SDA SRS 2 Pin/Blade Crossovers
dcmartinpc
OK, Most of you probably already know what happened, but because of what appears to be a robbery, I am minus a pair of SRS 2 P/B crossovers.
I need to get these speakers up and running again. I have the schematics for the crossover boards. Here are the options I am currently toying with...
1.) Pick up a set of Gimpod's boards and have a set built up on them
2.) Have a set built point to point
3.) Try to find a stock set and forego this whole modding thing...
Advice????
We can talk about the problems in the other thread. I would like to focus on the options here
Don
Advice????
Don
Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
This sounds like a great excuse to go active, if you've ever had the urge.
I've noticed a lot of the fellows with Klipsch speakers build large outboard crossovers on blocks of wood, which lets them use comically sized inductors. I know replacing the stock inductors is less popular here, but this would also be a good excuse to try it out. Those crossovers are fairly complex, though, so building new ones would be expensive, either on a circuit board or point to point. -
intangible wrote: »This sounds like a great excuse to go active, if you've ever had the urge.
My only concern with active is the "SDA" circuit. I am not sure how I would replicate that....
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
Not with these speakers.intangible wrote: »This sounds like a great excuse to go active, if you've ever had the urge.
Don, your only issue with Gimp's boards or point to point will be sourcing new inductors with the correct DCR."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I am going to show some of my ignorance here, but is the only inductor in the crossover the large inductor that hangs off the back, I can't remember the looks of the crossover in my head.... If so, I do still have those
Thanks in advance,
The most viable option is to get Gimpod's boards and then rebuild the x-over to spec.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
According to the schematics posted by DK, you have 6 inductors in each xover as follows:
0.4 mH - 2 each
0.7 mH - 1 each
2.75 mH - 2 each
16 mH - 1 each
That's alot of inductors. I know most here say do not replace the inductors unless you find new ones with the exact same DCR. IIRC, Doro says he always replaces the inductors, even with those that have a lower DCR.
I've done the latter in some Def Tech speakers on the advice of Danny Ritchie. I included them in new outboard crossovers I built using point to point wiring, sonicaps/mills. The improvement, after burn in seemed well worth it.
I couldn't pinpoint the changes brought about by the inductors alone since I did the whole xovers at once but I certainly hear no bad effects."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Ouch! That is close to $600 in inductors from North Creek!!!
Having no experience with active crossovers myself, I will take your word for it, but would you mind expounding? It appears to me that it could be done with one amp for the standard drivers, on for the dimensional drivers, and either two amps for the differing tweeters or with a single amp and a smaller passive crossover. -
You can't run active with SDA's. They are a whole other animal because of the SDA circuit.
+1 for using Gimpod's crossovers. I have done the 3.1TL's using them and he makes it so easy (as long as you can solder) by following the instructions on his site. That is the way I recommend.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Except for the 16mH, the rest would be a waste from NC.dcmartinpc wrote: »Ouch! That is close to $600 in inductors from North Creek!!!intangible wrote: »Having no experience with active crossovers myself, I will take your word for it, but would you mind expounding? It appears to me that it could be done with one amp for the standard drivers, on for the dimensional drivers, and either two amps for the differing tweeters or with a single amp and a smaller passive crossover.
H9 hit it on the head, it would be much more complex than your average active setup.You can't run active with SDA's. They are a whole other animal because of the SDA circuit.
H9"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Is solen my best bet for Inductors then? It is sounding like Gimpod boards are the way to go with replacement inductors. I have the 16mH still since I did not send it with the crossovers. That will save me some. I need to add this up!
Solen would have too low of a DCR.
From a quick search, these are close.
http://www.madisoundspeakerstore.com/air-core-19-awg/
http://www.madisoundspeakerstore.com/air-core-20-awg/
http://www.parts-express.com/mfg/jantzen/jantzen.cfm#20gauge"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
If nothing else Don, get the boards to have them in case the situation doesn't get resolved. Not sure how many runs he's making but those are going give you the least amount of headaches going forward if you don't ever see your stock x-overs again.
drumminman wrote: »According to the schematics posted by DK, you have 6 inductors in each xover as follows:
0.4 mH - 2 each
0.7 mH - 1 each
2.75 mH - 2 each
16 mH - 1 each
Sorry but wrong, The SRS SDA 2 pin/blade crossover is the same (component wise) as the SDA 1C and the inductor values are as follows;
0.4 mH - 2 each
0.13 mH - 1 each
2.50 mH (L1) - 1 each
1.25 mH (L2) - 1 each
9.6 mH (Big round one) - 1 each
Don, you my be in luck. I'm sending you a PM on this (it may take me a bit to get it all figured out) Be patient grasshopper.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
0.4 mH - 2 each
0.13 mH - 1 each
Oops! Sorry, I looked at the schematics for the SRS - I missed the "2" in the title :eek:"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Not to hijack the thread but related somewhat. If you can't find the exact inductance (.13 for example), do you go one up or one down - or is it more complicated than that.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I believe they can wind custom values for you.
If not, go up and you can wind them down yourself. There are online inductor calculators you can use or you can pick up a LCR meter to check your work."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
