Polk Audio SDA SRS Modification Thread Part 2 - The "Ultimate Build"
VR3
So I have the rare opportunity for someone to bring me the speakers in person! They are making the trek from Virginia -
Will start the thread and update it upon completion -
Specs of the build -
Tweeter Network -
Clarity Cap MR 400v
Clarity Cap ESA 250v
Duelund Resistors
Jantzen Inductors
Supra Rondo 13 awg Internal Wiring
Midbass/SDA Network -
Clarity Cap MR 400v
Jantzen Inductors
Jantzen C-Coil SDA Inductor for the lowest possible DCR
Other Features -
Updated shelf design - will be mounted inside the enclosure, front to back with a "flipped" front that opens up to a clear lexan window on a custom built faceplate that will be built for a beauty view of select parts, most likely a Duelund resistor and two MR caps and an engraved plate. Will be looking into a battery powered led with a switch to light this area up. Custom rounded handles, little wider than the stock flat handles for a more modern design.
Clear lexan substrate versus delrin, .25" thick - will be using tech flex/heat shrink for the internal wiring for the cleanest look
9 AWG SDA Cable, NL4 connection
Custom round aluminum termainl plate
WBT Binding Post
Hurricane Nuts for all screw locations
Dynamat driver baskets
No Rez or Sonic Barrier for the enclosure walls
"Custom Bass Brace" that is a "cage" design that attaches on four points on the back of the speaker with head duty rubber isolation mounts that will aid in an earthquake as well as accomplish the point of the original bass brace.
Attached is a concept of the original chassis design which has already changed.
Tweeter Network -
Clarity Cap MR 400v
Duelund Resistors
Jantzen Inductors
Clarity Cap MR 400v
Jantzen Inductors
Other Features -
WBT Binding Post
Post edited by VR3 on
Looking forward to your progress in this Trey!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
wow...impressive...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Trey,
This will be great to follow!
Please, post lots of pictures early and often.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
1st Quarter Update!
After extensive R&D on the new shelf platform I came up with a fully isolated design that will be a three piece build. I am excited, the fabricator is building them now. Very excited about this build.
I upped the aluminum to 1/8" thick, 6160, the front panel is 1/4" thick and the Lexan substrate is 1/4" thick. All aluminum hardware will be used on the shelf system as well.
Pictured below is the internal wiring and No Rez installed.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Another great looking mod TreyHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Thank you! I am still a few months out. I will post pictures of different parts ad they happen.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey,
You are quite the teeze!
Keep the pictures coming, please. This looks exciting!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Since those were delivered makes all the sense you would take on that big boy project. When done I'll be very intersted to have a look at the see through features ala the glass back Ferrarris that show off the v12. Do you also take in on shipped items regular sized speakers to do whatever they request? Btw the cross overs settled in beautifully and listeng to them right now. Again can't thank you enough to work w/ me and then the whole mis delivery deal which really scared me. It all worked out.
Lew.....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Slowly forming into a bad **** chassis- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Fairly excited to use Lexan on this project, at 1/4" thick it is beyond strong and has been very interesting to work with so far- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Slowly building up the boards, love the way the lexan is looking https://us.v-cdn.net/5021930/uploads/editor/5c/nbrdswjoo8ep.jpg
https://us.v-cdn.net/5021930/uploads/editor/wa/mrcx5esc9e0d.jpg- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Wow! Looking good!Home Theater
Two Channel
Somehow, "wow" seems like an understatement. Can't wait to see the finished product and read the extensive review!
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
Ok, after many designs and a lot of thrown away pieces we had to find a handle design that worked. We went with a throw back of the old but more substantial, milled from 1" wide, 1/2" deep aluminum
This will come together quickly, everything gets painted soon and everything will be pre-wired
before it goes on the chassis
That is pretty darn cool. Kind of looks like sticks of dynamite in there.... lol!HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Talk about motivation to make the drive. The custom "built for" engraving.
Nice touch. -
Thanks guys!
Cant wait to see what these look like with the faceplates black and the chassis white. We are also installing an adjustable battery powered blue led inside the cabinet to back light the part you can see!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
This is the definition of tedious- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey,
It may be tedious work, but it looks like another fantastic product of Vr3Mods!
Looking good!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Thanks Phil!
I will get to start posting pictures of yours soon enough! Alot of the way yours rip be built will be taken from here!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm looking forward to seeing pictures!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Starting to (slowly) see the finish line
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Fantastic work VR3!!!
Thank you
My goal is to have minimum visibility of wire on all parts of the build even though the substrate is clear.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey, your work has evolved into something quite awesome. Those white panels are great.
Question, how do the transformers work in this build?Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
although you could probably get a ferrari for what you have in those SRS's...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
