End Caps Done!
2
  • chandler9a
    chandler9a Posts: 878
    edited February 2012
    I'd be interested in the caps for 1C's as well. Very nice work, I just had my first experience with curly maple last night. I couldn't take my eyes off it after the first coat went on, beautiful stuff!
    Might be interested in caps for 2.3's as well.
  • Bubinga99
    Bubinga99 Posts: 283
    gdb wrote: »
    Joinery
    Care to elaborate? Musky1963 is just using a solid rectangular slab with no joinery, and I think he's referring to the fact that most of the time, all you see of the caps are the edges (for the taller SDA's anyway) so the "eyes" wouldn't have the visual impact they'd have for a larger visible surface.
  • gdb
    gdb Posts: 6,012
    Joinery techniques can be used to edge the slab with an "eye- rich" piece of wood or, you could just content yourself with the knowing that the eyes are nicely visible on the top surface. I, personally, would edge with solid wood some MDF that was veneered rather than using slab wood but, that's just me and my preferences. For me it's more important how speakers sound, not their looks.
  • marcgd1959
    marcgd1959 Posts: 11
    hi, i'm the person in the other thread who had his sda 1C's get manhandled by ups and getting them roughed up pretty badly. i see by this thread that the top and bottom can be replaced. i am interested in this as mine are now pretty rough. i thought i might ask as a sda novice who has been looking to own a pair of these for about 27 years . . . how does one remove the top and bottom wood piece without destroying the rest of the speaker itself?
    thanks ahead of time.:neutral:
  • Mike Reeter
    Mike Reeter Posts: 4,315
    marcgd1959 wrote: »
    Both the top and bottom caps on the 1C's are held onto the cabinet by glue and long staples, unlike the caps on the bigger SDA's that are bolted on. I would suggest a thin pry bar and a rubber mallet to remove them. Once you get the caps "started" they will come off pretty easily. I have used a 2x4 block of wood on edge and a hammer and tapped on the leading edge of the caps to get them "started" also.
    I use a constuction grade of glue (Liquid Nails) to replace the caps and forgot the staples. Let them dry for 24 hours before moving.
  • musky1963
    musky1963 Posts: 275
    The caps are 1" thick or VERY close. Sal, don't worry, you aren't in the back of the bus :lol:
    Jeff
  • Bubinga99
    Musky, did you spend any time considering thicker caps? To my eye, the 1" caps look disproportionately thin (on the 2.3TL's anyway). I did a quickie mock-up a couple years back (stacked up layers of 1/8 and 1/4 mdf) and if my memory serves, I think I decided 1-1/4" thick was the sweet spot for the 2.3TL's, with 1-1/2" looking disproportionate in the other direction. Inch-and-a-half might work for the larger 1.2's though. Anyways, just wondering if you considered thicker caps and what you (or anyone else for that matter) concluded.
  • quadzilla
    quadzilla Posts: 1,543
    Yeah, you can put me down for a set. Those are phenomenal.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Bubinga99
    I wouldn't glue the caps on if you're replacing them with solid wood caps. You may get lucky and they may not split/crack over time, but why tempt fate? It's easy enough to just install 4 hanger bolts in the cap like the larger SDA's and drill slightly elongated holes in the cabinet (elongated in the cross grain direction relative to the grain on the solid cap). Plus they are easier to remove in the future.
  • Mike Reeter
    Bubinga99 wrote: »
    Sounds like a plan to me.
  • headrott
    headrott Posts: 5,496
    Recieved my end caps from Jeff (musky1963). I am going to install them on Wednesday. I will also post some pictures after they are installed.
    Greg
    Toolfan66 Posts: 18,066
  • headrott
    Did you order some Larry? Have you installed them if you did?
    I'm on the list..
  • musky1963
    Glad you got them okay :cool: . I have another set done, so if you want them(Larry), please shoot me a pm. Jeff
    Jeff
    PM me price and info..
    F1nut Posts: 51,781
    Bubinga99 wrote: »
    He's joining boards together to make the slabs.
  • musky1963
    Using several boards or even ripping a single wide one into a few boards, then regluing them back together is better than using just a single wide board. It relieves the stress in wood and less chance of warping.
    Jeff
  • musky1963
    Also, I wouldn't consider gluing/ironing on veneer over mdf "joinery". Anyways, I have furniture that is pretty long in the tooth and rarely have I had any issues.
    Jeff
    F1nut Posts: 51,781
    I agree, was just pointing out to Bubinga99 that you are using joinery.
  • musky1963
    I have a moisture meter that I use when buying. You can get kiln dried wood at 8% and if the humidity is higher, which it always is here, it will even out in the low teens or 11-12%. Winter is actually drier in humidity. I rarely buy kiln-dried stock as I prefer air-dried/stickered wood. Rule of thumb is it takes about 1 year for every inch of thickness. ie: oak is full of water and weighs a ton when fresh cut. Air-dried maple is pretty stable after time and I think it has better color. BTW, the thick stock that I have(like the table I made you) has been air-dried for atleast 20 years :eek: .
    Jeff
  • musky1963
    Toolfan66, I sent you a pm early this am.
    Jeff
    musky1963 wrote: »
    I got it, have been at work and try not to post during that time. The 1.2tl's have a raidus on all four corners not squared on the back side like the ones Greg received. I am asuming that the caps are the same size though..
  • musky1963
    Can I use the same caps and just make the same radius on the back corners perhaps?
    Jeff
  • musky1963
    edited March 2012
    Greg, did you get them put on yet?
    Jeff
  • vcwatkins
    vcwatkins Posts: 1,993
    edited March 2012
    Could you PM me price and info on SRS2's?
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2012
    Well Musky, if you were on economic hard times, Club Polk has just solved that problem....LOL. Nice work man!
  • musky1963
    edited March 2012
    LOL, alot of tire kickers. Actually, only Greg has purchased some caps as of yet :redface:
    Jeff
  • brgman
    brgman Posts: 2,859
    edited March 2012
    I'll get the 1C to you.My 2.3tl's look good so no need to screw with them yet.The 1C's need love first.
    I'm all in though so hang in there musky man!:wink:
    I’M OFFENDED!!!!
  • headrott
    edited March 2012
    musky1963 wrote: »
    I only have the top of the left so far. I've been busy working on one of my SACD players as well. Sorry it's taking so long. One thing is that the holes you drilled into the caps are not precisely lined up with the original holes. I still got the cap on, but barely.
    Greg
