Cheapest speaker wire to test speakers
2
  • BlueFox
    BlueFox Posts: 15,250
    edited November 2012
    azsam wrote: »
    Cool. By the way, when I get the monoprice wire I will compare it with the lowes and see if I hear the difference :)
    Which is why you should have gotten 12 gauge instead of 14.
  • ROHfan
    ROHfan Posts: 1,014
    BlueFox wrote: »
    Preach on, ye god of all things audio.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    Toolfan66 Posts: 18,198
    ROHfan wrote: »
    He has been through the trenches and earned his stripes....
  • BlueFox
    ROHfan wrote: »
    How old are you?
    It would have been a much better test/comparison if he had 12 gauge from Lowes and the 14 gauge from Monoprice. Now it is simply an apple to apple comparison. If the inexpensive 12 gauge sounds better, or equal to, than the more expensive Monoprice then that is a useful bit of information. On the other hand, if the 14 gauge Lowes sounds better, or equal to, the Monoprice that too is useful, but I think the 12 guage Lowes would be a bit more informative.
  • azsam
    azsam Posts: 45
    You all are bad influence :) I ordered another monoprice.. but the 12 AWG spool. Now when the 14 AWG arrives I have to figure out how to get rid of it. I will see if i can sell it on craigslist or something.
  • Geoff4rfc
    Geoff4rfc Posts: 2,969
    azsam wrote: »
    My guess it you won't hear a dif.
    azsam wrote: »
    Since you haven't received the 14 yet, will Monoprice just let you return it unopened?
    Btw, I use Monoprice 12x4, works just fine.
  • azsam
    azsam Posts: 45
    Geoff4rfc wrote: »
    Dunno, but i got other cables within that same order, so I have to open it :( I think they would let me return it but at my own expense, no restocking fee maybe..
  • seabeerob213
    seabeerob213 Posts: 1,843
    i would just try to sell it on craigslist or something, or keep it extra, maybe you decide to re-arrange your system, and you dont have any of your heavy wire left long enough to use for new runs, you can use the 14 while you wait for more, use the 14 to make some jumpers for your speakers if they have 2 pairs of binding posts, it never hurts to have an extra or a spare around if something comes up
  • gdb
    gdb Posts: 6,012
    Ahem.......up until the 1980s, 14gauge speaker wire was HUGE and considered overkill, while the "norm" was 22- 20-18 gauge wire. Then came Monster and the rest is pretty much history. 14 wire may be perfectly adequate for your needs, what components (amp/ speakers) are you hooking up with this wire?
  • brgman
    brgman Posts: 2,859
    Did i miss what kind of speakers we are discussing?
    I’M OFFENDED!!!!
  • azsam
    azsam Posts: 45
    gdb wrote: »
    Denon AVR 1912 connecting it to :
    Monitor 40s
    Monitor 30s
    Monitor CS1
    The room is 215 square feet.
  • BlueFox
    gdb wrote: »
    And in the Middle Ages if a woman floated she was a witch. So, what's your point?
  • Geoff4rfc
    BlueFox wrote: »
    I thought that was still true today
  • gdb
    gdb Posts: 6,012
    BlueFox wrote: »
    point is......the gauge wars are hype and marketing..... and that if big were truly necessary, it would have been discovered and declared as fact long before Monster hit the scene. Have you had a peek inside your electronics or speakers ? What gauge wiring did the manufacturers elect to use ?
    F1nut Posts: 52,020
    There's a lot more to cable than the gauge, which is a fact that some folks just can't seem to grasp.
  • Geoff4rfc
    That's what she said
  • WilliamM2
    WilliamM2 Posts: 4,808
    Right. There's gauge, looks, and marketing.
  • bobsauto49
    bobsauto49 Posts: 973
    ^+1000!^ Spot on!
    "Everything I ever did in my life worthwhile I caught hell for"
    F1nut Posts: 52,020
    WilliamM2 wrote: »
    You and Bobby boy can't be that ignorant, can you? Really???
  • BlueFox
    Funny how the usual suspects love to spout out how nothing matters with a cable. No matter what is different with a cable there will be no difference in the end result. Yet, I have yet to see a weakling get in on the cable demos. Apparently, they are scared they will be shown wrong, and if they are so wrong about something as "simple" as wire then what other of their beliefs are also wrong.
    Anyway, I am looking forward to the comparison of the Lowes cable to the Monoprice cable. My personal belief is, by and large, inexpensive cable is pretty much the same. You need to get up into a few hundred dollar range before you start to get noticible improvement. But I could be wrong since I never did that test. I went from hardware store 12 gauge to Mapleshade Clearview Double Helix Plus for my first speaker cable upgrade. And that was an obvious difference, and it is a small gauge, maybe 18 or so. However, generally speaking with inexpensive wire bigger is usually better when the other parts (insulation, copper, stranded) are equal.
  • bobsauto49
    Name calling is for the delusional! Ignorance is bliss!
    F1nut Posts: 52,020
    So how about it Bobby boy, are you willing to demo some high end cables or are you happy to remain one of the blissfully ignorant?
  • goofyGAguy
    goofyGAguy Posts: 545
    emmahu wrote: »
    Maybe it can develop your brain at the same time.
    Maybe you could start with yours!
    My humble setup...
    ...is no more. :cry:
  • PolkieMan
    PolkieMan Posts: 2,446
    A little barley and hopps gently poured into the top of the receiver at the warm spots should set off everything just right,,,call me sparky!:lol:
    BlueFox wrote: »
    When I get 'hopped' up I notice the music sounds better. However, call me cheap, but I am not wasting good beer on my stereo.
  • decal
    decal Posts: 3,205
    scumbag in post 54 reported
  • bobsauto49
    I've tried Mit SG S3.3's,Avt2(which i'm currently using)and some analysis plus cables! The SG S3.3's did nothing for me,as well as all others I've tried,in my set-up. Plain and simple! I use the Avt2's cause I feel I got a good deal on them,and they're nice looking,compared to bulk speaker wire. I'm gonna match my new ML Montis speakers to some Analysis Plus. There again,Less then $160,and they look good! The SG S3.3's were a friends,that were"burned in". I tried them for 2 weeks,and just didnt find any sonic improvement to MY ears! Therefore,I've deciced to spend MY $1000 elsewhere in my system!
    However,i am looking forward to swapping out the Analysis Plus cables,with the AVT2's on the ML,just to see if I can hear any sonic difference! GoodDay! Rob
    Fair enough Rob. Not everyone can or will hear sonic improvements no matter what is used. That however doesn't paint the whole subject with a broad brush.
    The rest just need to experiment and try for themselves. Otherwise your opinions are just speculation. Marketing hype is used in every consumer product known to man. Doesn't seperate the bad from the good either. Cables are no different.
  • bobsauto49
    In most cases Tony,IMHO,Marketing hype,is what it is! Marketing hype! Most cable companies,and other goods sold throughout the world,claim to have "the best,greatest,supreme",ect.ect.!Fact is,they can't all have the bestest,cause its subjective! I own a Carquest store! I wouldn't for one second try and tell my customers that all my parts are supreme, to say a Napa,Autozone,or OReileys! Because they're not! In alot of cases the parts are the same,in all boxes!(and made oversea's) I would tell them that I can offer top notch CS to them,without fail! Fact is Marketing is what sells the product,in most cases! ACDelco,is a subsidary of GM,and has GREAT marketing! People ask me for them by name. What most people dont know is,They dont make over 90% of the parts in their box! Its made by the same companies that make Carquest,Napa,ect.ect.! Marketing!!!
  • gdb
    gdb Posts: 6,012
    bobsauto49 wrote: »
    What kind of discount do Polkies get ? I need a heater fan for a 93 Bonneville that I'm selling.:smile:
  • halo71
    halo71 Posts: 4,638
    And I need ball joints for a 99 Ford Ranger XLT. :lol:
    --Gary--
