What influences sound the most
CCNJ
CCNJ Posts: 384
edited October 2012 in 2 Channel Audio
I want to limit the discussion to electronics and remove speakers, source, room treatments and cables from the discussion. Which of the following three components do you feel has the greatest ability to influence sound quality in a two channel setup. I welcome any supporting comments or anecdotes.
Preamp
DAC
Power Amp
Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
Post edited by CCNJ on
«13
  • pearsall001
    pearsall001 Posts: 5,328
    edited August 2012
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited August 2012
    For my setup it was the preamp.
    EndersShadow Posts: 17,722
    edited August 2012
    I would think it would be whatever piece of gear is the one converting the signal to analog. Any changes upstream from that component cant add or enhance sound that has been removed.
    So if your going digital to your pre-amp and then analog to your amp, I would say your pre. If your going digital to your DAC and then analog to a pre, I would say your pre, ect.
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2012
    Power amp from that line up.
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    Some differing opinions so far. I haven't done enough experimenting to offer any more than a gut feel right now. I am curious however if am allocating dollars smartly on the electronics front.
    nooshinjohn Posts: 26,001
    edited August 2012
    Tubes...
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    Tubes...
    Tube pre, tube dac, tube power amp?
    edited August 2012
    I can only speak to amps and pre's, but the two most dramatic improvements in my rig came about with a Rogue Audio pre and my tube amps. Detail is off the charts, as is imaging, soundstage, and transparency. Speakers are not part of your discussion, so I will limit my comments to say this. Little Maggies are like being in the tenth row of a performance, and the big ones put me on the stage.
    Tubes give life to sound in the same way that a great performer gives life to his or her instrument. Tubes are essential if you want to hear everything the artist intended, and a few things they didn't. I swear I could hear a **** on one recording.:lol:
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    Thanks for elaborating. What rogue pre did you have that made such a dramatic improvement and why isn't it in your current sig today.
    heiney9 Posts: 25,504
    edited August 2012
    CCNJ wrote: »
    Preamp
    DAC
    Power Amp
    This is not a flippant answer, but all 3. You can't cut corners on either piece and make up that cut corner with the other 2 pieces of gear. I know it's not what you wanted to hear, but it's true. If you already have a capable amp and preamp, I have found the most difference in DAC's, even DAC's that use the same digital chipset.
    edited August 2012
    The Rogue Audio Perseus with Magnum upgrades and phono stage. It was replaced by the Sunfire Classic Tube pre, also with a phono stage.
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    heiney9 wrote: »
    I do realize that everything in the chain makes a difference but I wanted to get opinions on which of the three made the most dramatic improvement in people's rigs based on their own experimentation.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2012
    +1 h-9. Went through 1/2 doz. amps till i found the sound i wanted....went through a bakers doz. of pre's till i found one my amp liked. And the DAC was the icing on the cake that they both liked. Its expieramentation to find the "senergy". Of the diff units that produces tje results your ears like. And i cant even count how mamy speakers i went thrpugh till i found the sound i have now.so therw ia no one single answer to pur question. Sorry but you asked.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    edited August 2012
    Good question, but if you ask me.......YOU do.
  • Face
    Face Posts: 14,340
    edited August 2012
    Like it or not, the room and speakers do.
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    Face wrote: »
    For me, speakers would top the list but i wanted to focus this discussion on electronics.
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    tonyb wrote: »
    Took me a minute to get it...good answer
  • Face
    Face Posts: 14,340
    edited August 2012
    CCNJ wrote: »
    In that case, it varies. Some manufactures design their products flat with the lowest amount of distortion, some tilt FR in either direction, some add a little extra distortion for "lushness". It depends more on the exact component in question than the category.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited August 2012
    My first "WHOA" moment came when I plugged in the Adcom GFP-750 preamp.
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2012
    Once you get reasonably good versions of those three items then you will be amazed at how much sound can be improved with vibration isolation, and all forms of cables (power, speaker, ICs).
  • mantis
    mantis Posts: 17,561
    edited August 2012
    The preamp does.
    I have noticed by adding amps to certain systems that their was little or no change at all in the overall sound quality. More dynamic range and more control which to some may think it's a change in sound quality and I can agree to a point.
    I'm not saying all amps sound the same , some sound very different from the other depending on the radical differences in power , design , etc. Technically all amps should sound the same but they don't. In many rigs , changing out an amp is less noticeable then the preamp.
    DAC's change the sound depending on what you are comparing them to. If you have 2 good DAC's , it's hard to tell them apart. A cheap internal DAC compared to a good quality external DAC will yield easier to hear results.
    All things in ones system matter as you are building a system , not focusing on each part but how they all work together. This is the key to a successfull sounding system.
    Dan
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2012
    A Tube Pre.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited August 2012
    mantis wrote: »
    The preamp does.
    Couldn't disagree more with your comments about amps and dac's. I've heard it with my own ears, and they don't lie. The bolded part is ridiculous to say and I have found power ratings have very little to do with sound quality unless you have speakers at the extreme end that need gobs of power to operate properly or you have an extremely large room to pressurize. Then it's not so much about differences in quality with wattage, but having the proper power to overcome the inefficiency or room size.
    mantis wrote: »
    Now the above, I agree with that.
  • newbie308
    newbie308 Posts: 811
    edited August 2012
    If you are not a fan of digital, then I think the most important component in an analog system would be the phono cartridge. If the detail is not tracked then it cannot be reproduced. I was amazed at how different the music sounds with various cartridge and stylus types. I will admit that a tube pre made a large impact on the sound quality of my system, but the cartridge (or dac for digital) is key.
  • vcwatkins
    vcwatkins Posts: 1,992
    edited August 2012
    Tube pre here.
  • pearsall001
    edited August 2012
    Out of the three choices listed I'll go with the DAC as having the most impact. Of course the room trumps them all...but of course you already know that.
  • Conradicles
    Conradicles Posts: 6,377
    edited August 2012
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2012
    Whatever the weakest link is, that is the piece that is influencing the sound the most at any given time.
    Not exactly what you were looking for, but it's the truth.
    Now, if I had to put them in order, I'd say:
    - Dac
    - Pre
    - Amp
    Why? Because if your DAC and pre are good, an amp can't make it sound really crappy unless it's defective. If your amp and DAC are good, a pre could possibly make it sound really crappy, even if it wasn't defective. But if your pre and amp are good, a DAC can definitely make it sound crappy, even just operating as it was intended.
    One reason for this may be that there just aren't a lot of super crappy dedicated 2-channel home audio preamps and poweramps out there, whereas there are a ton a crappy DAC's, mainly internal, but external as well.
    edit: so given my theory, why is it that I've spent the most money on my amp, followed by me pre, followed by my DAC??? I don't know.
  • halo71
    halo71 Posts: 4,638
    edited August 2012
    For me, when I went from using a AVR as a pre to using an actual dedicated preamp. It was a night and day moment.
    --Gary--
    edited August 2012
    I would have to agree that everything makes a difference. But with Face, I'd have to go with speakers. In my experience there are some speakers that sound "good" with almost anything? The two in particular that come to mind are classic Polk Monitors and ADS. It's is HARD to make those sound bad, period.
    Along with John I'd also go with "tubes" next. I've found that almost anything with good tubes put into the chain has an "effect", usually a good one! The easiest to see instantly, is to get a hold of a good tube CDP and run it.
    DACs yeah, I'm on record on those. I think they're important but they're really, really expensive if you're going to get a "good" one!
    And a decent tube integrated. Stick a fork in it you're done for now!
    Enough for now!
    cnh
