XO Component Check
StantonZ
StantonZ Posts: 454
edited April 2013 in Vintage Speakers
Before I order parts for my Monitor 10B XO rebuild (going to use Sonicaps+Mills resistors), I need to know what to do about the polyswitch; specifically, I want to remove it. The schematic I'm using (dated 5/17/1989) specifies a 2.0 Ohm resistor in parallel with the 12uF cap. If I eliminate the polyswitch, do I change that resistor back to 2.5 Ohms (like the previous version of the schematic that used a fuse), or leave it at 2.0 Ohm and just replace the polyswitch with piece of solid wire?
(2) Polk RC80i (Top Middle)
Polk CS300 center channel
Post edited by StantonZ on
  • zane77
    zane77 Posts: 1,696
    edited April 2013
    Try it with a jumper, in the SDA's that's supposed to increase the highs slightly but you could try it both ways and see (hear) which way sounds best to you.
    Two Channel
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2013
    StantonZ wrote: »
    A .5 ohm resistor is all you need to replace it.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • StantonZ
    StantonZ Posts: 454
    edited April 2013
    If I replace the polyswitch with a .5 Ohm resistor, I assume I leave the 2.0 Ohm resistor alone. My question is: if I replace the polyswitch with a wire, do I change the 2.0 Ohm -> 2.5 Ohm to compensate, or will that alter the frequency response?
  • westmassguy
    edited April 2013
    StantonZ wrote: »
    I prefer to keep the 2 ohm separate. You've got a 12uf cap accross it, as a shunt. Changing the value of the 2 ohm resistor, may have an affect on the overal frequency responsee of the tweeter in unexpected ways. You can change out the .5 ohm with a .2 or .3, or even a wire jumper, and experiment, see how hot you want the top end, without affecting the resistor/capacitor arrangement.
  • StantonZ
    StantonZ Posts: 454
    edited April 2013
    Makes sense; that's what I was looking for. Thanks!
  • westmassguy
    edited April 2013
    StantonZ wrote: »
    You're welcome. Play with the values if you want, they're your babies to do with as you see fit.
  • TennMan
    TennMan Posts: 1,266
    edited April 2013
    That's interesting. I once owned a pair of Bozak LS250 speakers that had a three position brightness control on the rear for the tweeters. It was really nice to be able to select how bright you wanted them to sound. If I understand you correctly it would be possible to to the same with with Polks by adding a three position rotary switch like the Bozaks had, with three different resistors attached, connected by to replace polyswitches.
  • westmassguy
    edited April 2013
    TennMan wrote: »
    Theoretically, yes, but I've serviced quite a few of those multi-position switches, they get dirty and corroded, and are usually more trouble that they're worth.
  • TennMan
    edited April 2013
    I had the Bozaks for about 20 years with no problems from the switches but I can see how it could be a problem. The KISS concept is usually the best way to go to avoid problems down the road. :)
  • westmassguy
    edited April 2013
    Kiss?
  • Jimbo18
    Jimbo18 Posts: 2,351
    edited April 2013
    Kiss?
    K.I.S.S. as in Keep it Simple Stupid. Not you, of course.
  • westmassguy
    edited April 2013
    Jimbo18 wrote: »
    Gotcha
  • TennMan
    edited April 2013
    Yeah, what Jimbo said. Just an expression that usually applies to me. I tend to think a little out of the box sometimes and over-complicate things.
  • Jimbo18
    edited April 2013
    TennMan wrote: »
    It does sound like a cool idea though.
  • westmassguy
    edited April 2013
    TennMan wrote: »
    You, over-complicate? Nah, say it ain't so
  • TennMan
    edited April 2013
    haha... Let's just say I like lots of options to play with.
  • westmassguy
    edited April 2013
    TennMan wrote: »
    Just busting your chops Ronnie :)
  • StantonZ
    StantonZ Posts: 454
    edited April 2013
    FWIW, I'm going to order the 0.5 Ohm resistor but start with a solid wire (short) and see how it sounds; I just need to look for a nice thick (solid) piece of wire here at work.
  • Schurkey
    Schurkey Posts: 2,125
    edited April 2013
    Remove polyswitch, measure it with an ohmmeter, see what it's resistance REALLY is. Order resistor in the same value.
    (Better still would be to measure a NEW polyswitch, as they burn up in use. Resistance increases as the contacts fry. First Guess: A new polyswitch has nowhere near 1/2 ohm of resistance.)
  • westmassguy
    edited April 2013
    Schurkey wrote: »
    Polk eventually removed the polyswitches, and in many cases, the 1st resistor down-stream was bumped up by .5 ohms.
    That value wasn't just pulled out of the air. If memory serves, new polyswitches measured between 2 and 3 ohms. After several "trips" is closer to 5 ohm. There was talk of pre-conditioning the polyswitches at the factory for consistency.
  • Schurkey
    edited April 2013
    Decimal error? Between .2 and .3 ohms, new, .5 ohms after the contacts burn?
    I thought Polk did end up tripping the polyswitches at least once because they were unreliable in terms of amperage needed to trip them the first time.
  • westmassguy
    edited April 2013
    Schurkey wrote: »
    Thanks for pointing that out, a 5 ohm resister would not be a good thing :)
    From what I've read, they were a constant headache, which is why there was talk of pre-conditioning, and also why they were eventually done away with. Sometomes "Old School" is better. Fuses still work as intended. Problem is, some people don't put the right fuse back.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2013
    Gimpod told me mills 0.22.
    Of course you could be a Nutty Professor and get a toggle switch
    to switch the Poly switch in or out,
    sort of a Safe Mode so when you have a party or
    leave the kids Home Alone. :cheesygrin:
