Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
  • nspindel
    nspindel Posts: 5,343
    edited July 2014
    Ah great!
  • nspindel
    edited July 2014
    vmaxer, got your payment. Can you email me all your details please?
  • vmaxer
    vmaxer Posts: 5,116
    edited July 2014
    nspindel wrote: »
    Just sent it, please confirm you got it.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • nspindel
    edited July 2014
    All set. Just waiting to hear from Inthefade.
  • vmaxer
    vmaxer Posts: 5,116
    edited July 2014
    nspindel wrote: »
    I was thinking about getting 2 of these, was hoping we could get to 25. I really don't need to spend that much though.
    Can't wait to hear the difference.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Inthefade
    Inthefade Posts: 180
    edited July 2014
    nspindel wrote: »
    Just sent an email Nspindel. I'm in also.
    Toolfan66 Posts: 16,916
    edited July 2014
    It's nice to see this being successful, and going as planned..
    So is that a total of 12? Guess I better get busy on the cases but I'm guessing I have a couple of weeks since this will take a few weeks for these to get done..
    I know everyone has spent a good chunk of change to order the transformers, and since we have a few weeks till you guys receive them it only makes sense to wait a few, and it will give some of you guys on the funds side of things as well.
    It would be nice to know who is going to use speakons or binding posts, this is my opinion but I think everyone should go with speakons,
    1. Speakons are cheaper.
    2. The way they lock in place.
    3. There is no difference in sound
    4. I think they look better
    5. They look like it could have come from the factory this way (more professional)
    But this is up to you guys on what you want they will work either way, but I know F1, Trey, and a few other would agree with me..
    I own two of these transformers, one with binding posts, and one with speakons, and the speakons are where it's at, as a matter of fact I will be building me anothe case when I build these to change out my other one with speakons..
    Good job guys...
  • motorstereo
    motorstereo Posts: 2,052
    edited July 2014
    I'll take your good advice Larry. When the time comes I'd like my case with the Speakon terminals
    F1nut Posts: 49,805
    edited July 2014
    In case anyone is wondering what Neutrik SpeakOn connectors are and what Larry's enclosure looks like, etc.
    http://www.polkaudio.com/forums/showthread.php?142058-A-slightly-different-take-on-the-Dreadnought&highlight=dreadnought
    Take note, it was discovered that the transformer sounds better mounted in the vertical position.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    edited July 2014
    Larry, any chance I can get on the case list as well?
    edited July 2014
    ZLTFUL wrote: »
    Of course..
  • stogie
    stogie Posts: 230
    edited July 2014
    Larry, I'm in for one case w/speakon cutouts. Thanks
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • jonicont
    jonicont Posts: 277
    edited July 2014
    Speakons please. Thanks
    SDA 2BTL, VPI Prime, Soundsmith Zephyr MKIII, Rogue Ares Magnum, McCormack DNA 0.5 Gold, ARC LS-17se, Cambridge cxn v2, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • nspindel
    edited July 2014
    I strongly encourage everyone to take advantage of this run of cases Larry is doing. The transformer is not meant to sit on it's own, it's meant to be mounted in a case, and Larry's is custom designed for this exact task, his craftsmanship is incredible.
    I also encourage the use of speakons!
    Larry, can you whip me up a speakon backplate when you do these?
  • nspindel
    edited July 2014
    Also, should mention that Inthefade and I are in contact, and the official count is 12.
    I will ask Melanie when I place the order if we can add additional units if any other buyers come forward. When I place the order, our units go in a manufacturing queue, and won't actually be built for several months. If more buyers arrive, we may be able to add to our queued order as long as manufacturing has not commenced.
  • woofiepaws
    woofiepaws Posts: 214
    edited July 2014
    I would like a case with speakons please.
    MacBook Pro running Roon-Monoprice USB-Schiit Gungir Multibit-Audioquest Earth-Schiit Freya with Tung Sol 6SN7s-Audioquest Sky-Krell FPB 400cx-Audioquest Mont Blanc-1.2tls with all the mods.
  • crispybrown
    crispybrown Posts: 21
    edited July 2014
    One case for speakons for me please!
  • nspindel
    edited July 2014
    This thread has over 2700 views, and only 12 units are being ordered? Really??
  • agfrost
    agfrost Posts: 2,421
    edited July 2014
    I'd like a case set for use with Speakon connections, Larry. Thanks for your generosity in sharing your fabrication talents.
    Jay
  • voltz
    voltz Posts: 5,384
    edited July 2014
    case w/speakon's please! :)
  • vmaxer
    vmaxer Posts: 5,116
    edited July 2014
    Me too.....
    Let me know when to pay.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • South Dakota Po
    South Dakota Po Posts: 15
    edited July 2014
    nspindel please let me know what I need to do.
  • nspindel
    edited July 2014
    Ah we have another! 2 more needed and everyone saves some money! South Dakota Po, I will send you a pm.
  • vmaxer
    vmaxer Posts: 5,116
    edited July 2014
    nspindel wrote: »
    This is great, sure wish we could get to 25¡¡!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Mr_Hz
    Mr_Hz Posts: 176
    edited July 2014
    Larry, please put me down for two of your cases, both with Speakon connectors. Thanks!
    Man, great to see this come together so quickly! As mentioned, just 3 more orders and everyone saves.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • Inthefade
    edited July 2014
    Count me in for a box with speakons please
  • scubasteve4sq
    scubasteve4sq Posts: 72
    edited July 2014
    Is there still time to get in on this? If so say the word and I'll send money today.
  • scubasteve4sq
    edited July 2014
    Also Larry I'd like the case with speakon. And if your doing a backplate I'd definitely be in for a set of those as well
  • Sea
    Sea Posts: 317
    edited July 2014
    Well. Ok. I am in for one including a case with speakon cut outs.
    Is there a bottom to this rabbit hole? Neil, please let me know exactly how much to send. I think we may be over 15 now. I will paypal this morning.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • nspindel
    edited July 2014
    Hi scubaste4sq, yes there is still time to get in. I will PM you.
    At this point, I have received payment for 12 units:
    Inthefade, you're supposed to be paying me today, correct? That will make 13.
    I sent a PM to South Dakota Po already, have not heard back or received payment. If he is in, that will be 14.
    When scubasteve4sq pays, we'll be at 15.
    Once I receive payment for 15 units, I will turn around and refund everyone the difference, which will be $26.74.
    I will be placing the order on Monday so payment by Sunday is required for you to be in, although I still need to check with Melanie if we can add to this order later on.
