Does high quality digital cables matter?
13468927
  • headrott
    headrott Posts: 5,496
    edited May 2014
    Floyd Toole and Sean Olive have no real interest in stereophonic reproduction systems. They consider them fundamentally flawed and inferior to monophonic systems. That is why the vast majority of their audio tests were/are done in mono.
    The "experienced listeners" mentioned by Olive were "experienced" in listening to pre-recorded music, but were not trained and experienced in evaluating the performance aspects of a stereophonic sound field.
    I/we have discussed the Olive and Toole tests extensively on this forum:
    Stupid-things-you-hear-from-the-DBT-Null-test-crowd....
    The point that the cable difference jihadists miss is that any stereo equipment test must be done within the context of stereophonic performance. Just listening for some vaguely defined or undefined "difference" is not appropriate testing methodology for stereo systems.
    Most people who own and listen to stereo systems don't know anything about image weight, sound stage dimensions, layering, or articulation. Most people can't even tell you why a stereo system has two speakers.
    Thank you Ray for pointing these facts out. I meant to do this, and completely forgot about it.
    Also, thank you for the sexual comparisons analogy. Seems like a good one to me. :smile:
    finally, I find it funny that Habanero Monk is apparently refusing to talk to anyone that won't take time out of their busy schedule, spend more an an airline ticket than possibly they did on their ethernet cable, and put up with listening to **music from a computer system**????(that no one involved in the experiment has ever heard) to compare "his" cable to any that we would like.
    What else do we need setup to meet Habanero Monks skewed conditions?
    tonyb Posts: 33,069
    edited May 2014
    The whole cable debate thing, as tiring and silly as it is, comes down to always inexperience vs experience. There exists some in life who can't tie their shoes without a road map. If this happens...you must do that. If you use xyz cable, you must hear this. If you don't, then your missing something...or nothing at all. They rely on others opinions to justify their own. No independent thought, no experience....simple wolf pack mentality without ever being a wolf.
    Can't speak for everyone, but myself....when someone tells me this car is better than that one, that lawnmower kicks butt over all others, or xyz cable sounds 5 times better than other cables, I have to prove that to myself with a little experience with said product. I don't blindly take what anyone says as gospel.
    If you can't hear a difference, that's all well and good, but don't pretend because you can't, nobody else should either. That's what always happens in cable threads. Those with no experience trying to justify why they don't have any....instead of simply getting some.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited May 2014
    tonyb wrote: »
    No you wouldn't, otherwise you wouldn't conveniently ignore such tests that I and others have referenced. As I said, whenever a fair blind test is passed by a trained listener, it is rationalized away as "luck".
    I won't ignore them if they actually involve listening tests of cables. You're really reaching...
  • Habanero Monk
    Habanero Monk Posts: 715
    edited May 2014
    tonyb wrote: »
    When it comes to Ethernet I'm saying that you can't Tony. I have enough experience to put $1600 up. How much experience to you have to take it from me?
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2014
    WilliamM2 wrote: »
    OK, you can start with some of the original studies by AT&T Bell Laboratories on phone line cables. AT&T, and other telecommunications companies, have spent billions on audio cable research, and this was for band-limited monophonic signals. What scientific basis is there for thinking that a wide-band stereophonic signal would not exhibit audible differences when transported through different cables?
    WilliamM2 wrote: »
    No, I am listening, experimenting, offering scientific explanations for what I hear or don't hear, and publishing my results, here, and elsewhere.
    Since all you are offering is your opinion, I would say that you are the one reaching.
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2014
    So again, what cables do you use---and if they're anything but the cheapest available, wouldn't buying anything better be contradictory to your assertions?
    Here's the funny thing on this topic; though I've met many people that don't believe cables change anything (and that's fine), none of them used the 99 cent IC's that came with their components. So, my question is why not? If cable is cable, why don't you use the "cheapies" provided with components?
    Climb out of the "box" and experiment. If I do a cable change, and something doesn't sound right, that cable has to go; expensive or inexpensive---it has to go. Now you may call that foolish and "voo-doo" but at the end of the day, I don't care what you think--my dime, my system, my foolishness, right?
    It doesn't make a damn bit of difference to me how you cable your system, coat hangers or $25k IC's---because that's your decision.
  • Habanero Monk
    edited May 2014
    11tsteve wrote: »
    heck... maybe I should drive down and be the referee.
    That would be great. I wouldn't mind having someone watching the dice when ZLTFUL indicates to roll. I am considering screen casting this also.
  • 11tsteve
    11tsteve Posts: 1,166
    edited May 2014
    it would be a 45 minute flight.... barely time for 6 vodka tonics....
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • Habanero Monk
    edited May 2014
    11tsteve wrote: »
    If you are coming out with me as part of your company you better round it up to 9 :)
  • villian
    villian Posts: 412
    edited May 2014
    tonyb wrote: »
    Your arguments are valid for simple computer data transfer, however....we don't listen to data on a screen.
    Actually, we do.
    headrott wrote: »
    ..transferring and viewing computer data as 1's and 0's is "easier" for a cable than for the same cable to transmit music as 1's and 0's.
    That has got to be the funniest thing I have ever heard. Let me guess...the world is flat too?
    Too many good quotes to list..waiting for some fresh ammo. :)
  • villian
    villian Posts: 412
    edited May 2014
    headrott wrote: »
    tonyb wrote: »
    Bingo....his assertions work well for computers....not so much for sound. Which is my assertion....they are 2 different animals.
    When sound is digital there's no difference between it and anything else digital. Once converted to analog, sure. But not one second before that. Don't be so fast to write off someone who understands digital signals and computer technology better than yourself. Likewise to the other poster!
  • DarqueKnight
    edited May 2014
    villian wrote: »
    villian wrote: »
    The time relationships in a digital music signal are more complex than those of an "ordinary" data stream. Digital cables and connectors can have a detrimental effect on a signal's time relationships (jitter). Low quality digital cables can amplify the jitter effects produced by source components and DACs.
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2014
    As I mentioned earlier, there are anecdotal reports of changing Ethernet cables, and perceiving an improvement in sound. Whether true or not I don't know, but I now keep an open mind on anything audio related. Anyway, I was just reading a thread on another forum where some are saying music files from direct attached USB drives sound better than from a NAS drive over Ethernet. What is the difference? The network and it's associated cabling.
  • headrott
    edited May 2014
    villian wrote: »
    It may seem funny to you, but it is a fact. If you read page 2 and my reply there, here is an example that shows it is a fact. Did you happen to not read the rest of the post? Or did you simply dismiss it?:
    headrott wrote: »
    Exactly Tony. transferring and viewing computer data as 1's and 0's is "easier" for a cable than for the same cable to transmit music as 1's and 0's.
    As proof, I will offer up this: A couple years ago I bought some Belden solid copper core Cat 5e ethernet cable along with RJ45 ends to install onto the ends. I also bought some RJ45 crimpers costing $75.00 (NOT cheapies). I built the Ethernet cable and hooked it up to my router to transmit my online service to my compueter (I now use wireless). The cable worked fine. tranmitted data with no hiccups.
    I then hooked the same DIY ethernet cable up to my modified Denon DVD-1920 DVD/SACD player, which I installed an RJ45 output jack into and the other end hooked up to my (at the time newly built) DAC, also with an RJ45 input jack to transmit thepure DSD signalbetween the two.
    The result was that while the DIY ethernet cable worked between the my router and computer without hiccups, te same cable did not work between my modified DVD-1920 and DIY DAC. The data digital signal was not passed accurately enough between the Denon player and DAC (music). The digital data signal was passed between the router and computer with "seemingly" no problems.
    So, if they are just 1's and 0's and "just a digital data signal" why would one digital data signal work (between the router and computer, but not work between the Denon DVD-1920 and my DIY DAC?
    Answer: there's a lot more going on with 1's and 0's than what HabiMonk and other scoffers are admitting to and/or realise.
    Edit: I should point out that the same RJ45 jacks I initially installed in the Denon DVD-1920 and the DIY DAC are the same ones I used with a different ethernet cable and worked perfectly. Meaning the RJ45 jacks on the player/DAC were NOT the problem. It was the ethernet cable that was the problem and went away after switching to this cable: http://www.acoustic-revive.com/english/pcaudio/lan_cable.html
    Although I now use a modified Denon DVD-5910 as my DSD output player to my DAC.
    F1nut Posts: 51,719
    edited May 2014
    Fortunately I am going to be able to offer to setup a well structured A/B SBT at any event with 100% confidence of zero participation.
    And yet, when suggested that you come to Polkfest, you side step, dance a jig and flat out balk. Too funny.
  • headrott
    edited May 2014
    villian wrote: »
    Obviously, you do not understand digital signals (at least from a music point-of-view). Go back and read this entire thread, then please come back and talk.
    I believe it is yourself that has a "flat earth" view and are using projection to cope with it.
    tonyb Posts: 33,069
    edited May 2014
    None with Ethernet because I don't use them. Never claimed to have experience with Ethernet. But other digital cables transferring 1's and 0's I do and that's the basis of my opinions. Whats the basis of yours ?
  • Habanero Monk
    edited May 2014
    So you aren't happy that I have a potential date with ZLTFUL? So ideas on how it would work in a listening environment that isn't yours, one that you aren't familiar with.
    You don't see any downside to your ability in that scenario to discriminate?
  • Habanero Monk
    edited May 2014
    tonyb wrote: »
    I've clearly been talking about Ethernet transported audio. That is how I'm setup. I didn't say anything about SP/DIF or USB.
    Honestly the cost of the AQ USB cables are really a non-issue for me personally. I could see spending $40 for piece of mind.
    tonyb Posts: 33,069
    edited May 2014
    villian wrote: »
    headrott wrote: »
    Then please explain your experience with different cables that formed your opinion. Or did you just read it on another forum ?
  • Habanero Monk
    edited May 2014
    tonyb wrote: »
    I've clearly been talking about Ethernet transported audio. I didn't say anything about SP/DIF or USB.
    Honestly the cost of the AQ USB cables are really a non-issue for me personally. I could see spending $40 for piece of mind and very well may do that for my audio interface.
    tonyb Posts: 33,069
    edited May 2014
    Yes you have, but you clearly stated the 40 bucks is a non issue for you which suggests you are unwilling to part with anymore to find out. Which in my opinion is exactly why those who say cables don't matter are the ones trying to justify themselves not spending more money.
    I have no experience with Ethernet, none. Others on here do so I would take their advice over someone with only a one cable opinion. Does that make sense to you ?
  • Habanero Monk
    edited May 2014
    tonyb wrote: »
    I think you are speaking in general but are you saying something about the AQ USB cable I mentioned?
    Mantis made a really salient point early in thread about when a digital cable does it's job there is no more to do. I'm not advocating the cheapest $0.99 IC a person can find.
    I'm sure there are even IT guys that would laugh at a $13 patch cord from BJC. I know how data networks operate. I fully standby my statement that with a correctly functioning (i.e. meets spec) Ethernet cable you can't tell the difference. So in that instance more money is not going to get you more performance.
    Just waiting to hear back from ZLTFUL about what he meant on 3 cables instead of two. If just saying same or different 3 cables takes him from a 50/50 chance at being right about a simple change up to 66%. If it was 10 network interfaces it would be a 90% chance in his favor that something changed.
    Now it it's tell me if what is currently playing is A/B/C then that is another matter entirely. Just waiting for clarification so we can move on to next steps. Looking to close the loop and get air fare ASAP.
  • PSOVLSK
    PSOVLSK Posts: 5,373
    edited May 2014
    If cables don't matter, why would you not advocate this.
    On a lighter note, the cheapest $0.99 IC I've been able to find cost $0.99:)
  • Habanero Monk
    edited May 2014
    PSOVLSK wrote: »
    I didn't say cables don't matter. Jeez...
    In the context off CAT6 cables it is OBVIOUS cables matter. All the testing BJC did shows a ton of cables failing even though they advertise CAT6.
    I'm saying after you have, lets say a 6 ft patch cable, that passes NEXT/FEXT (near and far end cross talk), inter-pair skew, round trip latency (delay) and the thing is 25% over tolerance, what else is there to do?
  • PSOVLSK
    edited May 2014
    I guess I'm missing something here. What's the point of the big blind A/B/C test then?
  • BlueFox
    edited May 2014
    Since this is a contrived test it will not prove anything. If ZLTFUL is able to identify the cables then we have a piece of data, but if not then we are still at ground zero with no data.
  • Habanero Monk
    edited May 2014
    ZLTFUL wrote: »
    It isn't that difficult. 3 different "levels" of cable connected to 3 identical NICs. Plain and simple.
    Your BJC, my Cat5 Belkin and my "high dollar" Cat6 cable.
    We make some baseline comparisons to "get my bearings" and then I tell you, out of 30 runs if it is A, B or C. (I am upping it to 30 to give each cable a "fair shake".)
    I am allowed to take notes on each of the baselines and am able to take up to 3 complete albums per cable to generate the baseline.
    My proposal of 3 cables was simply to lower the chances of me simply guessing correctly. Taking my chances of "guessing" from 50/50 to a 33.333333...% chance of simply guessing right. In reality, I am weighting the test in your favor. Not sure why that doesn't appeal to you.
    I was just establishing that you are indeed going to tell me A/B/C. So you are going to stone cold tell me which is which when the dice is rolled.
    So on a six sided dice: A= 1-2 B=3-4 C=5-6. You obviously don't know the result you just tell me to make the roll. It will be change, no change. You tell me if its same or different and if different then which.
    I have an AMD based mainboard with three PCIe connectors so 3 cards shouldn't be a problem.
    How long to do you want to take? I was thinking 1 day. I come in on a Friday and out again on a Saturday. My other concern is if it's a day of thunder storms like yesterday here. Not much one can do about that though it is what it is.
  • Habanero Monk
    edited May 2014
    PSOVLSK wrote: »
    Testing a claim that even though an Ethernet cable passes CAT6 spec that there are still audible improvements to be gained in a typical computer networked environment.
    There are $70-$500 Ethernet cables out there.
    In the case of Ethernet they do matter. If you have a cable that has skew in the 100ns you could certainly have some performance issues.
  • Habanero Monk
    edited May 2014
    BlueFox wrote: »
    If ZLTFUL can't hit the 86% mark on what cable the dice indicate that is indeed data. I still don't know what possible, real world based objection you could have.
    Given that typical GB Ethernet runs can certify out to 20 meters the lengths we are talking about are trivial.
    Plan also on making sure the same nic silicon is used.
