B&K 200.5 has arrived (at work)
  • Enders - Congrats on the amp purchase. Glad to see things worked out with the other equipment sale and finding that beast!!!
    BTW - I have both my Parasound amps and Velodyne SMS-1 all controlled by the SC07 12v trigger. No thumping. I know I'm comparing apples/oranges between our two systems, but just a reference point.....
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • mufsoman wrote: »
    Yup, sorry the Rotel didnt work out, but this was a cheaper option of similar spec so its all good.
    Thanks for letting me know. I'm thinking the 12v trigger may solve things but not sure....
    Is it Pre-amp on then Amp on and Amp off then Pre-amp off or totally the other way around?
  • I think it depends on the 12v trigger setup. On my system. I use a panamax 5300 and my avr powers on then trips the 12v which turns on my 2 tfm15's then turns on my crown xls and my minidsp. On power down my avr shuts down first then my Cown shuts off then after 10 seconds my Carvers shut down. I get no thumps or pops on power down or power up
    Normally the preamp (or avr if thats what you use) sends the 12v signal
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • teekay0007
    teekay0007 Posts: 2,288
    Yes...Pre-amp on, then Pwr Amp on and Pwr Amp off, then Pre-amp off.
  • teekay0007 wrote: »
    Hmmm..... Pre-amp on then Power Amp I can do..... Power Amp off then Pre-Amp dont think I can do that one via my Integra
    How about you tell everyone what they want to know.....how does it sound ?
  • tonyb wrote: »
    F'in good!
    Mo' betta at less volume.
    Gets SUPER LOUD with no distortion, I'm enjoying it very much.
    Speakers seem clearer....
  • 11tsteve
    11tsteve Posts: 1,166
    My Ref 200.2 (no trigger) does the same thump/warble sound when I use the power button.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • 11tsteve wrote: »
    So are you using the 12v trigger to get around it? Or it just something you expect?
    I could leave it on 24/7 but I've heard and noticed it runs a bit warmer than my Carver when its been on/used for a bit.
  • 11tsteve
    no... i haven't hooked up a trigger... I meant I have no trigger hooked up.
    It is not very loud with mine, and does not seem to be anything destructive.... it is a small pop, usually followed by a quiet gurgle sound. I assume it is the lack of protective circuitry, and has something to do with caps discharging.
    But, if the trigger stops it, I may look into that.
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve wrote: »
    Yeah, I read somewhere that it would fix it because it keeps the caps charged enough to not pop when it goes off?
    Not sure how true that is as I didnt see it mentioned in more than this one place.
    Its not TOOO huge an issue, and I know it wont screw up the speakers, and its not super loud, just something I dont get with my Carver.
    If it just is what it is thats fine, just looking for ways around it if possible...
  • hochpt21
    hochpt21 Posts: 5,423
    I think I remember getting a thump with my B&K when I power off manually, but I just leave it on all the time.
  • hochpt21 wrote: »
    I may do that in the end, but I liked the fact it had a 12v trigger so I wasn't using power when I'm not around.
  • Tried to post this in a new thread, but it got flagged as spam.....
    So I think I'm in trouble here fella's.
    Had the B&K connected to my APC unit playing Cloudy w a chance of meatballs. Nothing crazy volume wise, about my standard volume for TV which is 50 out of 75.
    The APC unit tripped and went into overload.
    I disconnected the amp and rebooted the APC.
    Everything good..
    Plugged the amp directly into the wall.
    I have a hum from my right channel only.
    Doesnt matter which outlet I plug it into.
    Tried a 3 prong to 2 prong adapter, still hum
    I get the hum anytime the speaker wire is connected to the right channel even if the RCA's are not connected.
    I checked the speaker level fuse and the it looks fine.
    Am I screwed here and gonna have to have the amp looked at?
    Any ideas or suggestions recommended.
    I've got it direct into the wall with just my front 3 right now and no problems at all.
  • agfrost
    agfrost Posts: 2,474
    Sorry about your hum, Dan. Hope you get it figured out.
    About your turn-off thump, that's just what B&K's do. My ST-202+ thumps every time. I read that they all do that, and I don't worry about it at all.
    Jay
  • stupid question but have you tried different speakers, to see if the problem follows that particular speaker or just the speaker output terminal
  • Yeah, I switched what speaker was connected to that channel as well as what pre-out connection.
    No matter what I do that channel hums. Even with no RCA connected it hums.
  • mantis
    mantis Posts: 17,557
    You know I don't know why I come into these topic's when knowing it's going to make me want one again.
    I so Miss B&K and looking at your amp kills me. Now I gotta start searching for a clean 200.7 and or a 200 mono, 200.2 so I can have then when needed.
    Dan
  • BKphoto
    BKphoto Posts: 409
    mine does a little thump or whatever on start up...
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
  • MADGSF
    MADGSF Posts: 603
    Just to confirm do you get the hum when it is plugged back into the APC? For reference I use the 12v trigger and have always had my B&K connected to my PS Audio Quintet with no thump or hum. Welcome to the B&K club by the way.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
    EndersShadow Posts: 17,719
    MADGSF wrote: »
    The hum happens in one channel only, regardless of if a IC is connected, if its connected direct to the wall or the APC unit. The hum is not IN ADDITION to dialog/effects, its ALL there is.
    IE right channel is JUST hum nothing else.
    I believe the issue I had (which may not be relevant for you) is that my amp has the ability to ask for my wattage (1830 watts) from the wall than my APC unit can handle (1500) so I believe I messed something up.
    Amp will be direct into wall after this with the possibility of using this device (which shouldnt current limit the amp)
    http://www.amazon.com/dp/B0000513GY/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1KI4VB1TDNZAN&coliid=IOZEMK6B3O749
