XO Component Check
StantonZ
Before I order parts for my Monitor 10B XO rebuild (going to use Sonicaps+Mills resistors), I need to know what to do about the polyswitch; specifically, I want to remove it. The schematic I'm using (dated 5/17/1989) specifies a 2.0 Ohm resistor in parallel with the 12uF cap. If I eliminate the polyswitch, do I change that resistor back to 2.5 Ohms (like the previous version of the schematic that used a fuse), or leave it at 2.0 Ohm and just replace the polyswitch with piece of solid wire?
Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV
(2) Polk RC80i (Top Middle)
Polk CS300 center channel
Klipsch SPL-120 subwoofer
Try it with a jumper, in the SDA's that's supposed to increase the highs slightly but you could try it both ways and see (hear) which way sounds best to you.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
A .5 ohm resistor is all you need to replace it.Before I order parts for my Monitor 10B XO rebuild (going to use Sonicaps+Mills resistors), I need to know what to do about the polyswitch; specifically, I want to remove it. The schematic I'm using (dated 5/17/1989) specifies a 2.0 Ohm resistor in parallel with the 12uF cap. If I eliminate the polyswitch, do I change that resistor back to 2.5 Ohms (like the previous version of the schematic that used a fuse), or leave it at 2.0 Ohm and just replace the polyswitch with piece of solid wire?Home Theater/2 Channel:
dhsspeakerservice.com/ -
If I replace the polyswitch with a .5 Ohm resistor, I assume I leave the 2.0 Ohm resistor alone. My question is: if I replace the polyswitch with a wire, do I change the 2.0 Ohm -> 2.5 Ohm to compensate, or will that alter the frequency response?Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelKlipsch SPL-120 subwooferAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
I prefer to keep the 2 ohm separate. You've got a 12uf cap accross it, as a shunt. Changing the value of the 2 ohm resistor, may have an affect on the overal frequency responsee of the tweeter in unexpected ways. You can change out the .5 ohm with a .2 or .3, or even a wire jumper, and experiment, see how hot you want the top end, without affecting the resistor/capacitor arrangement.If I replace the polyswitch with a .5 Ohm resistor, I assume I leave the 2.0 Ohm resistor alone. My question is: if I replace the polyswitch with a wire, do I change the 2.0 Ohm -> 2.5 Ohm to compensate, or will that alter the frequency response?Home Theater/2 Channel:
Makes sense; that's what I was looking for. Thanks!Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelKlipsch SPL-120 subwooferAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
You're welcome. Play with the values if you want, they're your babies to do with as you see fit.Makes sense; that's what I was looking for. Thanks!Home Theater/2 Channel:
That's interesting. I once owned a pair of Bozak LS250 speakers that had a three position brightness control on the rear for the tweeters. It was really nice to be able to select how bright you wanted them to sound. If I understand you correctly it would be possible to to the same with with Polks by adding a three position rotary switch like the Bozaks had, with three different resistors attached, connected by to replace polyswitches.westmassguy wrote: »I prefer to keep the 2 ohm separate. You've got a 12uf cap accross it, as a shunt. Changing the value of the 2 ohm resistor, may have an affect on the overal frequency responsee of the tweeter in unexpected ways. You can change out the .5 ohm with a .2 or .3, or even a wire jumper, and experiment, see how hot you want the top end, without affecting the resistor/capacitor arrangement.- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Theoretically, yes, but I've serviced quite a few of those multi-position switches, they get dirty and corroded, and are usually more trouble that they're worth.That's interesting. I once owned a pair of Bozak LS250 speakers that had a three position brightness control on the rear for the tweeters. It was really nice to be able to select how bright you wanted them to sound. If I understand you correctly it would be possible to to the same with with Polks by adding a three position rotary switch like the Bozaks had, with three different resistors attached, connected by to replace polyswitches.Home Theater/2 Channel:
I had the Bozaks for about 20 years with no problems from the switches but I can see how it could be a problem. The KISS concept is usually the best way to go to avoid problems down the road.westmassguy wrote: »Theoretically, yes, but I've serviced quite a few of those multi-position switches, they get dirty and corroded, and are usually more trouble that they're worth.
Kiss?Home Theater/2 Channel:
westmassguy wrote: »Kiss?
K.I.S.S. as in Keep it Simple Stupid. Not you, of course. -
Yeah, what Jimbo said. Just an expression that usually applies to me. I tend to think a little out of the box sometimes and over-complicate things.
It does sound like a cool idea though. -
You, over-complicate? Nah, say it ain't soYeah, what Jimbo said. Just an expression that usually applies to me. I tend to think a little out of the box sometimes and over-complicate things.Home Theater/2 Channel:
haha... Let's just say I like lots of options to play with.westmassguy wrote: »You, over-complicate? Nah, say it ain't so- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
Just busting your chops Ronniehaha... Let's just say I like lots of options to play with.
FWIW, I'm going to order the 0.5 Ohm resistor but start with a solid wire (short) and see how it sounds; I just need to look for a nice thick (solid) piece of wire here at work.Yamaha RX-A2050 AVR (5.1.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelKlipsch SPL-120 subwooferAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
Remove polyswitch, measure it with an ohmmeter, see what it's resistance REALLY is. Order resistor in the same value.
(Better still would be to measure a NEW polyswitch, as they burn up in use. Resistance increases as the contacts fry. First Guess: A new polyswitch has nowhere near 1/2 ohm of resistance.) -
Polk eventually removed the polyswitches, and in many cases, the 1st resistor down-stream was bumped up by .5 ohms.Remove polyswitch, measure it with an ohmmeter, see what it's resistance REALLY is. Order resistor in the same value.
That value wasn't just pulled out of the air. If memory serves, new polyswitches measured between 2 and 3 ohms. After several "trips" is closer to 5 ohm. There was talk of pre-conditioning the polyswitches at the factory for consistency.Home Theater/2 Channel:
Decimal error? Between .2 and .3 ohms, new, .5 ohms after the contacts burn?westmassguy wrote: »If memory serves, new polyswitches measured between 2 and 3 ohms. After several "trips" is closer to 5 ohm. There was talk of pre-conditioning the polyswitches at the factory for consistency.
I thought Polk did end up tripping the polyswitches at least once because they were unreliable in terms of amperage needed to trip them the first time. -
Thanks for pointing that out, a 5 ohm resister would not be a good thingDecimal error? Between .2 and .3 ohms, new, .5 ohms after the contacts burn?
From what I've read, they were a constant headache, which is why there was talk of pre-conditioning, and also why they were eventually done away with. Sometomes "Old School" is better. Fuses still work as intended. Problem is, some people don't put the right fuse back.Home Theater/2 Channel:
Gimpod told me mills 0.22.
Of course you could be a Nutty Professor and get a toggle switch
to switch the Poly switch in or out,
sort of a Safe Mode so when you have a party or
leave the kids Home Alone. :cheesygrin:POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
