the bar for the rest of us to follow.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Definitely man, I just ask to mix it up how it looks and is constructed. Maybe we can talk up on a cool design for it
Thank you for the compliments!
The speakers at their home
Very nice!!
Wow..... That is so cool!HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Trey, your work has evolved into something quite awesome.
He's fooling you, his Transformer robots do all the work while he sleeps
Nice job
Thanks guys!! :-D
The Transformers do way more work than me... lol (I wish)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Awesome!!! I would love to hear them, I can only imagine.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Thank you sir
The owner sent me some updated photos!
Hey Trey
Would these upgrades change the s/n ratio , sensativety and frequency response etc? -
Technically speaking, no, but you can generally see small differences between stock and modified crossovers. It is within the specifications of the speakers.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
FYI, speakers do not have a signal to noise ratio spec.Political Correctness'.........defined
President of Club Polk -
+1 DSkip, I would say the signal to noise ratio on stock crossovers is 100%, It receives a signal and outputs noise...
heheheh - Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
@F1nut good to see your on the ball ,,just testing ya : )
Not sure if anyone else has noticed this but the use of the Clarity MR caps took the longest to settle in comparison to other caps I have used, (Sonic, Solen)..
Of the four sets of crossovers Vr3 Mods has done for me, the most recent set, using Clarity MRs, took by far the longest to burn in -- over 300 hours. There was significant improvement at the 250 hours point, but somewhere north of 300-325 hours my SDA SRS 1.2TLs really blossomed, opened up. An amazing experience!
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
I remember when the MR capacitors on my Super Towers were breaking in, me and @lightman1 were here enjoying a few glasses of alcoholic beverages around Thanksgiving. We were going through the paces on the Super Towers and it was like a switch was hit, they simply blossomed into this whole other dimension of insanity.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok, after many designs and a lot of thrown away pieces we had to find a handle design that worked. We went with a throw back of the old but more substantial, milled from 1" wide, 1/2" deep aluminum
This will come together quickly, everything gets painted soon and everything will be pre-wired
before it goes on the chassis
@xschop example 1- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So cool, reminds me of a Pass Labs design/look. Nice job again.
