Computer Audio Guys List Your Rig!
System: Home built i7 quad core, 18GB RAM, 5TB (2TB SSD, 3TB Sata 3 RAID), nvidia Geforce x660Ti
Output: Schiit DAC on order, mean time X-Fi Platinum output to Pioneer DJM600 Mixer into a DBX Driverack PA into Crown CE2000 amp, then to Polk LSi25's.
Sounds amazing and Battlefield 3 is a blast! Soon to hook-up my Polk RT1000p's for back surrounds, then just need to find a good Center now.---
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000 -
For now, works and sounds great.
Dell laptop w/Vista32/foobar 2000
foobar ASIO, WASAPI, SACD modules
ASIO for DSD
Amanero 1.056 device driver
1 TB USB music drive
Amanero OEM Combo384 USB to I2S module in DIY Buffalo III dual mono DAC (ESS Sabre32 Reference, ES9018's).
44.1Khz to 384Khz sample rates, Native DSD 2.8224 Mhz - 6.144 Mhz
http://amanero.com/
Connected to main system in sig.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »foobar ASIO, WASAPI, SACD modules
ASIO drivers
I'm curious as to the benefit of using ASIO and WASAPI together. It's my understanding that they both accomplish the same objective.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
I need ASIO for native DSD (SACD) channel mapping support.
EDIT: There is a custom channel mapping thing going on to swap the R and L channel DSD reversal versus PCM playback. It is done in software versus a hardware switching solution. I had to do hardware switching to correct the SACD channel swap in the Denon 3910 I modded to export CD/SACD to the DAC via I2S.
Details here, cause I am not smart enough to come up with this on my own.
http://hifiduino.wordpress.com/category/computer-hw-and-sw/
That makes sense. Thanks for the info!!
EDIT: Are you having to switch output formats each time you go from SACD to other encoding?2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
You are most welcome!
In order to have the SACD channels correct, yes I have to switch output format. I am fairly sure WASAPI will do DSD too, but you would still run into the R and L channel swap using it with my setup.
In players, some DAC chips share PCM (CD) and DSD (SACD) circuits into the DAC chip from the transport. So you connect to your external DAC and can play CD and SACD via I2S out (I2S separates clock from data where clock is embedded in the SPDIF signal). What happens is DSD uses individual circuits for R and L channel. If they don't follow the connection order you have at the external DAC, your R and L channels are swapped when playing DSD. I had to use a digital swich in my modded Denon 3910 to correct that for output to my external DAC. It is controlled by a manual switch on back of the Denon.
This is my first USB to DAC thing, and I made it more complex with all the options.:eek::cheesygrin: Before I was just SPDIF coax out or I2S out from a modded SB Touch.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
PC rig update:
- now using a Stello U3 USB converter via AES/EBU out.
This thing kicks major butt.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
My Rig,
Custom built PC Windows 7 32bit
GeForce GTX 560 Ti HDMI to Receiver
MediaMonkey WASAPI Output through HDMI in Exclusive Mode with tweaked settings to prevent crackling and distortion during playback and switching between songs. Bitstreaming.
All FLAC library
I would like to apologize for digging an old thread but I really need to know somethings.
I'm a complete noob at this but does anyone here use HDMI for output to their receiver? I went through most of the rigs here but couldn't seem to spot a single rig that uses this. Almost everyone is using USB DACs and optical out etc. -
ThirdWorldGuy wrote: »My Rig,
All FLAC library
I use onboard sound and toslink to an older Onkyo 603 receceiver. Radio Shack Optimus Pro 77's modded with Polk Monitor 70 tweeters and and Polk R15 woofer. The receiver and Mirage Omni S8 sub are under my desk.
AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
Sub-Velodyne SPL-1000R -
Foxconn E-350 based NTA350. Has a SSD drive. Win7 using ASIO. FooBar
Focusrite Scarlett 2i4
Yamaha P2500S
For sub duty I use another out on the Scarlett and feed a Behringer EPX2000
And sub (DIY dual opposed Infinity Kappa 120w.9)
And LSi 9's. Looking at seeing if the PSB Stratus Silvers on CL near me will be an upgrade. I can sell these and maybe break even. The seller is asking $275 for them. -
EndersShadow wrote: »Office setup
Custom PC: ASUS P5E | Intel Q9650 @ 3.6 | 8 Gig Dominator 1066 | ATI 5450 | 2 WD Black 640 | Samsung 1TB | Corsair VX450 | Antec P182
XBMC
Audio GD NFB-5
Polk Ultrafocus 8000's (demo pair)
Thought I would update my first post as most of this is done...
Office Rig:
Custom PC:Interface: XBMC streaming FLAC and hi-rez audio, Pandora, etc- Motherboard: ASUS P5E
- CPU: Intel Q9650 @ 3.6
- Memory: 8 Gig Dominator 1066
- GPU: ATI 5450
- Hard Drives: 2 WD Black 640, Samsung 1TB
- PSU: Corsair VX450
- Case: Antec P182
- Extras: Noctua NH-U12P Cooler
- 5 x Noctua NF-P12 case fans
- NZXT Sentry LX fan controller
- Hauppauge WinTV-HVR-2250 Tuner
DAC/Headphone Amps: Audio GD NFB-5, Meridian Explorer
Pre-Amp: Sunfire TGA-II
Amp: Fisher 460a tube amp
Speakers: Polk RTA 11TL's
Headphones: Beyerdynamic DT-770's 32 ohm
[/LIST]EndersShadow wrote: »Soon to be:
Custom PC ordering parts soon
XBMC
USB Cable undecided on brand
Audio GD NFB-5
Beyerdynamic DT-770 80ohms (tenative choice)
Work office setup:
Custom PC:Motherboard: ASRock A75M-ITXInterface: XBMC streaming FLAC and hi-rez audio, Pandora, etc
CPU: AMD A6-3500 2.1GHz FM1 65W Triple-Core APU
Memory: 4 Gig Corsair DDR3 1333
Hard Drive: Samsung 1 TB 2.5"
Case: Wesena ITX-6
PSU: City Net 150 watt pico psu
Extras:
Headphone DAC/AMP: Audio GD NFB-5
Headphones: Beyerdynamic DT-770 32 ohms"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Custom built HTPC
- Silverstone Grandia case
- Gigabyte MB - i5 3.1Ghz, quad core cpu, plenty of RAM, plenty of disk
- Fanless Zotac video card
- vm-ware desktop - several virtual pc's
- XBMC 12.2 Frodo
Denon 3808
- PA SDA-2B
- Paradigm 12" sub
- Paradigm reference center channel
- Paradigm di-poles in the back
- Epson 6500 projector
- 120" Carada screen
Apple TV Gen 1 160 GB
- running xbmc crystalubuntu
- streams content from HTPC over home gig network
- Panasonic 42" LCD TV in MB
- Sharp Aquos 46" LCD TV in FR
Raspberry Pi
- not running yet but plan to use xbmc and attach to another TV in LR -
Another custom built HTPC here.
-Zalman 160xt plus case in black
-i7 3.4ghz quad core cpu
-580 vid card
-16gb of ram
-8TB of HD space, plus a SSD for the OS.
All of that connects to my new Denon receiver via HDMI, sound outs to my Rti-10 set up in the living room, while video runs to my 46" Sony LCD.
Teamfortress is a whole new level of joy on a 46" screen with the Rti's rumbling.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
I've got a real simple set-up:
Antec case
MSI GXM890-G65 mobo
Phenom II X6 cpu
500gb hdd
8 gb of ram
LG BD-ROM/ DVD-RW
I've just got the optic going into the SC-05, with the DVI going into the Samsung 40", and no GC. It died over a year ago, and since I'm not really into games anymore, see no need to replace it.
I've got an old Soundblaster external sound card, but, the sound quality straight off the mobo is good enough.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
My modest setup, sounds great to me!
* HT Omega Claro Halo 24/196KHz soundcard
* Polk TSi 500 speakers
* Yamaha RX V473 AVR
* PC / Linux with AMD 8 core and 16GB, use quodlibet for playing music -
Custom PC: And another gutted ComPaq box, full blown build, for re-ripping ALL my CD's (Long Story) 8^(
Lenovo H405 Box & MoBo (At least 4-1TB and 3-500GB HDD's layin around. Lost count)
3.2GHz AMD Athlon II Quad Core, 8GB Ram, dual 80mm push and 120mmPS & 92mm pull fans
W7-HP 64bit, All silent settings, MS-Config'ed-minimal bs running in background, USB-full power, No-power saving modes anywhere, Media Center-hacked up-grades, DB Power Amp rip software, WASAPI Audio Exclusive Mode. (A little more work than you Apple Boys)
Intel-Pro Gigabit NIC Card-No hits, misses or errors.
Samsung 22X DVD/RW SATA Drive SH-S223C (2) Because I am gonna wear em' out re-ripping again 8^(
Asus-ATI Radeon 6540-DVI/HDMI/VGA W/120mm fan blowing on it and, N&S bridge heat sinks
Pangea Audio - USB cable 24awg -Ohno-PCOCC & 4% tinned silver solder on all 4 conductors - 1 Meter
SonicWave-Corning Glass-Toslink Cables (1 Meter) (2) (No Jitter Bugs or EMI/RFI)
Music Fidelity 24/96 V-Link II-W/ WASAPI Exclusive Mode-Worth every penny! Massive jitter reduction!
Sony SDP-EP9ES Digital Signal Processor (24bit/44.1/48Khz processing)
Just arrived intact! Score! For optional jitter reduction (If needed) & Parametric EQ, Surround Modes, Input Leveling, Optical Out & 5.1 Analog In options (Or maybe to my SONY museum)
Feeding To:
Marantz SR5007-(Slays my now gone, Onkyo TX-NR809 for audio) (Miss a ton of video features though)
Parasound HCA1200 MK II- 205 real watts RMS x 2 @8 Ohms-325@4 Ohms (Soon to be Re-Capped)
Polk RTi70 Tower Speakers-(Rebuilt XO’s) Bi-Wired & Tied to Parasound
Polk Monitor 40’s (For Now)(Rebuilt XO’s and braced/damped boxes) Bi-Wired & Tied to the Marantz
My custom built M40 speaker stands to have same height as RTi70’s
Velodyne CT-150-15”-275w Sub-12/24db Slopes (New PS Caps and Amp Module)
SONY DVP-S9000ES DVD/SACD/CD Player (Still great with up-scaling 1080P receivers)
SONY RDR-GX330 DVD Recorder (The only recorder I’ve found that records everything)
Sony BDPS1000ES Blu-ray Disc Player
SONY CDP-CX-90ES-200 Disc CD Changers (2) (Re-Capped) W/On-Screen Display-Daisy Chained=400 CD’s
SONY TC-K615S-Dolby S/B/C Cassette Deck (For ornamental nostalgia now & the SONY museum)
Could list the SONY Museum, but I have a headache already. 8^)
Pablo -
P.S. Looking for a cheap DAC?
The Sony SDP-EP9ES Digital Signal Processor makes for a pretty damn nice DAC, stand alone...
All proprietary SONY chips and massive filtering/jitter curcuits.
GooglyIt.
Pablo -
AsSiMiLaTeD wrote: »Anyone on the PC side using or tried JRiver?
Yep, I now own it and have it for both of my computers. I love it after leaving itunes. I am still learning about it.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
recently built my HTPC.
Corsair 550D
Corsair Liquid Cooler 60
I7 4770
16 GB Ram
250 GB Samsung Pro SSD
Asus Z87 Deluxe Mother Board
Asus Xonar Essence STX
Pioneer Bluray BD2208
Seagate 4 TB Media Disk (Flacs)
J river Media Player -
bigaudiofanatic wrote: »Yep, I now own it and have it for both of my computers. I love it after leaving itunes. I am still learning about it.
+1 Loads of options... Worth every penny -
AUNE T1 + DT770's right now.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I know with WASAPI I only get 24bit, and have to use ASIO for 32bit support and with Vega DAC.For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
Asus laptop w/LMS-->WD USB HDD (flac files)-->Modem/router-->Squeezebox Touch w/Channel Island Power Supply-->Benchmark DAC/PRE-->Placette Passive-->Parasound HCA1500A amp-->Harbeth 7ES-3 monitors
Kimber Hero IC's
Kimber 8TC v.2 speaker cables
Belden 1694A digital coaxSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Custom built Game rig (old one)
Win XP
Squeezebox LMS 7.7 ****
Win MP for burning CD's (320kps for use both in home and cars)
Intel P4 3.0Ghz
2GB of ram
Linksys Wireless Adapter w/speed boost 9db highgain ant (running off wireless Home network)
(3) 80GB HD
Ext 350 GB HD (main music source)
Ext 1.5 TB HD (backup for whole house)
Plextor DVD/CD burner
Sony DVD/CD burner
3 sets of fans
500/W Thermaltake PSU
System runs 24/7 in garage
Supports:
3 Classics V3
Touch
TransporterFamily Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
Reused an old Pentium4 2gigs of ram computer, using an old soundblaster live card. Was running win xp listening to The Breeze over 181.fm but when xp wouldn't update codec's for The Breeze I switched to Ubuntu. Running this thru pre amp to Halo a23 amp.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
updated rig.....AMD FX-6100 @ 4.55 ghz, XSPC liquid ... Win 7
crossfired 6970
Corsair 120 G ssd
HT Omega
Tributaries Series 5 optical
Matrix Mini DAC (which i would like to replace with a Keces)
Acurus RL-11
Parasound HCA 1200 II
Polk RTA-11T (updated Xovers, RDO-194, rewired, damped drivers, Armacell gaskets, spiked)
music is in AIFF format on a 1TB WD cloud drive.
i have tried Media Monkey and Foobar and haven't decided. my drives are due for a reformat, so i'll figure this out then.
currently in search of new cabling as most of mine is cheap crap....
AMD 8350 8 core, currently at 4.8 Ghz. under custom liquid loop.
Sapphire 6850
Mushkin 120 Gb ssd and Windows 7 64 bit
HT Omega with Grover Huffman D.I.
Peachtree Dac-It with Morrow M4 custom Y-cable going to both headphone and listed rig.
speakers change between the updated RTA11T, Infinity RSb, and a pair of 5JR which are next up for refurbishing.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Updated:
J. River MC19 + Auralic ASIO (sometimes JPLAY 5.2) PCM2DSD playback and PCM/DSD playback
NAS - Synology 411j 12TB Raid 5 8TB + (3) 4TB SATA internal
File Types - .FLAC .DFF .DSF .MP3
PC - CoolerMaster SilverStone Fortress FT03 Mini-Tower, Quad-Core i7 at 4gHz 16GB RAM, Windows 7 X64
USB Interface - Adnaco S3B USB-over-fibre on 5v battery
DAC - Auralic Vega
Amp - Decware EL34.1 ("Rachel")
Speakers - Zu Union CubesFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I forgot the 8 GB of Gskill Ripjaws 8-9-9-24 @ 1866, and that Jriver is my preferred media player.....updated rig.....
Sapphire 6850
Keces DA-131 mk.II
+1 on the Ripjaws
Mine is more focused on games but I do use it for music too.
Im at the last stages of a rebuild so I havent decided if im going to stay with the onboard or go back to x-fi or a newer sound blaster card.
I could also skip the sound card and stick to the USB Music Streamer II Dac for music.
http://highresolutiontechnologies.com/music-streamer-ii
System specs are
Intel i7 3820
EVGA X79 4-way SLI Classified motherboard
16GB DDR3 2133 XMP -RipJaw Z series
Vertex 4 SSD
XFX R9 290 in TriFire ( three video cards)
ABS 1100w BZ series PSU
Windows 7 64bit Pro edition
Three Acer 24" H233H monitors @ 5760x1080p
Custom full system Water Loop. CPU, motherboard, and videocards.
for Audio im using a Rotel Pre and Amp and some Free Bose speakers with a Sunfire Sub.
heres an image. http://postimg.org/image/ezgs8v6s5/
image with a more completed water loop. http://postimg.org/image/wvhomcjjp/B&W CM9Classé Sigma
