End Caps Done!
hi, i'm the person in the other thread who had his sda 1C's get manhandled by ups and getting them roughed up pretty badly. i see by this thread that the top and bottom can be replaced. i am interested in this as mine are now pretty rough. i thought i might ask as a sda novice who has been looking to own a pair of these for about 27 years . . . how does one remove the top and bottom wood piece without destroying the rest of the speaker itself?
thanks ahead of time.
marcgd1959 wrote: »hi, i'm the person in the other thread who had his sda 1C's get manhandled by ups and getting them roughed up pretty badly. i see by this thread that the top and bottom can be replaced. i am interested in this as mine are now pretty rough. i thought i might ask as a sda novice who has been looking to own a pair of these for about 27 years . . . how does one remove the top and bottom wood piece without destroying the rest of the speaker itself?
Both the top and bottom caps on the 1C's are held onto the cabinet by glue and long staples, unlike the caps on the bigger SDA's that are bolted on. I would suggest a thin pry bar and a rubber mallet to remove them. Once you get the caps "started" they will come off pretty easily. I have used a 2x4 block of wood on edge and a hammer and tapped on the leading edge of the caps to get them "started" also.
I use a constuction grade of glue (Liquid Nails) to replace the caps and forgot the staples. Let them dry for 24 hours before moving. -
The caps are 1" thick or VERY close. Sal, don't worry, you aren't in the back of the bus
Jeff -
Musky, did you spend any time considering thicker caps? To my eye, the 1" caps look disproportionately thin (on the 2.3TL's anyway). I did a quickie mock-up a couple years back (stacked up layers of 1/8 and 1/4 mdf) and if my memory serves, I think I decided 1-1/4" thick was the sweet spot for the 2.3TL's, with 1-1/2" looking disproportionate in the other direction. Inch-and-a-half might work for the larger 1.2's though. Anyways, just wondering if you considered thicker caps and what you (or anyone else for that matter) concluded.
Yeah, you can put me down for a set. Those are phenomenal.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Mike Reeter wrote: »Both the top and bottom caps on the 1C's are held onto the cabinet by glue and long staples, unlike the caps on the bigger SDA's that are bolted on.
I wouldn't glue the caps on if you're replacing them with solid wood caps. You may get lucky and they may not split/crack over time, but why tempt fate? It's easy enough to just install 4 hanger bolts in the cap like the larger SDA's and drill slightly elongated holes in the cabinet (elongated in the cross grain direction relative to the grain on the solid cap). Plus they are easier to remove in the future. -
Sounds like a plan to me. -
Recieved my end caps from Jeff (musky1963). I am going to install them on Wednesday. I will also post some pictures after they are installed.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Did you order some Larry? Have you installed them if you did?
Glad you got them okay :cool: . I have another set done, so if you want them(Larry), please shoot me a pm. JeffJeff
Musky1963 is just using a solid rectangular slab with no joinery,
He's joining boards together to make the slabs. -
Using several boards or even ripping a single wide one into a few boards, then regluing them back together is better than using just a single wide board. It relieves the stress in wood and less chance of warping.Jeff
Also, I wouldn't consider gluing/ironing on veneer over mdf "joinery". Anyways, I have furniture that is pretty long in the tooth and rarely have I had any issues.Jeff
I agree, was just pointing out to Bubinga99 that you are using joinery.
I have a moisture meter that I use when buying. You can get kiln dried wood at 8% and if the humidity is higher, which it always is here, it will even out in the low teens or 11-12%. Winter is actually drier in humidity. I rarely buy kiln-dried stock as I prefer air-dried/stickered wood. Rule of thumb is it takes about 1 year for every inch of thickness. ie: oak is full of water and weighs a ton when fresh cut. Air-dried maple is pretty stable after time and I think it has better color. BTW, the thick stock that I have(like the table I made you) has been air-dried for atleast 20 years :eek: .Jeff
Can I use the same caps and just make the same radius on the back corners perhaps?Jeff
Could you PM me price and info on SRS2's?Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Well Musky, if you were on economic hard times, Club Polk has just solved that problem....LOL. Nice work man!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
LOL, alot of tire kickers. Actually, only Greg has purchased some caps as of yet :redface:Jeff
I'll get the 1C to you.My 2.3tl's look good so no need to screw with them yet.The 1C's need love first.
I'm all in though so hang in there musky man!
I’M OFFENDED!!!! -
Greg, did you get them put on yet?
I only have the top of the left so far. I've been busy working on one of my SACD players as well. Sorry it's taking so long. One thing is that the holes you drilled into the caps are not precisely lined up with the original holes. I still got the cap on, but barely.
Greg
I found that the hangar bolts can be pulled/tilted a little side to side, if needed to fit into the mating holes in the cabinets. Being coarse thread, they grab and go where they want to. Another option is to slightly elongate or drill a slightly larger hole in the cabs.Jeff
Allright, got all the caps finished. i only took pictures of the tops though as the bottoms look the same but inverted.
:razz: Anyway, pics are below. What do you guys think? Sorry that I am not the greatest photographer in the world either.:redface:
Gonna get on doing a write up of how they sound with the Clarity cap ESA's and Duelund resistors too.
Greg
Looks nice, Greg.
Gorgeous Greg.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Those do look great Greg! High marks for Jeff's work!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Beautiful work, gentlemen!TV - LG 42" LED
Receiver - Pioneer VSX-521
Front speakers - Polk Monitor 40's Series II
Center - Polk Monitor CS1 Series II
Surround - Polk Audio OWM3
Subwoofer - JBL L8400P
"I was born with music inside me. Music was one of my parts. Like my ribs, my kidneys, my liver, my heart. Like my blood. It was a force already within me when I arrived on the scene. It was a necessity for me-like food or water."
~Ray Charles~ -
I think all model Polk originals are just 1" thick, but that may have just been a cost control decision to keep raw material and machine settings constant.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
