Battlefield 3
1568101117
  • mudwrx
    mudwrx Posts: 367
    edited November 2011
    So I played some co-op with a friend last night and it was fun. The second mission is good because we have to fly a helicopter and it'll be good practice for the multiplayer.
    Speaking of which, when I join a multiplayer game, is there a way to join with a friend so we are in the same game? Do we have to squad up beforehand somehow?
  • shepx2
    shepx2 Posts: 646
    Praz, I'll be on around 915 cst. I've been playing both rush and Conquest. Like em both.
    Mud, it's easiest to have your friend join your squad before joining, via the manage squad under quickmatch menu. If u get split up when joining, u can still switch teams when dead if teams won't be unbalanced, and can switch squads any time.
  • mudwrx
    mudwrx Posts: 367
    shepx2 wrote: »
    Thanks, we'll try that.
  • Grimster74
    Grimster74 Posts: 2,577
    I'll try and get on for a little bit tonight but black powder season starts tomorrow so I have to be up at 4 am.
  • PrazVT
    PrazVT Posts: 1,607
    Fine fine! As long as we mix it up - I'm partial to conquest :) Anyway I'll be on in the evening - I can play until about 8:30 or 9pm (PT) as my cousin's husband is coming over to hang out until he picks up my cousin from the airport.
    Do it! Join the Platoon!
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • coolsax
    coolsax Posts: 1,826
    on right now with PS3 PSN is coolsax78
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • tommyboy
    tommyboy Posts: 1,414
    Got on with Shep, zeros, biron, and Praz Friday (along with others who knew zeros) , and wow, thats what this game is about. You just don't get those kind of dogfights in COD, this game is meant to be played with friends.
    I won't be tonight cause of the Steelers game/Walking dead, but would like to join up with a few of you guys again soon. Fridays are hit and miss for me to play, but if thats the only time you guys can usually get on as a group then so be it
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • mrbiron
    mrbiron Posts: 5,721
    Fridays are really the only days I get to play....weekdays are just to busy.
    Good time though. I still suck at the game.
  • shepx2
    shepx2 Posts: 646
    Friday's are my normal gaming days. I'm occasionally on another day here and there, but it just depends.
  • Splif
    Splif Posts: 114
    I applied to the Polk platoon on battlelog. I'm usually on nightly around 10pm cst to about 1am cst. Only days I am not on are wed/thur
    Pn51D550
    Panasonic DMP-BDt110
    Onkyo HT-RC360
    Polk Monitor 60's L/R
    Polk CS2 C
    Polk Monitor 30's SL/SR
    BIC F12
    XBOX 360 COD:MW2 250g edition
    Logitech Harmony One
  • shepx2
    shepx2 Posts: 646
    Splif wrote: »
    As did I.
  • Zeros
    Zeros Posts: 940
    shepx2 wrote: »
    As did I.
    I accepted you both in to the platoon. Thanks!
  • KaosTsoc
    KaosTsoc Posts: 372
    Ok. So multiplayer is good, and like the physics on it, and how some of the environment is destructible. Note the word some.... The one thing that kind of gets on my nerves is that if someone is hiding in a bush, you can not blow up the bush. However in BC 2 if I saw someone hiding in a bush, I will take them out, then destroy the bush they were in. In battlefield 3 it seems that the lost this, and is kind of irritating. Overall I like the multiplayer though, just wish dice would make an update so, that like in real life everything can be destroyed even the bush's..
    Thanks.
    2006 Prerunner Access Cab
    5 Speed 4 cycl 2wd
    Audio:
    Pioneer P860 Head Unit
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
    Kinetik HC2000 battery and Sleeve
    200 Amp Mean Green High Output Alternator
    Need a DJ, photobooth, or both for rent?
    http://photoboothdallas.org
  • shepx2
    shepx2 Posts: 646
    KaosTsoc wrote: »
    Thanks.
    I'm not positive, but I believe they had to tone the destruction down a bit in order to keep frame-rates up.
  • cstmar01
    cstmar01 Posts: 4,424
    Zeros wrote: »
    I sent you a friend request.
    never got it that I saw. try BigheadChotaboy and see if that makes a difference.
    otherwise I'll look you up tonight when I get a chance.
  • Zeros
    Zeros Posts: 940
    cstmar01 wrote: »
    No problem, I canceled it and re-sent one.
  • KaosTsoc
    KaosTsoc Posts: 372
    shepx2 wrote: »
    That would make sense, but you would think that with the new engine it would be able to support that no matter what. I would think that would be part of the basics for them, but I guess not.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • tommyboy
    KaosTsoc wrote: »
    Thanks.
    The engine isn't the problem, its the consoles. They created an engine that would take advantage of todays PC. 2011 PC =/= xbox360 from 2005.
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • KaosTsoc
    KaosTsoc Posts: 372
    tommyboy wrote: »
    I get what your saying, but again look at BC2, they were able to do it then..... At the end of the day though the compairson will still be the same, and will also be the reason why some of the enviorenment is not destructible. Another issue I have is there is no hard core mode. I really enjoy that kind of game play. Alot more realistic, and this whole empty an entire mag into someone is just not realistic, or at least not to me. If I hit someone three - four good times in the right area you are going down.... Oh well it is just how the cookie crumbles....
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
  • Face
    Face Posts: 14,340
    tommyboy wrote: »
    I'm glad they didn't dumb it down across the board.
  • PrazVT
    PrazVT Posts: 1,607
    It's night and day trying to play on the 360 vs the PC. One thing I don't understand is why it has to be so slow - for good or bad COD runs much smoother - movement and all. Maybe it's the larger maps, maybe it's a shoddy port of a PC game to the consoles. It's not unplayable, but it takes away from the fun a little.
    The PC version has its own issues. Hackers for one. Spawn locations are horrible - spawning right in front of the enemy multiple times is just stupid. Some of the maps are just not suited for conquest (Operation Metro especially). Otherwise, I've enjoyed the PC version (my OCD from the old BF days was in full effect the last week - had to force myself to just not play at all today).
    Otherwise, I don't think the graphics engine is very demanding considering how fast today's multi-core cpus and gpus are. But for a 5 year old console, I can see the 360 struggling. Anyone know how the PS3 folks are faring?
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Toxis
    Toxis Posts: 5,116
    Any PS3 people who haven't made the jump yet, I'm selling mine. I'm a CoD type player. See classifieds.
  • Face
    Face Posts: 14,340
    PrazVT wrote: »
    Conquest Metro should be renamed Spamalot! Great map for acquiring points though.
  • PrazVT
    PrazVT Posts: 1,607
    HA agreed. You can rack up support points and eng points (noob tubing left and right) - but if you're the team having to come from the subway down below, you're pretty much screwed unless you get that ticket area flag.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Bobsama
    Bobsama Posts: 526
    PrazVT wrote: »
    Battlefield 3 is definitely a PC game ported to consoles. "Low" graphics quality on the PC is equal to the consoles. That said, the engine is a lot newer and more intensive than the CoD engines (which haven't changed much technically or graphically). That said, it's really a demanding game so break out your quad-cores and recent higher-end graphics cards. It runs fine on my Q8300 & HD5850.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • kuntasensei
    kuntasensei Posts: 3,263
    BTW: Black Friday sale at Wal-Mart will have BF3 for $28 starting at 10pm Thanksgiving night. Just a heads up for anyone crazy enough to jump on it.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • shepx2
    shepx2 Posts: 646
    Who's gonna be on tonight? Last Friday was great
  • Zeros
    Zeros Posts: 940
    You know I'll be on and if we need people, I'm sure that group of my hockey buddies that we have been playing with will be on too.
  • Splif
    Splif Posts: 114
    I should be on around 10:30pm cst
    Pn51D550
    Onkyo HT-RC360
    Polk CS2 C
    BIC F12
  • mrbiron
    I'm going to try and jump on around 9-930est
    happy hunting
