SDA SRS 2 Pin/Blade Crossovers
dcmartinpc
dcmartinpc Posts: 844
edited August 2011 in Vintage Speakers
OK, Most of you probably already know what happened, but because of what appears to be a robbery, I am minus a pair of SRS 2 P/B crossovers.
I need to get these speakers up and running again. I have the schematics for the crossover boards. Here are the options I am currently toying with...
1.) Pick up a set of Gimpod's boards and have a set built up on them
2.) Have a set built point to point
3.) Try to find a stock set and forego this whole modding thing...
Advice????
We can talk about the problems in the other thread. I would like to focus on the options here :smile:
Don
Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
Post edited by dcmartinpc on
  • intangible
    intangible Posts: 262
    edited August 2011
    This sounds like a great excuse to go active, if you've ever had the urge.
    I've noticed a lot of the fellows with Klipsch speakers build large outboard crossovers on blocks of wood, which lets them use comically sized inductors. I know replacing the stock inductors is less popular here, but this would also be a good excuse to try it out. Those crossovers are fairly complex, though, so building new ones would be expensive, either on a circuit board or point to point.
  • dcmartinpc
    edited August 2011
    intangible wrote: »
    My only concern with active is the "SDA" circuit. I am not sure how I would replicate that....
    Don
  • Face
    Face Posts: 14,340
    edited August 2011
    intangible wrote: »
    Not with these speakers.
    Don, your only issue with Gimp's boards or point to point will be sourcing new inductors with the correct DCR.
  • dcmartinpc
    edited August 2011
    I am going to show some of my ignorance here, but is the only inductor in the crossover the large inductor that hangs off the back, I can't remember the looks of the crossover in my head.... If so, I do still have those :D
    Thanks in advance,
    Don
    heiney9 Posts: 25,408
    edited August 2011
    The most viable option is to get Gimpod's boards and then rebuild the x-over to spec.
  • drumminman
    drumminman Posts: 3,396
    edited August 2011
    According to the schematics posted by DK, you have 6 inductors in each xover as follows:
    0.4 mH - 2 each
    0.7 mH - 1 each
    2.75 mH - 2 each
    16 mH - 1 each
    That's alot of inductors. I know most here say do not replace the inductors unless you find new ones with the exact same DCR. IIRC, Doro says he always replaces the inductors, even with those that have a lower DCR.
    I've done the latter in some Def Tech speakers on the advice of Danny Ritchie. I included them in new outboard crossovers I built using point to point wiring, sonicaps/mills. The improvement, after burn in seemed well worth it.
    I couldn't pinpoint the changes brought about by the inductors alone since I did the whole xovers at once but I certainly hear no bad effects.
  • dcmartinpc
    edited August 2011
    Ouch! That is close to $600 in inductors from North Creek!!!
    Don
    Toolfan66 Posts: 17,992
    edited August 2011
    Go with Solen..
  • intangible
    edited August 2011
    Face wrote: »
    Having no experience with active crossovers myself, I will take your word for it, but would you mind expounding? It appears to me that it could be done with one amp for the standard drivers, on for the dimensional drivers, and either two amps for the differing tweeters or with a single amp and a smaller passive crossover.
    edited August 2011
    You can't run active with SDA's. They are a whole other animal because of the SDA circuit.
  • headrott
    headrott Posts: 5,496
    edited August 2011
    +1 for using Gimpod's crossovers. I have done the 3.1TL's using them and he makes it so easy (as long as you can solder) by following the instructions on his site. That is the way I recommend.
    Greg
  • Face
    Face Posts: 14,340
    edited August 2011
    dcmartinpc wrote: »
    Except for the 16mH, the rest would be a waste from NC.
    intangible wrote: »
    heiney9 wrote: »
    H9 hit it on the head, it would be much more complex than your average active setup.
  • dcmartinpc
    edited August 2011
    Is solen my best bet for Inductors then? It is sounding like Gimpod boards are the way to go with replacement inductors. I have the 16mH still since I did not send it with the crossovers. That will save me some. I need to add this up!
    Don
  • Face
    Face Posts: 14,340
    edited August 2011
    edited August 2011
    If nothing else Don, get the boards to have them in case the situation doesn't get resolved. Not sure how many runs he's making but those are going give you the least amount of headaches going forward if you don't ever see your stock x-overs again.
  • gimpod
    gimpod Posts: 1,793
    edited August 2011
    drumminman wrote: »
    0.4 mH - 2 each
    0.7 mH - 1 each
    2.75 mH - 2 each
    16 mH - 1 each
    Sorry but wrong, The SRS SDA 2 pin/blade crossover is the same (component wise) as the SDA 1C and the inductor values are as follows;
    0.4 mH - 2 each
    0.13 mH - 1 each
    2.50 mH (L1) - 1 each
    1.25 mH (L2) - 1 each
    9.6 mH (Big round one) - 1 each
    Don, you my be in luck. I'm sending you a PM on this (it may take me a bit to get it all figured out) Be patient grasshopper.
  • drumminman
    edited August 2011
    gimpod wrote: »
    0.4 mH - 2 each
    0.13 mH - 1 each
    Oops! Sorry, I looked at the schematics for the SRS - I missed the "2" in the title :eek:
  • Marty913
    Marty913 Posts: 760
    edited August 2011
    Face wrote: »
    Not to hijack the thread but related somewhat. If you can't find the exact inductance (.13 for example), do you go one up or one down - or is it more complicated than that.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Face
    Face Posts: 14,340
    edited August 2011
    I believe they can wind custom values for you.
    If not, go up and you can wind them down yourself. There are online inductor calculators you can use or you can pick up a LCR meter to check your work.
