Will this be a problem? I DynaMatted my PS . . .
GlennDog
My Cary . . . my sweet little pre . . . my SLP-98 . . .
Today I Dynamatted the Power Supply cover and it gets quite warm. There are no stock openings/holes for ventilation. Prior to being modded, I didn't notice any excessive heating, but then again it was in a different location . . .
Thoughts?
TY
G
p.s. I was into the "I Dynamat Everything" mode . . . Maybe not such a great idea?? IDUNNO . . .
Thoughts?
TY
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
What's inside the box? The only issue I can think of is if the box itself is used as some sort of heatsink, but I doubt that's the case.Political Correctness'.........defined
President of Club Polk -
Perhaps some pics would be in order...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
The power supply box on the right is what seems to be getting warmer than it should. Pix suck, but you get the idea. No heat sinks at all or ventilation openings, unlike the good Aleph 30 (that will need to be upgraded soon).
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Owners manual refers to the black box as a power pack. It has an On/Off switch and connects to the "body" of the preamp through an umbilical cord . . . I defer to you folks in the "know"
TYAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Ok, well there are some heatsinks, but they are on the outside above and below the cord. Those heatsinks are mounted to the case, so you can expect heat transfer. By adding the Dynamat it would hamper heat dispersion.
I'd still like to know what is inside, can you take a pic?Political Correctness'.........defined
I'll try to post pix this afternoon . . . gotta shovel this white stuff falling from the sky!!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
I'm curious why you did this? What's the benefit? Is the power supply noisy?Dan
I didn't think it would be detrimental. The really weird thing is that after playing tunes last night (and for quite a while), the power pack did not get anywhere near as warm as the night before.
The first pic is the end where the PC is attached
Third pic is the side where the signal exits into the umbilical cordAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
I've seen almost "everything" you can imagine covered with this material on this site, sometimes it's almost like watching an old peddler selling Dr. Excelsior's "cure all" elixir out of his covered-wagon!
Then again, people sometimes "stumble" onto something that works by pure accident because no one thought of applying it "there" before?
I'm not seeing anything to concern yourself with. Like I said before, those heatsinks will transfer heat to the case and the transformers will also generate some heat. Unless the case is hot to point you don't want to touch it, no biggie.I'm curious why you did this? What's the benefit? Is the power supply noisy?
Airborn and physical vibrations affect the signal. Applying Dynamat Extreme is an excellent way to deal with that issue. If that were mine, I would have applied Dynamat Extreme to the transfomers as well.Political Correctness'.........defined
The system has been running for 3-4 hours now and No Excessive heating . . . Why would it have been so Very warm the first time after Dynamatting? I don't get it
F1 . . . see anything in there of interest?
I wonder if there is a way to upgrade/improve the power pack or umbilical? Cary offers nothing in those termsAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
What I was thinking . . . ThxAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Interesting. I didn't realize this was an issues with external power supplies. Would it not be more beneficial to use some kind of exterior Isolator? Is this how the Dynamat is applied? I didn't see it in the pics.I'm not seeing anything to concern yourself with. Like I said before, those heatsinks will transfer heat to the case and the transformers will also generate some heat. Unless the case is hot to point you don't want to touch it, no biggie.
Airborn and physical vibrations affect the signal. Applying Dynamat Extreme is an excellent way to deal with that issue. If that were mine, I would have applied Dynamat Extreme to the transfomers as well.Dan
Interesting. I didn't realize this was an issue with external power supplies. Would it not be more beneficial to use some kind of exterior Isolator? Is this how the Dynamat is applied? I didn't see it in the pics.I'm not seeing anything to concern yourself with. Like I said before, those heatsinks will transfer heat to the case and the transformers will also generate some heat. Unless the case is hot to point you don't want to touch it, no biggie.
Hard to say.
Just the usual stuff.
There's always a way to upgrade. :cheesygrin:Political Correctness'.........defined
It's an issue with a lot of audio gear, be it an amp, pre amp, CDP, etc. Chassis/case and component damping is one of the things you pay for in high end gear. For example, Joule pre amps use a unique suspension system to isolate the signal board from vibration and the chassis/case are covered in a damping material.
Yes, good feet or other isolation devices are always a benefit, but if the chassis/case are thin gauge steel it'll still ring, so applying Dynamat Extreme would still be a good idea.
It would be applied to the interior of the chassis/case wherever there is bare metal. Of course, this is more important with thin steel than it is with heavy gauge aluminum.Political Correctness'.........defined
