Group Buy/Bulk Buy - Solid Brass Speaker Spikes - 1/4-20
1567810
  • VSchneider
    VSchneider Posts: 443
    edited August 2011
    Now that we survived the storm, I want these spikes :)
    Hopefully the link works after they are back in stock!
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2011
    when I get mine I am going to turn them a bit on a lathe then dip the points in silver...safety first when you listen with F1....actually I wanna pierce through the carpet into the sub-floor.
    RT1
    SCompRacer Posts: 9,112
    edited August 2011
    Got mine today. Very happy with them. The two pieces of candy included in the pack was a nice touch.
    Ted, LOL on the Silver tips.....
  • madmax
    madmax Posts: 12,434
    edited August 2011
    when I get mine I am going to turn them a bit on a lathe then dip the points in silver...safety first when you listen with F1....RT1
    You might want to go 100% silver on at least one of them. :wink:
    Vinyl, the final frontier...
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2011
    Now we know why F1 hates silver speaker wires.
  • george daniel
    george daniel Posts: 12,096
    edited August 2011
    RT1
    waaaaaaaaaaa--I get it.:wink:
  • polrbehr
    polrbehr Posts: 2,842
    edited August 2011
    Got mine on Tuesday, actually had to sign for them too.
    Glad I am not the only one they threw some candy to, too :tongue:
  • nspindel
    nspindel Posts: 5,343
    edited August 2011
    Got mine yesterday, candy and all :-)
    Great work, Mark!
    Toolfan66 Posts: 18,072
    edited August 2011
    For those of you that have not tried putting anything under their CDP/SACD player take three of these and put them upside down under the player and report back, "if you want" put some under your amp as well, I put four under my amp just because of the weight..
    If you try this please report back...
    Larry.
  • nspindel
    edited August 2011
    What's a CDP/SACD player? Is that like a cassette deck? :tongue:
  • polrbehr
    edited August 2011
    Larry.
    OK, I tried doing what you suggested.
    Now my CDP is tilted over to one side, and it does not sound any better at all.
    Maybe I need help with the placement of the cones? :biggrin:
    Seriously, I am liking the idea of trying this, I am glad I ordered an extra set of 8 (even though I didn't actually need 2 sets... for now)
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2011
    Try some brass weights on top of your CDP...not under it. Mapleshade sells them but so do some other cheaper companies. I'm a big fan of isolation, resonance control, decoupling and weight on equipment, specifically CDP's. Not necessarily in that order, or all at once but the theory.
    Also check out Bright Star Audio....been using them exclusively since 2005.
  • dorokusai
    edited August 2011
    If any of you want to donate a pair to doro, I'll accept them :biggrin:
    edited August 2011
    polrbehr wrote: »
    I put one in the back centered and two up front like a tri-pod, If it tilts use four spikes.
    edited August 2011
    dorokusai wrote: »
    On top?? That is the first I have heard of that, how does that help?? The nice thing is decoupling and isolation doesn't have to be expensive and the out come is fantastic..
  • dorokusai
    edited August 2011
    It's the most undampened piece of the chassis on almost any piece of equipment. The sides are clamped with screws, the bottom has the weight of the internal components on it, so the initial burst of energy or vibration is into the top plate, which will transfer that energy back down into the component, sled assembly, etc etc. You can stop, absorb or limit all of that with weights or a panel on top of the CDP. Just put a finger lightly on top of your player when it spools up to play....
    I use a BSA Little Rock on all my CDP's...works wonders.
  • polrbehr
    edited September 2011
    I gotcha, Larry, I was just in a joking mood yesterday.
    I am going to try this and see what it does, you think a set between the amp and pre would be worth trying? I got enough extras to do 2 pieces.
    polrbehr wrote: »
    Yes try it all..:cool: I think you will be pleasently surprised..:wink:
    dorokusai wrote: »
    I will give it a try..:wink:
  • mole'
    mole' Posts: 3,160
    can we still get the spikes?
    website has it listed as "SOLD OUT"
    mole'
  • Polkersince85
    It will be about two weeks according to his email. That's to fill the backorders. They must have gotten slammed with orders.
    Sorry for the delay on the brass speaker feet. I was told by our
    supplier that he could deliver in 10-14 days. We will ship asap.
    Regards,
    Mark
    heiney9 Posts: 25,446
    FYI,
    Just got an email from Mark at Meniscus Audio and these are available again. I just ordered my set a few minutes ago
    EndersShadow Posts: 17,705
    Anyone know what difference there is between the Meniscus ones and these ones (besides the obvious color difference)?
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-715
    $7 more plus shipping, which from past experience, will probably be atleast $6-8. Get the group buy at $22 shipped, no brainer to me.
    The coupon code for free shipping is "Polkme"
  • Face
    Face Posts: 14,340
    The PE spikes can break with a heavy speaker. I wouldn't recommend PE's spikes with anything larger than a 2B.
    heiney9 wrote: »
    Yeah, I have 2 sets from the first run :smile:. One set already installed on my LSi 15's, the other set will be installed on some custom granite stands I will have fabricated in a month or so. I was just curious as their color looks more in line with the LSi 15 bases.
    Face wrote: »
    Gotcha, but I think the LSi 15's are lighter than the 2b's, but its still good to know.
    I didn't realize you already had the group buy sets. I'd go with what FACE says, but if you aren't moving them more than once or twice maybe it's not an issue.
    heiney9 wrote: »
    No worries. Yeah I think I might just keep these ones then. Brass doesnt look bad, and if I get custom granite risers built for the LSi's I will just take the spikes off them, and put them on the risers so you wont really see them that much.
    Bump to the top so people get a chance at getting some of these!!!!
  • nspindel
    I just ordered 4 more sets - kudos to the suggestion to try using them for isolation of components, not just speakers. Definitely going to give that a try.
