Battlefield 3
So I played some co-op with a friend last night and it was fun. The second mission is good because we have to fly a helicopter and it'll be good practice for the multiplayer.
Speaking of which, when I join a multiplayer game, is there a way to join with a friend so we are in the same game? Do we have to squad up beforehand somehow? -
Praz, I'll be on around 915 cst. I've been playing both rush and Conquest. Like em both.
Mud, it's easiest to have your friend join your squad before joining, via the manage squad under quickmatch menu. If u get split up when joining, u can still switch teams when dead if teams won't be unbalanced, and can switch squads any time. -
Thanks, we'll try that. -
I'll try and get on for a little bit tonight but black powder season starts tomorrow so I have to be up at 4 am.Money Talks, Mine says Goodbye Rob!!!!
Fine fine! As long as we mix it up - I'm partial to conquest
Anyway I'll be on in the evening - I can play until about 8:30 or 9pm (PT) as my cousin's husband is coming over to hang out until he picks up my cousin from the airport.I'll try and get on for a little bit tonight but black powder season starts tomorrow so I have to be up at 4 am.
Do it! Join the Platoon!Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
on right now with PS3 PSN is coolsax78Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
Got on with Shep, zeros, biron, and Praz Friday (along with others who knew zeros) , and wow, thats what this game is about. You just don't get those kind of dogfights in COD, this game is meant to be played with friends.
I won't be tonight cause of the Steelers game/Walking dead, but would like to join up with a few of you guys again soon. Fridays are hit and miss for me to play, but if thats the only time you guys can usually get on as a group then so be itAVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
Fridays are really the only days I get to play....weekdays are just to busy.
Good time though. I still suck at the game.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Friday's are my normal gaming days. I'm occasionally on another day here and there, but it just depends.
I applied to the Polk platoon on battlelog. I'm usually on nightly around 10pm cst to about 1am cst. Only days I am not on are wed/thurPn51D550
Panasonic DMP-BDt110
Onkyo HT-RC360
Polk Monitor 60's L/R
Polk CS2 C
Polk Monitor 30's SL/SR
BIC F12
XBOX 360 COD:MW2 250g edition
Logitech Harmony One -
Ok. So multiplayer is good, and like the physics on it, and how some of the environment is destructible. Note the word some.... The one thing that kind of gets on my nerves is that if someone is hiding in a bush, you can not blow up the bush. However in BC 2 if I saw someone hiding in a bush, I will take them out, then destroy the bush they were in. In battlefield 3 it seems that the lost this, and is kind of irritating. Overall I like the multiplayer though, just wish dice would make an update so, that like in real life everything can be destroyed even the bush's..
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org -
Thanks.
I'm not positive, but I believe they had to tone the destruction down a bit in order to keep frame-rates up. -
I sent you a friend request.
never got it that I saw. try BigheadChotaboy and see if that makes a difference.
otherwise I'll look you up tonight when I get a chance. -
No problem, I canceled it and re-sent one. -
That would make sense, but you would think that with the new engine it would be able to support that no matter what. I would think that would be part of the basics for them, but I guess not.
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Thanks.
The engine isn't the problem, its the consoles. They created an engine that would take advantage of todays PC. 2011 PC =/= xbox360 from 2005.AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
I get what your saying, but again look at BC2, they were able to do it then..... At the end of the day though the compairson will still be the same, and will also be the reason why some of the enviorenment is not destructible. Another issue I have is there is no hard core mode. I really enjoy that kind of game play. Alot more realistic, and this whole empty an entire mag into someone is just not realistic, or at least not to me. If I hit someone three - four good times in the right area you are going down.... Oh well it is just how the cookie crumbles....
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
I'm glad they didn't dumb it down across the board.The engine isn't the problem, its the consoles. They created an engine that would take advantage of todays PC. 2011 PC =/= xbox360 from 2005."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
It's night and day trying to play on the 360 vs the PC. One thing I don't understand is why it has to be so slow - for good or bad COD runs much smoother - movement and all. Maybe it's the larger maps, maybe it's a shoddy port of a PC game to the consoles. It's not unplayable, but it takes away from the fun a little.
The PC version has its own issues. Hackers for one. Spawn locations are horrible - spawning right in front of the enemy multiple times is just stupid. Some of the maps are just not suited for conquest (Operation Metro especially). Otherwise, I've enjoyed the PC version (my OCD from the old BF days was in full effect the last week - had to force myself to just not play at all today).
Otherwise, I don't think the graphics engine is very demanding considering how fast today's multi-core cpus and gpus are. But for a 5 year old console, I can see the 360 struggling. Anyone know how the PS3 folks are faring?Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Any PS3 people who haven't made the jump yet, I'm selling mine. I'm a CoD type player. See classifieds.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Conquest Metro should be renamed Spamalot! Great map for acquiring points though.Some of the maps are just not suited for conquest (Operation Metro especially). Otherwise, I've enjoyed the PC version (my OCD from the old BF days was in full effect the last week - had to force myself to just not play at all today)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
HA agreed. You can rack up support points and eng points (noob tubing left and right) - but if you're the team having to come from the subway down below, you're pretty much screwed unless you get that ticket area flag.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Battlefield 3 is definitely a PC game ported to consoles. "Low" graphics quality on the PC is equal to the consoles. That said, the engine is a lot newer and more intensive than the CoD engines (which haven't changed much technically or graphically). That said, it's really a demanding game so break out your quad-cores and recent higher-end graphics cards. It runs fine on my Q8300 & HD5850.It's night and day trying to play on the 360 vs the PC. One thing I don't understand is why it has to be so slow - for good or bad COD runs much smoother - movement and all. Maybe it's the larger maps, maybe it's a shoddy port of a PC game to the consoles. It's not unplayable, but it takes away from the fun a little.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
BTW: Black Friday sale at Wal-Mart will have BF3 for $28 starting at 10pm Thanksgiving night. Just a heads up for anyone crazy enough to jump on it.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Who's gonna be on tonight? Last Friday was great
You know I'll be on and if we need people, I'm sure that group of my hockey buddies that we have been playing with will be on too.
I should be on around 10:30pm cstPn51D550
Onkyo HT-RC360
Polk CS2 C
BIC F12
I'm going to try and jump on around 9-930est
happy huntingWhere’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
