whats next?
124
    tonyb Posts: 33,072
    edited October 2013
    Ohm's law ?? Fantastic.....if your an electrical engineer, but means diddly squat in how a piece sounds. Way too many variables besides "ohm's law" go into an amp.
    tonyb Posts: 33,072
    edited October 2013
    SCompRacer wrote: »
    I'm thinking you are not that stupid, you are here just to cause problems.
    Hence the name....Jester. He just forgot to put "court" in front of it.
  • thsmith
    thsmith Posts: 6,082
    edited October 2013
    Jestered wrote: »
    Going used may or may not be my choice. I've been looking at used amps for about a month now, but it seems people are wanting the same for their used amp that I could get it on Amazon for. Now that I have a better understanding outside of simple Ohm's Law, which some people still don't get, then that also allows me to better know what to look for in an amp.
    I think you are full of it or you still dont know what you are looking for in an amp because Amazon does not carry an amp worth considering. A few integrateds and AVRs but no stand alone decent amps. There are some $27 amps but like I said decent.
    If Amazon is your source for amps then good luck. You must be a troll.
  • thsmith
    edited October 2013
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2013
    Jestered wrote: »
    Do you mean 'get' in the sense that Ohm's Law, which uses basic algebra, applies to DC circuits. On the other hand, AC circuits require calculus to solve. Since amps are AC circuits, the simple DC circuit Ohm's Law doesn't apply.
    tonyb Posts: 33,072
    edited October 2013
    BlueFox wrote: »
    C'mon Fox....you played that card too early. Now you snatched some entertainment value out of the thread. What am I suppose to do with all this popcorn now ?
    pitdogg2 Posts: 27,070
    edited October 2013
    tonyb wrote: »
    Sneaky flying squirrel looking around corner.....
  • BlueFox
    edited October 2013
    Sorry. Wasn't thinking straight. Got up to early this morning.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    thsmith wrote: »
    You guys just don't give up. It's laughable at this point.
    Where exactly are you looking on Amazon? Is this not at least a decent amp?
    http://www.amazon.com/Parasound-Five-Channel-Amplifier-5250/dp/B000EOJ74M/ref=sr_1_2?ie=UTF8&qid=1381947904&sr=8-2&keywords=parasound
    Samsung 65" ES8000 LED
    Pioneer Elite VSX-53
    Polk RTiA5's - Front Towers
    Polk CSiA6 - Center Channel
    Polk RT15i's - Side Surrounds
    Polk FXiA4's - Rear Surrounds
    SVS PB-1000 - Subwoofer
    URC MX5000 - Remote
  • falconcry72
    falconcry72 Posts: 3,580
    edited October 2013
    Hey Jestered, when you're starting to narrow down amp choices, make a new thread about what you're looking at. There is a lot of experience here that can help you achieve your desired sound. Good luck on the hunt.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    Thanks falconcry72. I appreciate it!
    URC MX5000 - Remote
  • falconcry72
    edited October 2013
    Jestered wrote: »
    No problem. The thing about amps (and preamps, DACs, etc.) is that they could bench/spec the exact same, yet sound different. So unless you want to audition every amp out there in your own system, it is very helpful to piggyback on the experience of people who have actually spent time listening critically to multiple designs and done A/B comparisons in their own systems.
    Keep in mind, this is a forum for audiophiles, not electrical engineers. What we may lack in the ability to describe the "how" (why does an amp sound a certain way), we make up for in spades with the ability to describe the "what" (what does an amp actually sound like, compared to other designs).
    I can't tell you exactly why my amps sound different from each other, but I can give you real-world experience from comparing and critically listening to literally dozens of different designs over just the last couple years alone.
    There is no theoretical substitute for actual experience via trial and error.
    F1nut Posts: 51,794
    edited October 2013
    He got that from the same severely misinformed person that thinks all SS amps sound the same.
    Amazon? Certainly not the first, second, third, fourth or fifth place one would think to look for a quality amp. Audiogon is usually the default choice.
    SCompRacer Posts: 9,112
    edited October 2013
    Wattage specs would be great if all manufacturers used the same standard to measure them, or at least state what standard was used to get them. THD is another spec that could be expounded upon. You get a fixed amount but don't see when and where the distortion occurred. A distortion analyzer will show what types of distortion, the amounts of and where it occured throughout the audio frequency range. A real visual eye opener you can relate to what you heard. Maybe too much info for some folks.
    Another visual way is to put a scope on your speaker terminals. When music is playing, it looks like a crack addict playing with an etch a sketch. You can adjust settings to get a smooth sine wave and increase power to see if you lop their heads off (clipping). The other way, as stated, is connect a better amp and play at same low and max dB you would listen to. You start hearing more details or everthing the artist intended on the recording, you are golden. You don't know what you are missing until you hear the same material on something better. To me that is what an audiophile goes for. Others are content without that. And I don't want to hear how detail is always strident and painful cause it is not always the case.
  • headrott
    headrott Posts: 5,496
    edited October 2013
    Jestered is using a classic example of Hegelian dialectic. You present a problem to which you already know the solution, but cause those around you (the Polk Forum in this case) to endlessly present the solution (the truth) yet he acts as if he doesn't realise what that solution is and thus causing the Polk Forum members to endlessly keep presenting the solution to which Jestered already knows the answer (whether factual or not). The person (or people) (Jestered in this case) then continues his steering towards anarchy by "never realising" the answer to the presented problem and the cycle continues. (That is, the solution the problem presenter (Jestered) is seeking, that is anarchy and chaos).
    Please go "play" somewhere else Jestered.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    headrott wrote: »
    Either you're trying to sound smart, or you don't really "get" Hegel's philosophy. Hegel's "philosophy" goes much deeper than the simple explanation you've described. You can twist my question how ever you'd like, but the simple fact is that I asked a question. Nothing more and nothing less.
    URC MX5000 - Remote
    F1nut Posts: 51,794
    edited October 2013
    BOZO listed.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    1nut- Why do you keep chiming in?
    URC MX5000 - Remote
    F1nut Posts: 51,794
    edited October 2013
    This message is hidden because Jestered is on your BOZO list.
    Ah, much better!
  • Jestered
    Jestered Posts: 49
    edited October 2013
    BOZO listed.
    At least you came up with a new name. But, again, why do you keep responding?
    URC MX5000 - Remote
  • Jestered
    Jestered Posts: 49
    edited October 2013
    Ah, much better!
    Thank you!
    URC MX5000 - Remote
  • headrott
    edited October 2013
    Jestered wrote: »
    Excellent! "We" simply answered the question multiple times. Nothing more and nothing less. Please move along before you wind up on others' BOZO lists.
    F1nut Posts: 51,794
    edited October 2013
    Anyone else think mindless and jestered are the same person? I mean, the odds of 2 people being like that are astronomical.
  • headrott
    edited October 2013
    It's funny Jesse, I originally almost posted a question asking Jestered what other screen name(s) he has used......... I decided on my response above however.
    F1nut Posts: 51,794
    edited October 2013
    Just proves that great minds think alike :)
  • BlueFox
    edited October 2013
    I think they are different. Jester doesn't stick question marks in the middle of his sentences.
  • Jestered
    Jestered Posts: 49
    edited October 2013
    headrott wrote: »
    If it means you will stop responding, then PLEASE put me on your list! I'm begging you...
    URC MX5000 - Remote
  • headrott
    edited October 2013
    Jestered wrote: »
    Why do you insist on taunting others?
  • Jestered
    Jestered Posts: 49
    edited October 2013
    headrott wrote: »
    Ha! Now that's funny! Who exacatly am I taunting? I've been attacked over and over again in this thread, but yet I'm taunting? You sir are delusional.
    URC MX5000 - Remote
    txcoastal1 Posts: 13,513
    edited October 2013
    All I know I have plenty of gear to swap around. That being said I have a 100 watt AVR that distorts a pair of speakers before one of my higher end 60 watt amps measured at the same SPL...proof is in the pudding
