Yaqin MS-34d
  • this_is_vv
    this_is_vv Posts: 24
    edited February 2012
    heiney9 wrote: »
    Geez, people are quick to judge. Spend some time with it and junk the stock tubes for something better. A tube amp is really only as good as the tubes you run. Unfortuneatly, stock Chinese tubes are about the worst.
    Thats the plan....start with 61np then move to el-34 ...lets see the difference
  • this_is_vv
    edited March 2012
    this_is_vv wrote: »
    The 61np has been changed....still looking for difference ...saw some difference in music....in BASS...some whispers..
    V
  • this_is_vv
    edited March 2012
    this_is_vv wrote: »
    V
    is the 61np better or i have mullard 8100 ???which one is better...listening both sound same...
  • this_is_vv
    edited April 2012
    HI my tube savious...
    Suddenly one day on my yaqin ms-34d amp one channel was not working...i noticed one of my el-34b tube was not glowing at all...i switched the tubes around and suddenly the amp is working fine...is that means tube is gone???
    do i need to do anything...also i see some difference in sound...
    V
  • michaeljhsda2
    michaeljhsda2 Posts: 2,207
    edited April 2012
    Perhaps the tube wasn't seated properly.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • pietro944
    pietro944 Posts: 720
    edited April 2012
    heiney9 wrote: »
    agreed.....I went from the stock chinese 6n8p on the yaqin cd-3 Tube Buffer to Rca 6sn7GTB Black Plates and then to Rca 6sn7GT VT-231......the upgrade was extraordinary.....I heard instruments,like brushes on cymbals,that I hadn't heard before....peter
  • this_is_vv
    edited December 2012
    Eventually amp plate got burned so that went ti eBay with loss
