Vr3 Fortress Edition Mods
2456
  • PrazVT
    PrazVT Posts: 1,607
    edited February 2012
    That's why I avoid looking at Trey's threads ...just too tempting. Those look sweeeeeet dude!!
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    VR3 Posts: 29,449
    These will fit any Polk speaker in the last 10 or so years with a bi-wire/bi-amp plate....
    You can use the stock crossovers or modded - but obviously you, I or someone else would have to mod them to get them to that stage. I am not prepared to fork out the $$$ to prebuild crossovers... :)
    These will definitely fit any Polks though! :)
    VR3 Posts: 29,449
    thsmith wrote: »
    How does it sound, what are the differences over stock ?
    They should feature similar upgrades your SDAs had when you modded them... better clarity, definition, staging - bass response and control, etc
    Also!
    THANK YOU ALL FOR THE COMPLIMENTS!! :)
    VR3 Posts: 29,449
    Does anyone have any alternatives for perfboard or a higher grade of perfboard?
    VR3 Posts: 29,449
    RTiA7/CSiA6 combo sporting the Fortress - should be fun!
    I am interested to see if I can pull off a PTP wiring with the A7 on the small boards...
  • jbooker82
    jbooker82 Posts: 1,627
    sweet deal. Who is getting these? Do you have some kind of gasket to seal the aluminm plate / protect the RTI's wood finish. Sheet of cork from an auto parts store would work well. Foam weather stiping would also work well.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    VR3 Posts: 29,449
    Yep, I am using foam gasket tape from Parts Express - comes standard :)
    I honestly do not know the forum member's name. (Screen name)
    And thank you! :)
  • gp4jesus
    gp4jesus Posts: 2,019
    Have you considered selling just the plates for those of us that like doing that stuff almost as much as you? (please?)
    *all connected w/Premiere ICs
    VR3 Posts: 29,449
    Yes.
    They are 35 each + shipping.. :) (Engraved plates with personalized info would be $5.00 per plate)
    That includes nuts, washers, bolts, etc
  • OOsemka
    OOsemka Posts: 60
    VR3 wrote: »
    And thank you! :)
    Hi,
    This is me. I am new to this forum. I read more then share my own thoughts. I wonder if you got my crossovers yet.
    Thanks for working on them for me.
    Music Room:
    Paradigm Signature S8
    Paradigm Signature C5
    Paradigm Signature S2
    Receiver - Onkyo tx-nr809
    Amplifier - Adcom 5802
    Office system:
    Fronts - Polk RTI A7 (Trey Mod)
    Center - Polk CSI A6 (Trey Mod)
    Rears - Polk FXI A6
    Sub - BIC F12
    Receiver - SONY STR-DG1000
    Amp - Carver TFM-35
    VR3 Posts: 29,449
    I did receive your crossovers today! Just got home from a 11 hour day! *wooooo*
    I appreciate the opprotunity!
  • WESTORTHE3RD
    WESTORTHE3RD Posts: 8
    edited March 2012
    Im wondering if you have ever did a set of rti 10 crossovers?Had a look at the ones in my 10's and wrote down the cap values.A couple of 10's an eight, 5.1 and 2 of 0.47j.I kinda thought the 10's and the a7 were supposed to be the same speaker internally, but when I look at the pic of the a7 crossover you did I think I'm looking at a lot higher value caps than I have in my rti 10 crossovers.The biggest difference that I think I'm seeing is an 18 in the sub board where I have just a piddly 5.1,as well as an 18 in the mid tweeter board in place of a 10.I'm not a techno wizard of any sort, so please bear with me if I'm **** something up here.Also wondering if it would pay to swap out caps and resistors to a7 values if the urge to upgrade struck?I've heard said the a7 and 10 sound different, the a7 being inproved;people credited the a7 fancyer cabnet. Maybe not...:wink:
    VR3 Posts: 29,449
    edited March 2012
    I would not change any values, using nicer parts would drastically improve your speakers.
    EMail me to go further -
    Vr3Mods@gmail.com
    VR3 Posts: 29,449
    edited March 2012
    RTiA7 bass section, point to point!!
    VR3 Posts: 29,449
    edited March 2012
    Kind of cool - would be easy to do a tri-wire configuration if so desired...
    Separated the mid and tweeter section completely - nice easy layout... :)
    VR3 Posts: 29,449
    edited March 2012
    This was an extremely difficult mod to do... but I still like it better than using the Polk circuit boards! :P
    VR3 Posts: 29,449
    edited March 2012
    Both done! W000t
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited March 2012
    You shouldn't cut those leads so short on the caps, some look less than 1/4". It can cause excessive heat to enter the cap when soldering.
    VR3 Posts: 29,449
    edited March 2012
    Noted, thank you.
    The lead is actually about 5/8" or so (total). I usually cut them down to about 5/8-3/4 and will wrap the connecting wires around it and solder on to it - has worked pretty well so far. I definitely would never cut it down to the 1/4 range - outside of the reason you mentioned it just would not be very secure.
  • WilliamM2
    edited March 2012
    I meant that it looked like a 1/4" from the solder to the cap itself. Not far for the heat to disipate.
    VR3 Posts: 29,449
    edited March 2012
    I understand what you are saying.
    Unfortunately working in such tight constraints I sometimes I do not have much of a choice. I usually am not on the metal to long - I have a variable heat (digital) soldering iron so I can control it pretty well...
    As noted - I have not experienced issues caused by such circumstances... in the future though will make adjustments where possible.
  • gp4jesus
    edited March 2012
    VR3 wrote: »
    Vr3Mods@gmail.com
    Trey you're the man!
    VR3 Posts: 29,449
    edited March 2012
    Group pics!
  • OOsemka
    OOsemka Posts: 60
    edited March 2012
    They look really good. Thank you for working on them for me. I will let you know how they behave inside the speaker :-D
    Music Room:
    Office system:
    Rears - Polk FXI A6
    Sub - BIC F12
    Amp - Carver TFM-35
    VR3 Posts: 29,449
    edited March 2012
    Thank you for the opprounity! Cant wait to hear your thoughts!! :)
  • OOsemka
    OOsemka Posts: 60
    edited March 2012
    I have received the crossovers and installed them right away. The quality of the work you did Trey is outstanding, it's too bad those x-overs are inside the speaker and not outside. Also I have never received the package that would be that well packed.
    I am in the process of burning the crossovers in, but I can already hear a difference in sound. I don't know how to describe it but my it is much more detailed, specially in a mid area. They also sound cleaner.
    Thanks so much for the awesome communication you were able to provide during the process. I just realised we have exchanged about 70 emails all together. That's more then I posted comments on this forum :-).
    So what else can you upgrade for me ? :-P
    Music Room:
    Office system:
    Rears - Polk FXI A6
    Sub - BIC F12
    Amp - Carver TFM-35
    VR3 Posts: 29,449
    edited March 2012
    haha!
    Thanks man! Let me know how the burn in process!
    I was noting the average exchange of emails is 70-100 per crossover mod I have done!! LOL
    VR3 Posts: 29,449
    edited March 2012
    TSI400 Fortress Mods coming soon!
    Clarity Cap ESA on the tweeter network, Solen in line midbass, nichicon shunt (speaker series) bypassed by ESA series, Mills resistors - point to point wiring!
    Pics to follow!
  • NWLanding
    NWLanding Posts: 8
    edited March 2012
    VR3 wrote: »
    Pics to follow!
    Pics will be great to follow your progress! :cheesygrin:
    VR3 Posts: 29,449
    edited April 2012
    TSI400 mods!
