MartyCube... Lets get ready to CRANK THE BASS!!!!!!!!
    EndersShadow Posts: 17,765
    I agree.... I also got a guy who knows a how to craft some stuff.. both (cough, ryan, cough) and another guy in Cali who might be able to help me make some on the cheap as well.
    edited January 2015
    I'm slow like a tortoise at things like this but...
    Enclosure FlatPack is sitting at work and will be taken home tonight. I purchased some TiteBond and glue brushes (thanks @f1nut ) to help me put things together.
    I need to get to Harbor Freight to get some other supplies as well. My final parts list is below (thanks @ZLTFUL & @F1Nut):
    2 x 1 In x 15 Ft. Ratcheting Band Clamp
    4 x 24 in. Quick Release Bar Clamp
    1 x 2" thick Eggcrate foam mattress pad - surprisingly Amazon is like 1/2 what Walmart is on these....
    1 x Duratex
    Thats it, the rest has all been purchased and is sitting at my house waiting and waiting and waiting...
    I plan to build the enclosure slowly and anywhere I can seal joints with locktite after they are glued together and dried. I figure I've got 2 extra bottles of it with nothing else to use it on, so why not make sure this baby is airtight. I want to do this once and be done lol....
    Once I get to actual assembly stuff I will post some pictures....
  • oldrocker
    oldrocker Posts: 2,590
    Can't wait to see this monster....
    oldrocker wrote: »
    I cant wait to DIAL this monster in!
    I may have to send the wife shopping for shoes with the kido or something lol....
    My goal is a noise complaint hehehe.....
  • Conradicles
    Conradicles Posts: 6,437
    That Titebond glue is fantastic. I used it on my recent build.
  • Conradicles
    Why the egg crate foam Enders?
    Dunno it was recommended by the guys in AVSForum with this build
    See quote (link here)
    chalugadp wrote: »
    For ported sub lining can be helpful but other then the back wall its debatable how much differeance it makes. I line mine cuz the bed topper from walmart is cheap and its another way to ensure the cab has no leaks. If the foam cost was over 50$ I probably wouldnt use it.
    Interesting back and forth from the same guy (below) about downfiring in different rooms, may have to test my setup both ways before I finalize the design with the legs added. He used REW so I may ask him to post some graphs...
    I also may just try to find a nice piece of wood to test a bottom plate so it not directly onto the carpet...
    Samps wrote: »
    After a whole day of testing my down firing martycube I have come to the conclusion that it is not the best arrangement for this driver and box.
    When down firing the effective tune is lowered which would normally be a good thing but it also caused a loss of output between 20-40hz which is the meat of your fun movie bass. When this very same box was flipped so the driver was facing straight up the response was much better and matched the model. This was tested with a calibrated umik1 with rew. Tested on two different carpets in two different rooms. The results might change depending on how high the driver is raised off the ground but I didn't test that. My recommendation would be to run the ports out of a different side if you plan to use the down firing setup.
    As a side note. Subjectively I like the sound better without all of the foam lining the walls of the cab. Rew showed no meaningful difference but to me the bass sounded crisper with only the back wall lined. I can't prove it but my ears like it.
    So my cube is now up firing with only the back wall lined. I took a day off work and spent 8 hours testing. I had to dump the rew measurements three times because I used all of the available graph spots.
    SEE POST 423 FOR UPDATE
    (link)
    Samps wrote: »
    Don't get me wrong, it sounds good down firing. But it sounds better firing up. I'm suggesting moving the ports to a side not firing directly into the floor. I'm sure the driver is fine facing down. Almost all down firing designs by commercial manufacturers have the port facing either the front or back. It appears the area under the box is adding to the effective length of the ports. I am enjoying this sub, but I need to add a grill of some kind now. The legs should help form a good frame for whatever I come up with.
    (link)
    Samps wrote: »
    Moved the cube into my basement and the results were quite different. The arrangement of the sub didn't make hardy any difference at all. So, I'm not sure what kind of conclusion can be made by my tests. The only other difference besides the room is the avr used.
    Down firing may work just fine.
    I would like to try to duplicate my results in the living room, but moving this thing up and down stairs by myself is not easy. Coming down wasn't too bad, but going back up sucks.
    (link)
    Samps wrote: »
    Upstairs is 3/4" shag carpet on a wood floor. Basement is a tight flat carpet on cement floor.
    The nearfield measurement in the basement with the mic placed right under the cube was the flattest response I've ever generated. It was almost a perfect match to the model from 15-80hz with no ripple or bumps at all. It was also alot louder than the mic placed 10 feet away.
    Has anyone ever considered placing the sub firing directly into the back of their head? The frequency response would be perfect.
    (link)
  • oldrocker
    May I suggest eye protection and a corset? Keep the blood vessels intact and the internal organs in the right place when that thing goes off :o
    I'm sure I'll hear some sort of insane thump over the horizon.. >:)
  • oldrocker
    Just scrolled back to the pic of the Dew can next to it..WOW!
  • codyc1ark
    codyc1ark Posts: 2,539
    Is this done yet? I feel like I've been waiting forever.
    codyc1ark wrote: »
    LOL, dont hate Cody.... some things take time
    PS..... Go Pack Go :smiling_imp:
    ZLTFUL wrote: »
    Liked Cody's comment.
    @codyc1ark I gave him an open invitation to come up so we can assemble it but he keeps whining about sand in his vajayjay and stuff.
    ROTFLMAO
  • codyc1ark
    I hear it's like a sand factory.
    edited January 2015
    OK, back to the original topic, I may have found someone closer to help me get it together so I dont have to buy a bunch of clamps and whatnot for this. As a side benefit he's got some leftover 4x4 Roxul panels from his HT he may be willing to donate (and help me build out some quick frames for).
    Sorry Ryan, I appreciate the offer but, the drive out to you is a hard sell to my wife lol..... Plus then I'd be close to Cody...... and that just killed it for me :grimacing: .
    I am trying to hammer some stuff down and see if its possible to get that to happen.
    Otherwise I will be stopping at Harbor Freight and snagging 6 24" clamps give or take.
    edited January 2015
    So bumping this thread.....
    A buddy of mine in Evansville (who was going to help me fab the enclosure originally) and I have been talking for a couple weeks and we got tomorrow on the calendar for coming down and getting my enclosure built.
    He's got access to lots of clamps and anything else we would need.
    And he's also built me 4 sound panels to take back with me to Indy to cover with whatever fabric I want. Yeah, he's cool like that.
    Tomorrow in addition to putting together the enclosure, I'm walking him through how to rip movies to a external Hard drive you can access through the WD Live TV.
    For those of you interested here is a link to what I am talking about. As far as ease of use, couldn't get easier and my wife and family love it as its easy to see what movies we have, the movie skips the previews and any special features, and I only have the highest codec loaded.
    Overall for those of you who have gone digital, if your collection isnt INSANE with blu-rays, this is a cool setup and cost you all of 200 bucks for the lot. If your collection is massive maybe rip JUST the movies you watch lots to a hard drive, and leave the rest in your library. Or copy Ryan (like I will eventually) and build a dedicated media server .
    Anyway looking forward to a early wake-up tomorrow to go hang out with my buddy for most of the day, get my enclosure built, talk audio and see his awesome DIY speakers that were awesome to watch build.
    Just got back. Will post some pics later tonight. Enclosure is all together at his place with weights on the baffle and lots of clamps on it.
    We will get the finish done later along with the bottom base. We got the binding post holes routed and everything figured out.
    Here are some pics in no particular order. I focused more on hanging out with Chris and building than taking pictures, so apologies for a not fully step by step pictures.
  • WLDock
    WLDock Posts: 3,073
    Coming along nicely!
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • mrbiron
    mrbiron Posts: 5,720
    I read, or should I say, browsed the pictures in Chris' build thread. That guy has some talent! I hope you learned a thing or two while being in his presence :wink:
    Keep us posted.
    mrbiron wrote: »
    Keep us posted.
    Yeah.... I saw his HT and GOD DAMN, his theater is treated right.... Low noise level and super awesome....
    edited February 2015
    Chris just sent these to me....
    He said he's got the holes, corners and joints all filled. Furniture nuts are inserted into the baffle. He's thinking about putting the round-over on all the edges tonight.
    We are still thinking about how to make a nice base.
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    mrbiron wrote: »
    Keep us posted.
    ^ How did you get that thru the censors ?
    Nice work. Glad you are getting so much closer to the build you've anticipated for some time now.
    TNHNDYMAN wrote: »
    mrbiron wrote: »
    Keep us posted.
    No idea to be honest lol... That was the first thing I though of lol.
    Now to get some final things in place to get it all done.
    Man, Chris moves quick lol... guess he was as interested in the Superbowl as I was lol....
    He routed the edges, the port baffle and took some nice close-ups...
  • seabeerob213
    seabeerob213 Posts: 1,843
    mrbiron wrote: »
    Keep us posted.
    So you can say damn, but not c rap, interesting.
    Awesome lookin build, loom forward to seeing your updates
  • codyc1ark
    Fiiiiiiiiiiiiiinally...
    ZLTFUL wrote: »
    Not to diminish Dan's project at all but more to enable him into terrible life choices. ;)
    Yeah, I've seen that.... maybe my second wife would let me get it :lol: IE aint gonna happen no time soon, and likely not ever.
  • codyc1ark
    I think we've heard that before around here, from multiple people, including yourself, and maybe me as well. :smile:
  • MetropolisLake
    Beyerdynamic iNuke
    Behringer. Unless Beyerdynamic owns Behringer or something.
  • MetropolisLake
    With a 1 year old I want to lower the probability of her poking her finger into the driver
    Anybody who is concerned about this ought to check out the Ultimax instead of the Reference sub. On the product page on parts express they stab the thing hard with a screwdriver and it doesn't even scratch.
