Yaqin MS-34d
Geez, people are quick to judge. Spend some time with it and junk the stock tubes for something better. A tube amp is really only as good as the tubes you run. Unfortuneatly, stock Chinese tubes are about the worst.
Thats the plan....start with 61np then move to el-34 ...lets see the difference -
this_is_vv wrote: »Thats the plan....start with 61np then move to el-34 ...lets see the difference
The 61np has been changed....still looking for difference ...saw some difference in music....in BASS...some whispers..
V -
this_is_vv wrote: »The 61np has been changed....still looking for difference ...saw some difference in music....in BASS...some whispers..
V
is the 61np better or i have mullard 8100 ???which one is better...listening both sound same... -
HI my tube savious...
Suddenly one day on my yaqin ms-34d amp one channel was not working...i noticed one of my el-34b tube was not glowing at all...i switched the tubes around and suddenly the amp is working fine...is that means tube is gone???
do i need to do anything...also i see some difference in sound...
V -
Perhaps the tube wasn't seated properly.SDA SRS 2.3TL's
SDA 2B TL's -
agreed.....I went from the stock chinese 6n8p on the yaqin cd-3 Tube Buffer to Rca 6sn7GTB Black Plates and then to Rca 6sn7GT VT-231......the upgrade was extraordinary.....I heard instruments,like brushes on cymbals,that I hadn't heard before....peter -
Eventually amp plate got burned so that went ti eBay with loss
