Polk Audio SDA SRS Modification Thread Part 2 - The "Ultimate Build"
VR3
VR3 Posts: 29,529
edited August 2014 in DIY, Mods & Tweaks
So I have the rare opportunity for someone to bring me the speakers in person! They are making the trek from Virginia -
Will start the thread and update it upon completion -
Specs of the build -
Tweeter Network -
Clarity Cap MR 400v
Clarity Cap ESA 250v
Duelund Resistors
Jantzen Inductors
Supra Rondo 13 awg Internal Wiring
Midbass/SDA Network -
Clarity Cap MR 400v
Jantzen Inductors
Jantzen C-Coil SDA Inductor for the lowest possible DCR
Other Features -
Updated shelf design - will be mounted inside the enclosure, front to back with a "flipped" front that opens up to a clear lexan window on a custom built faceplate that will be built for a beauty view of select parts, most likely a Duelund resistor and two MR caps and an engraved plate. Will be looking into a battery powered led with a switch to light this area up. Custom rounded handles, little wider than the stock flat handles for a more modern design.
Clear lexan substrate versus delrin, .25" thick - will be using tech flex/heat shrink for the internal wiring for the cleanest look
9 AWG SDA Cable, NL4 connection
Custom round aluminum termainl plate
WBT Binding Post
Hurricane Nuts for all screw locations
Dynamat driver baskets
No Rez or Sonic Barrier for the enclosure walls
"Custom Bass Brace" that is a "cage" design that attaches on four points on the back of the speaker with head duty rubber isolation mounts that will aid in an earthquake as well as accomplish the point of the original bass brace.
Attached is a concept of the original chassis design which has already changed.
Post edited by VR3 on
«13
  • drumminman
    drumminman Posts: 3,396
    edited April 2014
    Looking forward to your progress in this Trey!
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    wow...impressive...
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2014
    Trey,
    This will be great to follow!
    Please, post lots of pictures early and often.
    VR3 Posts: 29,529
    edited June 2014
    1st Quarter Update!
    After extensive R&D on the new shelf platform I came up with a fully isolated design that will be a three piece build. I am excited, the fabricator is building them now. Very excited about this build.
    I upped the aluminum to 1/8" thick, 6160, the front panel is 1/4" thick and the Lexan substrate is 1/4" thick. All aluminum hardware will be used on the shelf system as well.
    Pictured below is the internal wiring and No Rez installed.
  • zane77
    zane77 Posts: 1,696
    edited June 2014
    Another great looking mod Trey
    Two Channel
    VR3 Posts: 29,529
    edited June 2014
    Thank you! I am still a few months out. I will post pictures of different parts ad they happen.
  • Moose68Bash
    edited June 2014
    Trey,
    You are quite the teeze!
    Keep the pictures coming, please. This looks exciting!
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2014
    Since those were delivered makes all the sense you would take on that big boy project. When done I'll be very intersted to have a look at the see through features ala the glass back Ferrarris that show off the v12. Do you also take in on shipped items regular sized speakers to do whatever they request? Btw the cross overs settled in beautifully and listeng to them right now. Again can't thank you enough to work w/ me and then the whole mis delivery deal which really scared me. It all worked out.
    Lew.....
    VR3 Posts: 29,529
    edited August 2014
    Slowly forming into a bad **** chassis
    VR3 Posts: 29,529
    edited August 2014
    Fairly excited to use Lexan on this project, at 1/4" thick it is beyond strong and has been very interesting to work with so far :)
    VR3 Posts: 29,529
  • zane77
    zane77 Posts: 1,696
    Wow! Looking good!
    Two Channel
  • ROHfan
    ROHfan Posts: 1,014
    Somehow, "wow" seems like an understatement. Can't wait to see the finished product and read the extensive review!
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    VR3 Posts: 29,529
    Ok, after many designs and a lot of thrown away pieces we had to find a handle design that worked. We went with a throw back of the old but more substantial, milled from 1" wide, 1/2" deep aluminum
    This will come together quickly, everything gets painted soon and everything will be pre-wiredxe38273ab06j.jpg
  • xjghost
    xjghost Posts: 1,115
    That is pretty darn cool. Kind of looks like sticks of dynamite in there.... lol!
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • oldrocker
    oldrocker Posts: 2,590
    Talk about motivation to make the drive. The custom "built for" engraving.
    Nice touch.
    VR3 Posts: 29,529
    Thanks guys!
    Cant wait to see what these look like with the faceplates black and the chassis white. We are also installing an adjustable battery powered blue led inside the cabinet to back light the part you can see!
    VR3 Posts: 29,529
    edited October 2014
    This is the definition of tedious :p
    VR3 Posts: 29,529
  • Moose68Bash
    Trey,
    It may be tedious work, but it looks like another fantastic product of Vr3Mods!
    Looking good!
    VR3 Posts: 29,529
    Thanks Phil!
    I will get to start posting pictures of yours soon enough! Alot of the way yours rip be built will be taken from here!
  • Moose68Bash
    I'm looking forward to seeing pictures!
    VR3 Posts: 29,529
    edited November 2014
    Starting to (slowly) see the finish line
  • vmaxer
    vmaxer Posts: 5,120
    VR3 wrote: »
    Beautiful - I want!!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,529
    Thank you! :)
  • Conradicles
    Conradicles Posts: 6,373
    Fantastic work VR3!!!
    VR3 Posts: 29,529
    Thank you :)
    My goal is to have minimum visibility of wire on all parts of the build even though the substrate is clear.
    VR3 Posts: 29,529
  • mrbiron
    mrbiron Posts: 5,721
    Trey, your work has evolved into something quite awesome. Those white panels are great.
    Question, how do the transformers work in this build? :wink:
  • BKphoto
    BKphoto Posts: 409
    although you could probably get a ferrari for what you have in those SRS's...
