XO Component Check
StantonZ
StantonZ Posts: 454
edited April 2013 in Vintage Speakers
Before I order parts for my Monitor 10B XO rebuild (going to use Sonicaps+Mills resistors), I need to know what to do about the polyswitch; specifically, I want to remove it. The schematic I'm using (dated 5/17/1989) specifies a 2.0 Ohm resistor in parallel with the 12uF cap. If I eliminate the polyswitch, do I change that resistor back to 2.5 Ohms (like the previous version of the schematic that used a fuse), or leave it at 2.0 Ohm and just replace the polyswitch with piece of solid wire?
(2) Polk RC80i (Top Middle)
Polk CS300 center channel
Post edited by StantonZ on
