Battery vs power cable, shielding vs no shielding - my results over the years
Aint this beautiful? It doesn't look like a $600 cable, more like $30k. And performs like a $60k, but for $600. It's ridiculously underpriced. This is just wrong.....
Cheezy -
Is that masking tape on the ends of that thing?
I see why you call yourself cheesy.:rolleyes:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I do believe that is Playdough.--Gary--
masking tape... lol ha ha.nooshinjohn wrote: »Is that masking tape on the ends of that thing?
You are a comedian. That's a Whitewood airy tree fiber on both ends of the plugs. They are to keep the conductors from coming lose, prevent oxidation, and keep the sound uncolored for natural sound with realism. Pat you on the back.
Cheezy -
Such good bull$hit!!
On the other hand, what can I get for $500,000.00 as that is all I can afford at this point.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
It's tree fiber, similar to wood but without the colorations wood gives. Here is a close-up. You see the texture is more consistent than with wood.I do believe that is Playdough.
Here is standard wood. You see the grain makes it all messy. It gives colorations to the sound. But if you take the wood material, reconstruct it, you can make uncolored sound.
F1nut is messaging me and saying that he knows my real name. I told him he was wrong. But he still thinks he is right.
It's the same thing with the cables. I have listened to the cables, he never did, and he thinks he knows better. Very bad logic. This is an embarrassing day for the skeptics.F1nut wrote:Got ya!AudioTruth wrote:No, that's not my name.F1nut wrote:I've got all your info, yeah it is. -
That only works if there are trolls in the first place.ken brydson wrote: »^This^.
Couldn't agree more. Don't feed the trolls and they'll go away. Pretty simple....
I have made 509 posts at Audioasylum in my own forum, nobody responded for weeks/months. Did I leave? No, I kept posting hundreds of threads. -
Wonder why nobody responded? lol I know why!
And many of us know who you are Patrick Laakso.--Gary--
And all my customers know I don't have that name. My name is written on all packages.Wonder why nobody responded? lol I know why!
And many of us know who you are Patrick Laakso. -
AudioTruth wrote: »That only works if there are trolls in the first place.
Well I thought I still had a link to your forum Patrick, but I guess they TOTALLY disposed of all the archives and everything.:redface:
Oooops!
Here it is just scroll down, glad to do my part to help you out Patrick.
I thought your forum was "Top Shelf"!
I am surprised other people (companies) even make power cables any more.
http://www.audioasylum.com/cgi/etv.mpl?forum=coconutTesting
Testing
Testing -
Skeptics think they know me better than I know myself, very strange. Based on this information, it's easy to know that they are wrong about cables too. 100% of those who own the cable, are getting eargasms. The skeptics who never owned the cable, are saying that the cable doesn't give eargasms. Do you see what is wrong here?
AudioTruth wrote: »Skeptics think they know me better than I know myself, very strange. Based on this information, it's easy to know that they are wrong about cables too. 100% of those who own the cable, are getting eargasms. The skeptics who never owned the cable, are saying that the cable doesn't give eargasms. Do you see what is wrong here?
Well to be honest, yes I do.
I tried to make a knife out of rope one time, I couldn't get it to cut anything, so I included all the BS in the world that I could come up with to try to sell it, and I still could not sell that damn thing as a knife.
Nobody believed it!
That said, if I made even a HALF WAY DECENT knife, and eliminated all the BS, I could sell them.
Left and right!
Imagine that!:eek:Testing
Testing
Testing -
I would like to mention also Patrick.........using solid core conductors with a mechanical IEC or Male AC plug IS NOT A VERY GOOD IDEA!
Not to mention, UNSAFE.
They ARE/WERE designed for stranded wire (unless you solder spades).
Unlike receptacles, they are moved around ALOT more, and removed/replaced at times, often many times, not to mention, they are not mounted to a stationary box, mounted to a stud, like a receptacle is.Testing
Testing
Testing -
Furutech plugs were designed for solid core conductors.I would like to mention also Patrick.........using solid core conductors with a mechanical IEC or Male AC plug IS NOT A VERY GOOD IDEA!
They ARE/WERE designed for stranded wire.
Unlike receptacles, they are moved around ALOT more, and taken in and out at times, not to mention, they are not mounted to a stationary box, mounted to a stud.
Furutech has these crimp sleeves (for AC plugs) that collects multi strand wiring, and makes it appear like solid core to the plug:
Of course this reduces audio quality, so it's best to use solid core in the first place.
Nordost and Virtual Dynamics have always used solid core in their power cables, because it gives the best sound.
There is no safety concern if the cable is really thick. I need to use a bolt cutter to cut the cable. -
Patrick....do you not find it rather strange that no matter what audio forums you post your BS on. People make fun of your ignorant ramblings all over?--Gary--
I can make a knife using my hair. Just pluck out a hair and cut through butter.Well to be honest, yes I do.
Nobody believed it!
Left and right!
Imagine that!:eek:
You can do the same with the rope, you remove only one strand and cut through butter. If you want a sharper knife, you use rope made of metal. -
AudioTruth wrote: »Furutech plugs were designed for solid core conductors.
It can be done "cold welded" but someone in Sweden with 9 rabbits living in their house, my suggestion is to drop the solid core with a mechanical connection.
Prolly won't hear much from you after the first house you burn down.:eek:
Think about it.Testing
Testing
Testing -
It's not strange. They try to justify their lack of eargasm by believing that I'm wrong. Deep inside they are crying, not laughing.Patrick....do you not find it rather strange that no matter what audio forums you post your BS on. People make fun of your ignorant ramblings all over? -
If you mean the conductors coming loose from the plug, that is physically impossible with my tree fiber design. It took an hour of sawing through the tree fiber to get to the conductors. With a bolt cutter it took half as long.It can be done "cold welded" but someone in Sweden with 9 rabbits living in their house, my suggestion is to drop the solid core with a mechanical connection.
Think about that.
I don't have 9 rabbits living in my house, and I never had. I don't have a house either. -
Yeah, but you are WAY better than them, remember?Nordost and Virtual Dynamics have always used solid core in their power cablesTesting
Testing
Testing -
Ha ha that's hilarious. F1nut has been so quiet here on public forum but he's been PM'ing you? What a fail.. You know his butt got sore!AudioTruth wrote: »F1nut is messaging me and saying that he knows my real name. I told him he was wrong. But he still thinks he is right.
Nope... Wrong. That's not his name. I have proof. But not telling you what his real name is. ... only the customers have access to his name.Wonder why nobody responded? lol I know why!
Yes, I am getting total satisfaction out of your cables. Serious improvement in SQ. It's like drug. I'm so addicted to the sound I can't leave my house even for an hour. I stay at all times except for work.AudioTruth wrote: »Skeptics think they know me better than I know myself, very strange. Based on this information, it's easy to know that they are wrong about cables too. 100% of those who own the cable, are getting eargasms. The skeptics who never owned the cable, are saying that the cable doesn't give eargasms. Do you see what is wrong here?
Skeptics are like the communist. It's not only evil but they are the devils. The government and FDA are like that too sadly.
Cheezy -
AudioTruth wrote: »If you mean the conductors coming loose from the plug, that is physically impossible with my tree fiber design. It took an hour of sawing through the tree fiber to get to the conductors. With a bolt cutter it took half as long.
EDIT: I'm going to edit this even though, I know different.I don't have 9 rabbits living in my houseI don't have a house either.
Makes perfect sense to me!Testing
Testing
Testing -
Patrick's cables are much thicker and durable than your skinny cords. He's giving out too much great info already. You guys have been educated by him already.I would like to mention also Patrick.........using solid core conductors with a mechanical IEC or Male AC plug IS NOT A VERY GOOD IDEA!
Cheezy -
Nope... Wrong. That's not his name. I have proof. But not telling you what his real name is. We respect each other our identities... only the customers have access to his name.
Oh yeah I understand. He is such the great audio designer/inventor that he is scared to give him name. Yeah that sounds like an honest person with nothing to hide! :rolleyes:
Go listen to your cheap 'hardware store' wire with playdough handles......--Gary--
Cheezy, Patrick is running out of forums to advertize his wares.
Banned most everywhere but here.
I have to admit, I feel sorry for both of you (if you are actually two different people).Testing
Testing
Testing -
There is no such thing as being better than someone else. Everyone are equal overall. To become really good at one thing, you become bad at everything else. Everything balances out. Nordost is very good at marketing, and that's about it. As you noticed, I'm very bad at marketing.Yeah, but you are WAY better than them, remember? -
He simply doesn't have to give out his name to everyone in the public. The person needs some privacy, just like everyone else. You want his real name be nice to him and ask for forgiveness for being rude to him. AND buy his cables. You will get his real name then. You need to be respectful at all times.Oh yeah I understand. He is such the great audio designer/inventor that he is scared to give him name. Yeah that sounds like an honest person with nothing to hide! :rolleyes:
Patrick is very special. He builds stuff that really works. No scam. I have proof. They are right in front of me. White Night Power 5M and 2M's + tweaks.
Cheezy
