End Caps Done!
musky1963
Okay, I am nearly done putting the final finishes on the curly maple end caps. (I will be putting them up on the classifieds shortly). I am going to go into a little production run right now. I could not find the correct hangar bolts at Ace hardware, so I would just drill the holes if the buyer wanted them and they can use their existing ones. I have 2.3TL's and wondered if anyone knew if all the hangar bolts and tee-nuts are spaced the same for other Polks, such as the 1.2's, 2.3's, TL series, etc?
Jeff
I am still deciding what to charge. It takes about 10 bd. ft. of this maple for 2 speakers. I just placed an end cap on my 2.3t's to see what it will look like and I have to say it looks awesome
. I guess it helps that I am not a huge fan of oak. I can do the sides, but I would need exact measurements and pics for those. Jeff -
Keep me in the loop on these for 2.3tl's please musky one.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
And me as well. Have you considered doing them out of slabs instead of boards? And do you ever run across tiger maple?Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Yeah, I am absolutely interested in some for the 2.3TL's! As Rob said, Tiger Maple would also be great! Great offering! Thank you very much!
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
The term "tiger" is used loosely. Some people call it curly, fiddleback, tiger etc. Some of the stripes/figure is narrow, close together. I thought about the thick stock for caps, but personally, I think it might be a bit much.Jeff
Have you thought about African Bubinga wood?
Greg
Yes, I might have a small amount. Mighty rare in these parts. I mostly have maple, cherry and walnut. Very limited on exotics. Teak might be nice too.Jeff
Cocobolo would look nice, but it is crazy expensive just like the rest of the exotics.:eek:Testing
Testing
Testing -
When I think of tiger maple, this is what I'm referring to:
http://www.cswoods.com/csw_education.htm
Second picture down, captioned "tiger maple". That's all I've ever known it as.Turntable: Empire 208
Arm: Rega 300
I might be interested in end caps and side panels for srs2s.
Dymonwood may be a cheaper alternative Sal (I'm not really sure).
Not sure of the dimensions of the end caps, but I know they sell dymonwood in larger sheets.
Some of it is horribly ugly, but I think the Cocobolo looks really good.
Attachment not found.Testing
Testing
Testing -
I saw the attachment to this thread and was sadly disappointed in the Feet vs. Pics of these awesome caps. !!
Post some cap pics!Too much **** to list.... -
Not the best pics as my house is dark and I have to give the caps another few coats of oil. I will attempt some better pics. These do not even show the figure properly and how 3-d looking it really is.
Jeff -
Yep, I'll take some!! Phenominal looking!!:biggrin:
Greg
:eek::eek::eek: Best cabinet mod I have seen!
Very, Very Nice!Too much **** to list.... -
Nice work Musky1963. Yep, 3d figure is hard to capture with a camera. An outdoor photo in sunlight seems to be one of the better ways to catch it but you still have to futz around with angles. Did you dye it to try and match the original color of the oak caps, or to match furniture in your room? This reminds me, I've wanted to makes some new end caps as well and never got around to it. I'd probably veneer it though, and surround the veneer field with solid trim and possibly a thin accent strip in between. I never really decided on what woods to use, but was down to a few final candidates. I might have to try and revive that project in the spare time that I seldom have these days....
Birdseye is best.
If you make any for 1Cs I want some. I assume you do the top and bottom.Speakers: SDA-1C (most all the goodies)
might be a +1 on the 1C'SMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Once again nice work Muskey, beautiful wood.
Birdseye is best.
X2
I've always loved it foremost too but the the Curly/Tiger is 2nd only by a smidgen in my judgement. I guess I favor either one equally as much.
But man those top caps look gorgeous in Tiger/Curly!!
Probably the better choice of wood in this case for sure.
Great job!Most people just listen to music and watch movies. I EXPERIENCE them.
Thanks guys! I have used birdeye and it is nice, but only for certain pieces. These caps are only 1" thick at the edge and birdseye wouldn't look great.......kind of boring maybe? Now on a dresser or something with alot of visible facing you, it looks good if it has heavily populated eyes that is.Jeff
Very interested in end-caps (and side panels) for SRS2s. Those are spectacular!
Joinery -
I'd be interested in the caps for 1C's as well. Very nice work, I just had my first experience with curly maple last night. I couldn't take my eyes off it after the first coat went on, beautiful stuff!
Might be interested in caps for 2.3's as well. -
Joinery
Care to elaborate? Musky1963 is just using a solid rectangular slab with no joinery, and I think he's referring to the fact that most of the time, all you see of the caps are the edges (for the taller SDA's anyway) so the "eyes" wouldn't have the visual impact they'd have for a larger visible surface. -
Joinery techniques can be used to edge the slab with an "eye- rich" piece of wood or, you could just content yourself with the knowing that the eyes are nicely visible on the top surface. I, personally, would edge with solid wood some MDF that was veneered rather than using slab wood but, that's just me and my preferences. For me it's more important how speakers sound, not their looks.
