What influences sound the most
CCNJ
I want to limit the discussion to electronics and remove speakers, source, room treatments and cables from the discussion. Which of the following three components do you feel has the greatest ability to influence sound quality in a two channel setup. I welcome any supporting comments or anecdotes.
Preamp
DAC
Power Amp
Preamp
DAC
Power Amp
Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
Post edited by CCNJ on
My AVR!
For my setup it was the preamp.
I would think it would be whatever piece of gear is the one converting the signal to analog. Any changes upstream from that component cant add or enhance sound that has been removed.
So if your going digital to your pre-amp and then analog to your amp, I would say your pre. If your going digital to your DAC and then analog to a pre, I would say your pre, ect."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Power amp from that line up.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Some differing opinions so far. I haven't done enough experimenting to offer any more than a gut feel right now. I am curious however if am allocating dollars smartly on the electronics front.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4 -
Tubes...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Tubes...
Tube pre, tube dac, tube power amp?Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
I can only speak to amps and pre's, but the two most dramatic improvements in my rig came about with a Rogue Audio pre and my tube amps. Detail is off the charts, as is imaging, soundstage, and transparency. Speakers are not part of your discussion, so I will limit my comments to say this. Little Maggies are like being in the tenth row of a performance, and the big ones put me on the stage.
Tubes give life to sound in the same way that a great performer gives life to his or her instrument. Tubes are essential if you want to hear everything the artist intended, and a few things they didn't. I swear I could hear a **** on one recording.
nooshinjohn wrote: »I can only speak to amps and pre's, but the two most dramatic improvements in my rig came about with a Rogue Audio pre and my tube amps. Detail is off the charts, as is imaging, soundstage, and transparency. Speakers are not part of your discussion, so I will limit my comments to say this. Little Maggies are like being in the tenth row of a performance, and the big ones put me on the stage.
Thanks for elaborating. What rogue pre did you have that made such a dramatic improvement and why isn't it in your current sig today.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Preamp
DAC
Power Amp
This is not a flippant answer, but all 3. You can't cut corners on either piece and make up that cut corner with the other 2 pieces of gear. I know it's not what you wanted to hear, but it's true. If you already have a capable amp and preamp, I have found the most difference in DAC's, even DAC's that use the same digital chipset.
The Rogue Audio Perseus with Magnum upgrades and phono stage. It was replaced by the Sunfire Classic Tube pre, also with a phono stage.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I do realize that everything in the chain makes a difference but I wanted to get opinions on which of the three made the most dramatic improvement in people's rigs based on their own experimentation.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
+1 h-9. Went through 1/2 doz. amps till i found the sound i wanted....went through a bakers doz. of pre's till i found one my amp liked. And the DAC was the icing on the cake that they both liked. Its expieramentation to find the "senergy". Of the diff units that produces tje results your ears like. And i cant even count how mamy speakers i went thrpugh till i found the sound i have now.so therw ia no one single answer to pur question. Sorry but you asked.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Good question, but if you ask me.......YOU do.HT SYSTEM-
lsi 9's -
Like it or not, the room and speakers do."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
For me, speakers would top the list but i wanted to focus this discussion on electronics.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Took me a minute to get it...good answerRig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
In that case, it varies. Some manufactures design their products flat with the lowest amount of distortion, some tilt FR in either direction, some add a little extra distortion for "lushness". It depends more on the exact component in question than the category.For me, speakers would top the list but i wanted to focus this discussion on electronics."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
My first "WHOA" moment came when I plugged in the Adcom GFP-750 preamp.
Once you get reasonably good versions of those three items then you will be amazed at how much sound can be improved with vibration isolation, and all forms of cables (power, speaker, ICs).Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
The preamp does.
I have noticed by adding amps to certain systems that their was little or no change at all in the overall sound quality. More dynamic range and more control which to some may think it's a change in sound quality and I can agree to a point.
I'm not saying all amps sound the same , some sound very different from the other depending on the radical differences in power , design , etc. Technically all amps should sound the same but they don't. In many rigs , changing out an amp is less noticeable then the preamp.
DAC's change the sound depending on what you are comparing them to. If you have 2 good DAC's , it's hard to tell them apart. A cheap internal DAC compared to a good quality external DAC will yield easier to hear results.
All things in ones system matter as you are building a system , not focusing on each part but how they all work together. This is the key to a successfull sounding system.Dan
A Tube Pre.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
The preamp does.
Couldn't disagree more with your comments about amps and dac's. I've heard it with my own ears, and they don't lie. The bolded part is ridiculous to say and I have found power ratings have very little to do with sound quality unless you have speakers at the extreme end that need gobs of power to operate properly or you have an extremely large room to pressurize. Then it's not so much about differences in quality with wattage, but having the proper power to overcome the inefficiency or room size.All things in ones system matter as you are building a system , not focusing on each part but how they all work together. This is the key to a successfull sounding system.
Now the above, I agree with that."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
If you are not a fan of digital, then I think the most important component in an analog system would be the phono cartridge. If the detail is not tracked then it cannot be reproduced. I was amazed at how different the music sounds with various cartridge and stylus types. I will admit that a tube pre made a large impact on the sound quality of my system, but the cartridge (or dac for digital) is key.Enjoying the journey while never attaining the destination.
Tube pre here.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Out of the three choices listed I'll go with the DAC as having the most impact. Of course the room trumps them all...but of course you already know that.
Your ears.
Whatever the weakest link is, that is the piece that is influencing the sound the most at any given time.
Not exactly what you were looking for, but it's the truth.
Now, if I had to put them in order, I'd say:
- Dac
- Pre
- Amp
Why? Because if your DAC and pre are good, an amp can't make it sound really crappy unless it's defective. If your amp and DAC are good, a pre could possibly make it sound really crappy, even if it wasn't defective. But if your pre and amp are good, a DAC can definitely make it sound crappy, even just operating as it was intended.
One reason for this may be that there just aren't a lot of super crappy dedicated 2-channel home audio preamps and poweramps out there, whereas there are a ton a crappy DAC's, mainly internal, but external as well.
edit: so given my theory, why is it that I've spent the most money on my amp, followed by me pre, followed by my DAC??? I don't know.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
For me, when I went from using a AVR as a pre to using an actual dedicated preamp. It was a night and day moment.--Gary--
I would have to agree that everything makes a difference. But with Face, I'd have to go with speakers. In my experience there are some speakers that sound "good" with almost anything? The two in particular that come to mind are classic Polk Monitors and ADS. It's is HARD to make those sound bad, period.
Along with John I'd also go with "tubes" next. I've found that almost anything with good tubes put into the chain has an "effect", usually a good one! The easiest to see instantly, is to get a hold of a good tube CDP and run it.
DACs yeah, I'm on record on those. I think they're important but they're really, really expensive if you're going to get a "good" one!
And a decent tube integrated. Stick a fork in it you're done for now!
Enough for now!
