Computer Audio Guys List Your Rig!
  • KellyMic
    KellyMic Posts: 166
    edited January 2013
    System: Home built i7 quad core, 18GB RAM, 5TB (2TB SSD, 3TB Sata 3 RAID), nvidia Geforce x660Ti
    Output: Schiit DAC on order, mean time X-Fi Platinum output to Pioneer DJM600 Mixer into a DBX Driverack PA into Crown CE2000 amp, then to Polk LSi25's.
    Sounds amazing and Battlefield 3 is a blast! Soon to hook-up my Polk RT1000p's for back surrounds, then just need to find a good Center now.
    Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
    Crown D-75, Crown CE1000, Crown CE2000
    SCompRacer Posts: 8,361
    edited January 2013
    For now, works and sounds great.
    Dell laptop w/Vista32/foobar 2000
    foobar ASIO, WASAPI, SACD modules
    ASIO for DSD
    Amanero 1.056 device driver
    1 TB USB music drive
    Amanero OEM Combo384 USB to I2S module in DIY Buffalo III dual mono DAC (ESS Sabre32 Reference, ES9018's).
    44.1Khz to 384Khz sample rates, Native DSD 2.8224 Mhz - 6.144 Mhz
    http://amanero.com/
    Connected to main system in sig.
  • Tbone289
    Tbone289 Posts: 661
    edited January 2013
    SCompRacer wrote: »
    ASIO drivers
    I'm curious as to the benefit of using ASIO and WASAPI together. It's my understanding that they both accomplish the same objective.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    edited January 2013
    Tbone289 wrote: »
    I need ASIO for native DSD (SACD) channel mapping support.
    EDIT: There is a custom channel mapping thing going on to swap the R and L channel DSD reversal versus PCM playback. It is done in software versus a hardware switching solution. I had to do hardware switching to correct the SACD channel swap in the Denon 3910 I modded to export CD/SACD to the DAC via I2S.
    Details here, cause I am not smart enough to come up with this on my own.
    http://hifiduino.wordpress.com/category/computer-hw-and-sw/
    dsdoutput.png?w=893&h=648
  • Tbone289
    Tbone289 Posts: 661
    edited January 2013
    That makes sense. Thanks for the info!!
    EDIT: Are you having to switch output formats each time you go from SACD to other encoding?
    edited January 2013
    Tbone289 wrote: »
    You are most welcome!
    In order to have the SACD channels correct, yes I have to switch output format. I am fairly sure WASAPI will do DSD too, but you would still run into the R and L channel swap using it with my setup.
    In players, some DAC chips share PCM (CD) and DSD (SACD) circuits into the DAC chip from the transport. So you connect to your external DAC and can play CD and SACD via I2S out (I2S separates clock from data where clock is embedded in the SPDIF signal). What happens is DSD uses individual circuits for R and L channel. If they don't follow the connection order you have at the external DAC, your R and L channels are swapped when playing DSD. I had to use a digital swich in my modded Denon 3910 to correct that for output to my external DAC. It is controlled by a manual switch on back of the Denon.
    This is my first USB to DAC thing, and I made it more complex with all the options.:eek::cheesygrin: Before I was just SPDIF coax out or I2S out from a modded SB Touch.
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2013
    PC rig update:
    - now using a Stello U3 USB converter via AES/EBU out.
    This thing kicks major butt.
  • ThirdWorldGuy
    ThirdWorldGuy Posts: 39
    edited May 2013
    My Rig,
    Custom built PC Windows 7 32bit
    GeForce GTX 560 Ti HDMI to Receiver
    MediaMonkey WASAPI Output through HDMI in Exclusive Mode with tweaked settings to prevent crackling and distortion during playback and switching between songs. Bitstreaming.
    All FLAC library
    I would like to apologize for digging an old thread but I really need to know somethings.
    I'm a complete noob at this but does anyone here use HDMI for output to their receiver? I went through most of the rigs here but couldn't seem to spot a single rig that uses this. Almost everyone is using USB DACs and optical out etc.
  • hertz9753
    hertz9753 Posts: 310
    edited May 2013
    My Rig,
    All FLAC library
    I use onboard sound and toslink to an older Onkyo 603 receceiver. Radio Shack Optimus Pro 77's modded with Polk Monitor 70 tweeters and and Polk R15 woofer. The receiver and Mirage Omni S8 sub are under my desk.
    001.jpg 369.6K
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
  • Habanero Monk
    Habanero Monk Posts: 715
    edited May 2013
    Foxconn E-350 based NTA350. Has a SSD drive. Win7 using ASIO. FooBar
    Focusrite Scarlett 2i4
    Yamaha P2500S
    For sub duty I use another out on the Scarlett and feed a Behringer EPX2000
    And sub (DIY dual opposed Infinity Kappa 120w.9)
    And LSi 9's. Looking at seeing if the PSB Stratus Silvers on CL near me will be an upgrade. I can sell these and maybe break even. The seller is asking $275 for them.
    EndersShadow Posts: 17,543
    edited May 2013
    Office setup
    Custom PC: ASUS P5E | Intel Q9650 @ 3.6 | 8 Gig Dominator 1066 | ATI 5450 | 2 WD Black 640 | Samsung 1TB | Corsair VX450 | Antec P182
    XBMC
    Audio GD NFB-5
    Polk Ultrafocus 8000's (demo pair)
    Thought I would update my first post as most of this is done...
    Office Rig:
    Custom PC: Interface: XBMC streaming FLAC and hi-rez audio, Pandora, etc
    DAC/Headphone Amps: Audio GD NFB-5, Meridian Explorer
    Pre-Amp: Sunfire TGA-II
    Amp: Fisher 460a tube amp
    Speakers: Polk RTA 11TL's
    Headphones: Beyerdynamic DT-770's 32 ohm
    [/LIST]
    Soon to be:
    Custom PC ordering parts soon
    XBMC
    USB Cable undecided on brand
    Audio GD NFB-5
    Beyerdynamic DT-770 80ohms (tenative choice)
    Work office setup:
    Headphone DAC/AMP: Audio GD NFB-5
    Headphones: Beyerdynamic DT-770 32 ohms
  • j1mmy
    j1mmy Posts: 95
    edited June 2013
    Custom built HTPC
    - Silverstone Grandia case
    - Gigabyte MB - i5 3.1Ghz, quad core cpu, plenty of RAM, plenty of disk
    - Fanless Zotac video card
    - vm-ware desktop - several virtual pc's
    - XBMC 12.2 Frodo
    Denon 3808
    - PA SDA-2B
    - Paradigm 12" sub
    - Paradigm reference center channel
    - Paradigm di-poles in the back
    - Epson 6500 projector
    - 120" Carada screen
    Apple TV Gen 1 160 GB
    - running xbmc crystalubuntu
    - streams content from HTPC over home gig network
    - Panasonic 42" LCD TV in MB
    - Sharp Aquos 46" LCD TV in FR
    Raspberry Pi
    - not running yet but plan to use xbmc and attach to another TV in LR
  • jflail2
    jflail2 Posts: 2,868
    edited June 2013
    Another custom built HTPC here.
    -Zalman 160xt plus case in black
    -i7 3.4ghz quad core cpu
    -580 vid card
    -16gb of ram
    -8TB of HD space, plus a SSD for the OS.
    All of that connects to my new Denon receiver via HDMI, sound outs to my Rti-10 set up in the living room, while video runs to my 46" Sony LCD.
    Teamfortress is a whole new level of joy on a 46" screen with the Rti's rumbling.
  • obieone
    obieone Posts: 5,077
    edited June 2013
    I've got a real simple set-up:
    Antec case
    MSI GXM890-G65 mobo
    Phenom II X6 cpu
    500gb hdd
    8 gb of ram
    LG BD-ROM/ DVD-RW
    I've just got the optic going into the SC-05, with the DVI going into the Samsung 40", and no GC. It died over a year ago, and since I'm not really into games anymore, see no need to replace it.
    I've got an old Soundblaster external sound card, but, the sound quality straight off the mobo is good enough.
  • timk65
    timk65 Posts: 40
    edited June 2013
    My modest setup, sounds great to me!
    * HT Omega Claro Halo 24/196KHz soundcard
    * Polk TSi 500 speakers
    * Yamaha RX V473 AVR
    * PC / Linux with AMD 8 core and 16GB, use quodlibet for playing music
  • Polk&amp;Beans
    Polk&amp;Beans Posts: 94
    edited August 2013
    Custom PC: And another gutted ComPaq box, full blown build, for re-ripping ALL my CD's (Long Story) 8^(
    Lenovo H405 Box & MoBo (At least 4-1TB and 3-500GB HDD's layin around. Lost count)
    3.2GHz AMD Athlon II Quad Core, 8GB Ram, dual 80mm push and 120mmPS & 92mm pull fans
    W7-HP 64bit, All silent settings, MS-Config'ed-minimal bs running in background, USB-full power, No-power saving modes anywhere, Media Center-hacked up-grades, DB Power Amp rip software, WASAPI Audio Exclusive Mode. (A little more work than you Apple Boys)
    Intel-Pro Gigabit NIC Card-No hits, misses or errors.
    Samsung 22X DVD/RW SATA Drive SH-S223C (2) Because I am gonna wear em' out re-ripping again 8^(
    Asus-ATI Radeon 6540-DVI/HDMI/VGA W/120mm fan blowing on it and, N&S bridge heat sinks
    Pangea Audio - USB cable 24awg -Ohno-PCOCC & 4% tinned silver solder on all 4 conductors - 1 Meter
    SonicWave-Corning Glass-Toslink Cables (1 Meter) (2) (No Jitter Bugs or EMI/RFI)
    Music Fidelity 24/96 V-Link II-W/ WASAPI Exclusive Mode-Worth every penny! Massive jitter reduction!
    Sony SDP-EP9ES Digital Signal Processor (24bit/44.1/48Khz processing)
    Just arrived intact! Score! For optional jitter reduction (If needed) & Parametric EQ, Surround Modes, Input Leveling, Optical Out & 5.1 Analog In options (Or maybe to my SONY museum)
    Feeding To:
    Marantz SR5007-(Slays my now gone, Onkyo TX-NR809 for audio) (Miss a ton of video features though)
    Parasound HCA1200 MK II- 205 real watts RMS x 2 @8 Ohms-325@4 Ohms (Soon to be Re-Capped)
    Polk RTi70 Tower Speakers-(Rebuilt XO’s) Bi-Wired & Tied to Parasound
    Polk Monitor 40’s (For Now)(Rebuilt XO’s and braced/damped boxes) Bi-Wired & Tied to the Marantz
    My custom built M40 speaker stands to have same height as RTi70’s
    Velodyne CT-150-15”-275w Sub-12/24db Slopes (New PS Caps and Amp Module)
    SONY DVP-S9000ES DVD/SACD/CD Player (Still great with up-scaling 1080P receivers)
    SONY RDR-GX330 DVD Recorder (The only recorder I’ve found that records everything)
    Sony BDPS1000ES Blu-ray Disc Player
    SONY CDP-CX-90ES-200 Disc CD Changers (2) (Re-Capped) W/On-Screen Display-Daisy Chained=400 CD’s
    SONY TC-K615S-Dolby S/B/C Cassette Deck (For ornamental nostalgia now & the SONY museum)
    Could list the SONY Museum, but I have a headache already. 8^)
    Pablo
  • Polk&amp;Beans
    edited August 2013
    P.S. Looking for a cheap DAC?
    The Sony SDP-EP9ES Digital Signal Processor makes for a pretty damn nice DAC, stand alone...
    All proprietary SONY chips and massive filtering/jitter curcuits.
    GooglyIt.
    Pablo
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2013
    Anyone on the PC side using or tried JRiver?
    Yep, I now own it and have it for both of my computers. I love it after leaving itunes. I am still learning about it.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    recently built my HTPC.
    Corsair 550D
    Corsair Liquid Cooler 60
    I7 4770
    16 GB Ram
    250 GB Samsung Pro SSD
    Asus Z87 Deluxe Mother Board
    Asus Xonar Essence STX
    Pioneer Bluray BD2208
    Seagate 4 TB Media Disk (Flacs)
    J river Media Player
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    +1 Loads of options... Worth every penny
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2013
    AUNE T1 + DT770's right now.
    Main Surround -
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited October 2013
    Tbone289 wrote: »
    I know with WASAPI I only get 24bit, and have to use ASIO for 32bit support and with Vega DAC.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • steveinaz
    steveinaz Posts: 19,522
    edited November 2013
    Asus laptop w/LMS-->WD USB HDD (flac files)-->Modem/router-->Squeezebox Touch w/Channel Island Power Supply-->Benchmark DAC/PRE-->Placette Passive-->Parasound HCA1500A amp-->Harbeth 7ES-3 monitors
    Kimber Hero IC's
    Kimber 8TC v.2 speaker cables
    Belden 1694A digital coax
  • recoveryone
    recoveryone Posts: 885
    Custom built Game rig (old one)
    Win XP
    Squeezebox LMS 7.7 ****
    Win MP for burning CD's (320kps for use both in home and cars)
    Intel P4 3.0Ghz
    2GB of ram
    Linksys Wireless Adapter w/speed boost 9db highgain ant (running off wireless Home network)
    (3) 80GB HD
    Ext 350 GB HD (main music source)
    Ext 1.5 TB HD (backup for whole house)
    Plextor DVD/CD burner
    Sony DVD/CD burner
    3 sets of fans
    500/W Thermaltake PSU
    System runs 24/7 in garage
    Supports:
    3 Classics V3
    Touch
    Transporter
    Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Optimus LS30's Rear Surrounds Optimus LS30's Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX103 Squeezebox Touch Polkaudio R50 Towers Polkaudio CS 10 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Polk audio RTi 6 fronts, Rears Dayton B652 Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Reused an old Pentium4 2gigs of ram computer, using an old soundblaster live card. Was running win xp listening to The Breeze over 181.fm but when xp wouldn't update codec's for The Breeze I switched to Ubuntu. Running this thru pre amp to Halo a23 amp.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • 11tsteve
    11tsteve Posts: 1,166
    edited December 2013
    11tsteve wrote: »
    AMD FX-6100 @ 4.55 ghz, XSPC liquid ... Win 7
    crossfired 6970
    Corsair 120 G ssd
    HT Omega
    Tributaries Series 5 optical
    Matrix Mini DAC (which i would like to replace with a Keces)
    Acurus RL-11
    Parasound HCA 1200 II
    Polk RTA-11T (updated Xovers, RDO-194, rewired, damped drivers, Armacell gaskets, spiked)
    music is in AIFF format on a 1TB WD cloud drive.
    i have tried Media Monkey and Foobar and haven't decided. my drives are due for a reformat, so i'll figure this out then.
    currently in search of new cabling as most of mine is cheap crap....
    updated rig.....
    AMD 8350 8 core, currently at 4.8 Ghz. under custom liquid loop.
    Sapphire 6850
    Mushkin 120 Gb ssd and Windows 7 64 bit
    HT Omega with Grover Huffman D.I.
    Peachtree Dac-It with Morrow M4 custom Y-cable going to both headphone and listed rig.
    speakers change between the updated RTA11T, Infinity RSb, and a pair of 5JR which are next up for refurbishing.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • doctorcilantro
    Updated:
    J. River MC19 + Auralic ASIO (sometimes JPLAY 5.2) PCM2DSD playback and PCM/DSD playback
    NAS - Synology 411j 12TB Raid 5 8TB + (3) 4TB SATA internal
    File Types - .FLAC .DFF .DSF .MP3
    PC - CoolerMaster SilverStone Fortress FT03 Mini-Tower, Quad-Core i7 at 4gHz 16GB RAM, Windows 7 X64
    USB Interface - Adnaco S3B USB-over-fibre on 5v battery
    DAC - Auralic Vega
    Amp - Decware EL34.1 ("Rachel")
    Speakers - Zu Union Cubes
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • 11tsteve
    11tsteve wrote: »
    updated rig.....
    Sapphire 6850
    I forgot the 8 GB of Gskill Ripjaws 8-9-9-24 @ 1866, and that Jriver is my preferred media player.....
    Polk Lsi9
    Keces DA-131 mk.II
  • j1mmy
    j1mmy Posts: 95
    edited January 2014
    +1 on the Ripjaws
  • RamZet
    RamZet Posts: 792
    edited February 2014
    Mine is more focused on games but I do use it for music too.
    Im at the last stages of a rebuild so I havent decided if im going to stay with the onboard or go back to x-fi or a newer sound blaster card.
    I could also skip the sound card and stick to the USB Music Streamer II Dac for music.
    http://highresolutiontechnologies.com/music-streamer-ii
    System specs are
    Intel i7 3820
    EVGA X79 4-way SLI Classified motherboard
    16GB DDR3 2133 XMP -RipJaw Z series
    Vertex 4 SSD
    XFX R9 290 in TriFire ( three video cards)
    ABS 1100w BZ series PSU
    Windows 7 64bit Pro edition
    Three Acer 24" H233H monitors @ 5760x1080p
    Custom full system Water Loop. CPU, motherboard, and videocards.
    for Audio im using a Rotel Pre and Amp and some Free Bose speakers with a Sunfire Sub.
    heres an image. http://postimg.org/image/ezgs8v6s5/
    image with a more completed water loop. http://postimg.org/image/wvhomcjjp/
    B&W CM9Classé Sigma
