building subwoofers. what do u put inside for insulation?
ravaneli
ravaneli Posts: 530
edited September 2012 in Speakers
I got two huge boxes with cherry veneer outer layer that i have been staining last few days ( several coats).
what do I have to put inside ? They will be both powered by my B&K amp. What kind of foam or insulation do I need?
I have never done that and i don't want some fancy expencive material but something that will do the job. Also, how do I attach it - glue? or just stuff it in?
BlueFox wrote: »
I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
But as in all things your perception is your reality.
Post edited by ravaneli on
  • ravaneli
    ravaneli Posts: 530
    BlueFox wrote: »
  • 20hz
    20hz Posts: 636
    Too expensive , i have been building car and home subs for 20+ years , on smaller car subs 1 cu foot I use regular house wall insulation it gets stapled every 6 inches so it looks kinda puffy , I have gone the exact cabinet volume from the manufacture and tried no insulation than the above method , the insulated method sounded deeper .
    My big sub 7 cubic after all the braces I used 2" of wall insulation , I use polyfill ( from the fabric store) but to my ears a complete fill ( unlike tacking to walls ) has less bang for the buck . I have used dynamat foam the ebay stuff in ravaneli's repley ( I found a box at work ) anything works as long as its not to dense . Now ported cabinets if done right wont need insulation . I built a ported sub once it sounded wrong even though it was tuned at 23 hz , so just go max size and seal it with a thin layer of insulation on the walls if you are going minimum just do the wall past the magnet only you will find the sub more punchy .
    NO glue the ?alcohol? will rot the surround if you put it in before it dries ( a few days after it stops stinking ) .
    ravaneli wrote: »
  • xj4094dg
    xj4094dg Posts: 1,158
    Pics?
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • ravaneli
    ravaneli Posts: 530
    i will get some pics tomorrow. Already ordered the eggcrate foam. Found 40 sq feet for 50 bucks.. i need only 15 but i can use it on something else.
    I actually got the boxes for free because they arrived with a small damage to a couple of the corners and i wanted to return them. The vendor didn't want them back and just refunded me in full and left me the boxes. They were 1" MDF and cherry veneer. Very thick and solid. After all the stain and polyurethane they look fat and gorgeous, even with the sloppy stain job I did. Now I don't want to cut corners and ordered good insulation and some HUGE posts, bigger than mu thumb.
    My subs already sound great (to me) in the tiny and thin car subwoofer boxes, but those are trapezoidal and have worn out carpet on the outside and are from 3/4 " mdf and i can feel them vibrate when they hit. No insulation either. I can't wait to hear these..
    BlueFox wrote: »
  • rebuy
    rebuy Posts: 694
    One of the most important things to remember is to have an airhole in the box so your speakers don't over heat or anything.
  • ravaneli
    ravaneli Posts: 530
    well that will make them ported? i like the sound of sealed. Will buy new drivers if they go bad, but i dont really push them
    BlueFox wrote: »
  • halo71
    halo71 Posts: 4,639
    What.....you asking questions? I thought you knew all things about audio and the related. :cheesygrin:
    --Gary--
  • ravaneli
    ravaneli Posts: 530
    i can't find anything about filling the sub box. people use all kinds of stuff, there are no guidelines.
    now what about the glue? How do i attach the foam? that comment about the glue rottening the mdf... that concerns me..
    BlueFox wrote: »
  • westmassguy
    westmassguy Posts: 6,850
    You could order Dacron Batting from Parts Express, or use what I do in 99% of my builds, Polyfill. It comes in Bags, and is available at Walmart or any good Fabric Store. Same damping properties as Dacron, for a lot less money.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • onebadchad
    onebadchad Posts: 364
    Id try straw, its cheap and readily available, get a bail and have some left for the garden. Gives u more of a natural sound
    Hello Kitty am/fm CD player
  • rebuy
    rebuy Posts: 694
    ravaneli wrote: »
    No, the voice coil is so big on subs that they get overheated so you cool them by way of an airhole. I think the straw is a great idea too since it will give the bass an organic sound that you won't get with man made materials.
  • ravaneli
    ravaneli Posts: 530
    i know it's sloppy, with stain not evenly distributed, but for me it's good enough :)
    BlueFox wrote: »
  • ravaneli
    ravaneli Posts: 530
    do you see the end of the speaker terminals? How on earth am i supposed to attach the wire to that???
    BlueFox wrote: »
