Cheapest speaker wire to test speakers
Cool. By the way, when I get the monoprice wire I will compare it with the lowes and see if I hear the difference
Which is why you should have gotten 12 gauge instead of 14.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Preach on, ye god of all things audio.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
He has been through the trenches and earned his stripes.... -
How old are you?
It would have been a much better test/comparison if he had 12 gauge from Lowes and the 14 gauge from Monoprice. Now it is simply an apple to apple comparison. If the inexpensive 12 gauge sounds better, or equal to, than the more expensive Monoprice then that is a useful bit of information. On the other hand, if the 14 gauge Lowes sounds better, or equal to, the Monoprice that too is useful, but I think the 12 guage Lowes would be a bit more informative.Lumin X1 file player, Westminster Labs interconnect cable
You all are bad influence
I ordered another monoprice.. but the 12 AWG spool. Now when the 14 AWG arrives I have to figure out how to get rid of it. I will see if i can sell it on craigslist or something. -
My guess it you won't hear a dif.You all are bad influence
Since you haven't received the 14 yet, will Monoprice just let you return it unopened?
Btw, I use Monoprice 12x4, works just fine.Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
Dunno, but i got other cables within that same order, so I have to open it
I think they would let me return it but at my own expense, no restocking fee maybe.. -
i would just try to sell it on craigslist or something, or keep it extra, maybe you decide to re-arrange your system, and you dont have any of your heavy wire left long enough to use for new runs, you can use the 14 while you wait for more, use the 14 to make some jumpers for your speakers if they have 2 pairs of binding posts, it never hurts to have an extra or a spare around if something comes up2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Ahem.......up until the 1980s, 14gauge speaker wire was HUGE and considered overkill, while the "norm" was 22- 20-18 gauge wire. Then came Monster and the rest is pretty much history. 14 wire may be perfectly adequate for your needs, what components (amp/ speakers) are you hooking up with this wire?
Did i miss what kind of speakers we are discussing?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Denon AVR 1912 connecting it to :
Monitor 40s
Monitor 30s
Monitor CS1
The room is 215 square feet. -
And in the Middle Ages if a woman floated she was a witch. So, what's your point?Lumin X1 file player, Westminster Labs interconnect cable
I thought that was still true todaySet up: 11.2 HT + 2ch
point is......the gauge wars are hype and marketing..... and that if big were truly necessary, it would have been discovered and declared as fact long before Monster hit the scene. Have you had a peek inside your electronics or speakers ? What gauge wiring did the manufacturers elect to use ? -
There's a lot more to cable than the gauge, which is a fact that some folks just can't seem to grasp.Political Correctness'.........defined
President of Club Polk -
That's what she saidSet up: 11.2 HT + 2ch
Right. There's gauge, looks, and marketing. -
^+1000!^ Spot on!"Everything I ever did in my life worthwhile I caught hell for"
You and Bobby boy can't be that ignorant, can you? Really???Political Correctness'.........defined
Funny how the usual suspects love to spout out how nothing matters with a cable. No matter what is different with a cable there will be no difference in the end result. Yet, I have yet to see a weakling get in on the cable demos. Apparently, they are scared they will be shown wrong, and if they are so wrong about something as "simple" as wire then what other of their beliefs are also wrong.
Anyway, I am looking forward to the comparison of the Lowes cable to the Monoprice cable. My personal belief is, by and large, inexpensive cable is pretty much the same. You need to get up into a few hundred dollar range before you start to get noticible improvement. But I could be wrong since I never did that test. I went from hardware store 12 gauge to Mapleshade Clearview Double Helix Plus for my first speaker cable upgrade. And that was an obvious difference, and it is a small gauge, maybe 18 or so. However, generally speaking with inexpensive wire bigger is usually better when the other parts (insulation, copper, stranded) are equal.Lumin X1 file player, Westminster Labs interconnect cable
Name calling is for the delusional! Ignorance is bliss!You and Bobby boy can't be that ignorant, can you? Really???"Everything I ever did in my life worthwhile I caught hell for" -
So how about it Bobby boy, are you willing to demo some high end cables or are you happy to remain one of the blissfully ignorant?Political Correctness'.........defined
My humble setup...
...is no more.
A little barley and hopps gently poured into the top of the receiver at the warm spots should set off everything just right,,,call me sparky!
When I get 'hopped' up I notice the music sounds better. However, call me cheap, but I am not wasting good beer on my stereo.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
scumbag in post 54 reportedIf you can't hear a difference, don't waste your money.
I've tried Mit SG S3.3's,Avt2(which i'm currently using)and some analysis plus cables! The SG S3.3's did nothing for me,as well as all others I've tried,in my set-up. Plain and simple! I use the Avt2's cause I feel I got a good deal on them,and they're nice looking,compared to bulk speaker wire. I'm gonna match my new ML Montis speakers to some Analysis Plus. There again,Less then $160,and they look good! The SG S3.3's were a friends,that were"burned in". I tried them for 2 weeks,and just didnt find any sonic improvement to MY ears! Therefore,I've deciced to spend MY $1000 elsewhere in my system!So how about it Bobby boy, are you willing to demo some high end cables or are you happy to remain one of the blissfully ignorant?
However,i am looking forward to swapping out the Analysis Plus cables,with the AVT2's on the ML,just to see if I can hear any sonic difference! GoodDay! Rob"Everything I ever did in my life worthwhile I caught hell for" -
Fair enough Rob. Not everyone can or will hear sonic improvements no matter what is used. That however doesn't paint the whole subject with a broad brush.
The rest just need to experiment and try for themselves. Otherwise your opinions are just speculation. Marketing hype is used in every consumer product known to man. Doesn't seperate the bad from the good either. Cables are no different.HT SYSTEM-
lsi 9's -
In most cases Tony,IMHO,Marketing hype,is what it is! Marketing hype! Most cable companies,and other goods sold throughout the world,claim to have "the best,greatest,supreme",ect.ect.!Fact is,they can't all have the bestest,cause its subjective! I own a Carquest store! I wouldn't for one second try and tell my customers that all my parts are supreme, to say a Napa,Autozone,or OReileys! Because they're not! In alot of cases the parts are the same,in all boxes!(and made oversea's) I would tell them that I can offer top notch CS to them,without fail! Fact is Marketing is what sells the product,in most cases! ACDelco,is a subsidary of GM,and has GREAT marketing! People ask me for them by name. What most people dont know is,They dont make over 90% of the parts in their box! Its made by the same companies that make Carquest,Napa,ect.ect.! Marketing!!!"Everything I ever did in my life worthwhile I caught hell for"
bobsauto49 wrote: »In most cases Tony,IMHO,Marketing hype,is what it is! Marketing hype! Most cable companies,and other goods sold throughout the world,claim to have "the best,greatest,supreme",ect.ect.!Fact is,they can't all have the bestest,cause its subjective! I own a Carquest store! I wouldn't for one second try and tell my customers that all my parts are supreme, to say a Napa,Autozone,or OReileys! Because they're not! In alot of cases the parts are the same,in all boxes!(and made oversea's) I would tell them that I can offer top notch CS to them,without fail! Fact is Marketing is what sells the product,in most cases! ACDelco,is a subsidary of GM,and has GREAT marketing! People ask me for them by name. What most people dont know is,They dont make over 90% of the parts in their box! Its made by the same companies that make Carquest,Napa,ect.ect.! Marketing!!!
What kind of discount do Polkies get ? I need a heater fan for a 93 Bonneville that I'm selling.
And I need ball joints for a 99 Ford Ranger XLT.
--Gary--
